RC MODELI AVIONA - ELEKTRO => TRENAŽNI MODELI => Topic started by: Sava on May 04, 2014, 10:00:25 AM
Nimfa iz grčke mitologije je dala ime ovom modelu. Završen je za poletanje, posle probe će dobiti i šaru, naravno ako pristojno leti kao što izgleda. Urađena je od deprona debljine 6mm. i sa baterijom od 2200mA lagana je 600 grama.
(http://i1092.photobucket.com/albums/i403/uzvars/DSCF1323_zps418f3270.jpg) (http://s1092.photobucket.com/user/uzvars/media/DSCF1323_zps418f3270.jpg.html)
(http://i1092.photobucket.com/albums/i403/uzvars/DSCF1326_zps8c456abc.jpg) (http://s1092.photobucket.com/user/uzvars/media/DSCF1326_zps8c456abc.jpg.html)
(http://i1092.photobucket.com/albums/i403/uzvars/DSCF1329_zpsfcec1198.jpg) (http://s1092.photobucket.com/user/uzvars/media/DSCF1329_zpsfcec1198.jpg.html)
(http://i1092.photobucket.com/albums/i403/uzvars/DSCF1330_zps1cf7de6d.jpg) (http://s1092.photobucket.com/user/uzvars/media/DSCF1330_zps1cf7de6d.jpg.html)
(http://i1092.photobucket.com/albums/i403/uzvars/DSCF1331_zps11d88137.jpg) (http://s1092.photobucket.com/user/uzvars/media/DSCF1331_zps11d88137.jpg.html)
(http://i1092.photobucket.com/albums/i403/uzvars/DSCF1391_zps0f7ebc17.jpg) (http://s1092.photobucket.com/user/uzvars/media/DSCF1391_zps0f7ebc17.jpg.html)
Lepo izgleda svaka cast :)aplauz
:)aplauz :)aplauz :)aplauz
Bravo Kume
I ja sam pre dve godine pravio nesto slicno,ali od stirodura
(http://i.imgur.com/ZEgwQAE.jpg?1)
(http://i.imgur.com/kUrLOFp.jpg?1)
(http://i.imgur.com/2grsKVe.jpg?1)
(http://i.imgur.com/0CaKGEr.jpg?1)
(http://i.imgur.com/p1D0SaM.jpg?1)
Svaka cast Savelija. Tvoj dan je izgleda kao i onih bagera u Kolubari, 28 sati
Kada stignes da napravis tolike modele?
;namig Ćut´ nesmem sve ni da postavim, nebi verovali. (work) Samo da se prolepša vreme pa da ovu nimfu okupam ili da joj pravim stajni trap da ne odere trbuh na suvozemnom sletanju.
Mozete li da okacite planove?
http://www.snicerc.com/free_plans/icona5/
http://www.snicerc.com/free_plans/icon-a5-ss-snice-sport-52/nggallery/slideshow/
Da sam ranije imao ove planove sigurno bih pravio drugu veću verziju. Sviđaju mi se oba modela i kako je žabu teško naterati u vodu tako i mene da pravim i taj model. Ako ne pre, zadatak za zimu je dobijen. Hvala za planove, pozdrav :big smile
Obećao sam raport sa prvog leta sirene Čariklo i evo tek sada bez video klipa i nekih velikih slikanja napravljen je prvi let. Neverovatno šta sve može da uradi ovaj model. Na travi zatrčava 50 cm. (pedeset santimetara) i leti u tačku kao raketa Let je kao po šinama , a sa trećinom gasa leti za sav materijal ugrađen u njega. Sa baterijom 1300 mAh 3s leti 8 minuta i potroši oko 700 mAh.
Kada ga malo našaram ( proučavam tehnologiju tibeteagle) potrudiću se da napravim video klip. Do tada ova snežno bela varijanta.
(http://i1092.photobucket.com/albums/i403/uzvars/DSCF1324_zpsd51fe2ce.jpg) (http://s1092.photobucket.com/user/uzvars/media/DSCF1324_zpsd51fe2ce.jpg.html)
Ode nam Sava u stiropor definitivno. Isaraj ga sto vise pa u nebo i kaci neki video.
Ovo moze biti interesantan pocetnicki model.
Ovih dana sam baš nešto vazdan modelario i uzmem da obučem onu sirenu, leti lepo red je da je završim.
(http://i1092.photobucket.com/albums/i403/uzvars/DSCF1641_zps84965a16.jpg) (http://s1092.photobucket.com/user/uzvars/media/DSCF1641_zps84965a16.jpg.html)
(http://i1092.photobucket.com/albums/i403/uzvars/DSCF1642_zps792d3a13.jpg) (http://s1092.photobucket.com/user/uzvars/media/DSCF1642_zps792d3a13.jpg.html)
(http://i1092.photobucket.com/albums/i403/uzvars/DSCF1643_zpsd5e9bc3b.jpg) (http://s1092.photobucket.com/user/uzvars/media/DSCF1643_zpsd5e9bc3b.jpg.html)
(http://i1092.photobucket.com/albums/i403/uzvars/DSCF1644_zps101d4baa.jpg) (http://s1092.photobucket.com/user/uzvars/media/DSCF1644_zps101d4baa.jpg.html)
Svidja mi se ovaj model,svaka cast na izgradnji. :)aplauz
Posto imam isti motor planiram da ga izgradim,koristio bih stirodur 1cm debljine mmmm i uskoro dobijam ram za zicom za secenje,da li bi bilo dobro da imam samo elevator i rudder jer nemam servoe za elerone,kako se ponasa,i kako se zove model gde ga mogu naci po netu?
Lepo odradjeno kao i uvek, vidi se da ga je ruka iskusnog modelara odradila ;namig :)aplauz :)aplauz :)aplauz (res)
Ako sve bude po planu, do kraja meseca najzad zavrsavam moj kutak u kuci i pocinjem da pravim CNC sekac, a kad proradi i modele ;namig
Hvala na lepim rečima. Lepo je imati nove alatke, sigurno skraćuju posao i poboljšavaju kvalitet. Ja od CNC sekača imam tri modelarska rama, levi, desni i ravni. A tu je i par skalpela, veoma kvalitetnih, tako da se može solidno raditi. Cela paleta šmirgla na dašici rešava problem površinske obrade.
Koristim priliku da se zahvalim Tibeteagle čije sam savete koristio kod farbanje modela. Može lepo da se uradi, samo strpljenja.
Jes da nije za ovu temu ali evo jednog interesantnog resenja za CNC secenje.
http://translate.google.com/translate?hl=en&sl=de&tl=en&u=http%3A%2F%2Fwww.cnc-hotwire.de%2F (http://translate.google.com/translate?hl=en&sl=de&tl=en&u=http%3A%2F%2Fwww.cnc-hotwire.de%2F)
Bas su me zainteresovale CNC masine,vidim da ih nije toliko tesko napraviti,malo googlanja i sve se moze resiti. (work)
http://www.flitetest.com/articles/Hot_Wire_CNC_foam_cutter ovo je ovde onako lepo objasnjeno sta je sve potrebno mmmm
Posto sam u elektrotehnickoj skoli za smer "mehatronika" porazgovaracu za profesorima da vidim sta oni misle o ovoj masini :big smile jer nisam strucnjak (fiu)
Jeste lepo ali je prilicno skupo napraviti I pustiti da radi CNC masina.
To jeste,kako rece jedan modelar,vruca zica za rucno secenje je neprevazidjena (za aeroprofil),jos trafo da stigne i krecem u akciju (<--) nego jeste glupo sto ova tema nije vezana za secenje al' nadam da se nece biti problema.
http://rcfly4um.org/Smileys/default/respekt.gif Sjajno, video sam najmanje u dva navrata ovaj model ali ne i ofarban. Nas drugar Sava ne samo sto izuzetno kvalitetno i pedantno izradjuje svoje modele vec je i brzina izuzetna, sustizu jedan drugog. Julije i ja (Novi Sad) izgibosmo nedelju dana sklapajuci i podesavajuci Furnije ARF. Savo sve cestitke.
Bata Stepanovic.
