RAZNO => AUTO / BRODO MODELI => Topic started by: zgrmbust on March 03, 2013, 10:32:04 PM
Title: Kvalitetan alat?
Post by: zgrmbust on March 03, 2013, 10:32:04 PM
ima li neko preporuku za kvalitetne - tvrde HEX srafcigere ili kljuceve po nekoj pristupacnoj ceni (1.5,2,2.5,3,mm)  :sljus
Title: Re: Re: Setovanje kocnica na 1/8 Buggy/Truggy Nitro
Post by: magic on March 03, 2013, 10:45:20 PM
Da ne otvaram novu temu ..... ima li neko preporuku za kvalitetne - tvrde HEX srafcigere ili kljuceve po nekoj pristupacnoj ceni (1.5,2,2.5,3,mm)  :sljus
http://www.hobbyking.com/hobbyking/store/__11048__Turnigy_Long_Shaft_4pc_Hex_driver_set.html (http://www.hobbyking.com/hobbyking/store/__11048__Turnigy_Long_Shaft_4pc_Hex_driver_set.html)
Post by: zgrmbust on March 03, 2013, 10:48:48 PM
Hvala....  :)
Post by: mantagt on March 03, 2013, 11:06:46 PM
Mogu samo da dodam da imam taj alat već duže vreme i jako sam zadovoljan njime... Inače urnišem alat i ništa mi ne traje dugo, a ovim hexovima još nijedna ćoškica ne fali...  :big smile
Za male pare, a odlično!
Post by: zgrmbust on March 03, 2013, 11:29:05 PM
Sutra porucujem 2 seta..... desilo mi se bar 2 puta usled rasklapanja modela da se ogule neki imbusi koje sam imao da covek po (___)di....
Post by: magic on March 03, 2013, 11:39:10 PM
Ako vec porucujes uzmi slobodno i colovne i ostale kljuceve iz ove serije koje tamo imaju, totalno sulud kvalitet za male pare. Ja sam isto uvek ludeo sa imbusima, kupovao razne, kupio i Unior, ali ovo je za klasu iznad.
Post by: zgrmbust on March 03, 2013, 11:43:32 PM
Hvala za pomoc i predloge   (res)
Post by: magic on March 03, 2013, 11:48:58 PM
pored onoga jos treba uzeti i ovo:
http://www.hobbyking.com/hobbyking/store/__9976__TURNIGY_4pcs_hex_socket_driver_set_.html (http://www.hobbyking.com/hobbyking/store/__9976__TURNIGY_4pcs_hex_socket_driver_set_.html)
http://www.hobbyking.com/hobbyking/store/__22646__Turnigy_HEX_socket_Screwdriver_3_6_inch_1_4_inch_11_32_inch_and_3_8_inch_4pcs.html (http://www.hobbyking.com/hobbyking/store/__22646__Turnigy_HEX_socket_Screwdriver_3_6_inch_1_4_inch_11_32_inch_and_3_8_inch_4pcs.html)
http://www.hobbyking.com/hobbyking/store/__22645__Turnigy_Imperial_Hex_Driver_Set_050_1_16_5_64_3_32_4pc.html (http://www.hobbyking.com/hobbyking/store/__22645__Turnigy_Imperial_Hex_Driver_Set_050_1_16_5_64_3_32_4pc.html)
http://www.hobbyking.com/hobbyking/store/__18027__Work_Stand_Plastic_Titanium_Color_.html (http://www.hobbyking.com/hobbyking/store/__18027__Work_Stand_Plastic_Titanium_Color_.html)
kao i nesto ovako u velicini koja odgovara vasim sponama
http://www.hobbyking.com/hobbyking/store/__23069__Turnigy_Turnbuckle_Wrench_4mm.html (http://www.hobbyking.com/hobbyking/store/__23069__Turnigy_Turnbuckle_Wrench_4mm.html)
Post by: matovic on March 04, 2013, 12:04:46 AM
Ja narucih danas ovo http://www.hobbyking.com/hobbyking/store/__9976__TURNIGY_4pcs_hex_socket_driver_set_.html (http://www.hobbyking.com/hobbyking/store/__9976__TURNIGY_4pcs_hex_socket_driver_set_.html)
Kazu mana su male/kratke drskice ali to nije toliki problem.... jes da nije tema za to ali moram da kazem da Losi-ev alat (ne onaj koji dolazi uz model vec onaj malo "bolji" koji ima na amain) koji koristim nesto oko godinu dana je otisao dodjavola, glave oblaznule i totalno sam razocaran obzirom da sam ga platio $55+ :(
Post by: Bigneda on March 04, 2013, 01:35:08 AM
I ja da dodam da je odlican alat ne za te pare nego i za vise puta vece ;)
Moj set su doduse reklamirali kao HSS ali su slike i cena isti pa predpostavaljam da su samo stampu skinuli sa alata :)
Po evropi za takav 'brendirani' set traze OD 25eu pa navise ! ...jes da mnogo lepse izgleda  (pijemo)
Post by: JLZ on March 04, 2013, 09:45:12 AM
Ja sam uzeo duge inbus kljuceve Unior u Merkatoru i odlicni su. Takodje, njihove t-racve za 2,5 i 3mm.
Srafcigeri: Wera
Ako hoces da ustedis imas i ovo (http://www.amainhobbies.com/product_info.php/cPath/89_140_2022_2023/products_id/40099/n/Dynamite-5-Piece-Metric-Hex-Driver-Set). Meni se jedan slomio jer je bio sa defektom. Promptno su ponudili zamenu ili refund.
(ako narucis preko 25$, dostava je skoro dzaba (0.5-0.8$)
Title: Re: Kvalitetan alat?
Post by: zgrmbust on March 04, 2013, 12:17:50 PM
Porucio sam deo alata iz HK  ...... imao je najvise glasova  :big smile,  hvala svima.
Post by: sman on March 04, 2013, 02:21:26 PM
najvise imam problema (pretpostavljam i ostali) sa inbusom od 1.5mm dok se ovi veci drze dobro ...promeno sam ih dosta ali svi su bili loseg kvaliteta, prosle godine sam pazario ovaj i za sada je ok...
http://www.amainhobbies.com/product_info.php/cPath/89_140_2019_2020/products_id/25117/n/E-flite-15mm-Hex-Driver (http://www.amainhobbies.com/product_info.php/cPath/89_140_2019_2020/products_id/25117/n/E-flite-15mm-Hex-Driver)
Post by: Agama on March 04, 2013, 09:07:50 PM
Ja preferiram VP PRO jer je ok cena, al isto tako imam i od HUDY taj je po kvalitetu top(al je malo poskup)
