RC MODELI AVIONA - SUS => SCALE MODELI => Topic started by: Sava on December 07, 2009, 06:01:59 PM
Title: Samo da nije zut
Post by: Sava on December 07, 2009, 06:01:59 PM
ovako je sve pocelo:
(http://img22.imageshack.us/img22/1763/29356206.th.jpg) (http://img22.imageshack.us/i/29356206.jpg/)
(http://img37.imageshack.us/img37/4804/35372843.th.jpg) (http://img37.imageshack.us/i/35372843.jpg/)(http://img229.imageshack.us/img229/7083/44445753.th.jpg) (http://img229.imageshack.us/i/44445753.jpg/)(http://img17.imageshack.us/img17/5879/67968813.th.jpg) (http://img17.imageshack.us/i/67968813.jpg/)
(http://img22.imageshack.us/img22/3584/42306008.th.jpg) (http://img22.imageshack.us/i/42306008.jpg/)(http://img214.imageshack.us/img214/8564/15679408.th.jpg) (http://img214.imageshack.us/i/15679408.jpg/)(http://img22.imageshack.us/img22/3996/46463434.th.jpg) (http://img22.imageshack.us/i/46463434.jpg/)
Ovde se vec nazire kraj:
(http://img340.imageshack.us/img340/931/85526319.th.jpg) (http://img340.imageshack.us/i/85526319.jpg/)(http://img11.imageshack.us/img11/2707/61283353.th.jpg) (http://img11.imageshack.us/i/61283353.jpg/)(http://img17.imageshack.us/img17/6658/76601750.th.jpg) (http://img17.imageshack.us/i/76601750.jpg/)
Ovde su dva brata zut i nezut:  :sljus
(http://img22.imageshack.us/img22/1771/28769043.th.jpg) (http://img22.imageshack.us/i/28769043.jpg/)
Title: Re: Samo da nije zut
Post by: coka on December 07, 2009, 07:48:00 PM
 Svaka cast, Savelija.
 Videti da neko rucno izradjuje avione, pa sa tim jos i tako pedantno, uvek me razveseli.
 Nadam se da ces provesti mnoge lepe trenutke u vazduhu sa novim avionom. Sto se tice pomoci oko sletanja, vrlo rado.
 Izgubio sam tvoj tel...zvrcni kada budes radio.
Post by: mirce on December 07, 2009, 08:46:55 PM
Bravo Savo, ajd' sad malo detalja o modelu, koliki je, koji motor, težina... i sve ostalo po redu...
Imam jedno pitanje, vidim na jednoj slici kako si postavio antene prijemnika. Znajući kako treba da stoje na Futabi i JR-u da li je to tako kako si namestio OK?
Da se nije onaj letos "oteo" možda zbog toga?
Sve u svemu konačno da još neko stavi neki svoj "projekat" a, tebi Savo, sve najbolje sa modelom, da se naletiš i nauživaš želi
Post by: Sava on December 07, 2009, 09:55:03 PM
Model je radjen po planovima koji se isporucuju uz kit i kao takvi su nepotpuni i nepodobni za izradu modela na ovaj nacin kao sto sam ja radio.Drugim recima, sve sto je bilo "odstancovano" nije se nalazilo na crtezu i morao sam te detalje sam da nacrtam. Inace sam ceo model radio sa prekidima oko dva meseca.Raspon krila 195 cm. sa tezinom 2900 gr. na polatanju, sto je za 600 grama lakse od nekadasnjeg modela iz kita.Motor je 2T OS Max 10 ccm.Rezervoar 300ccm.Olovo u repu 10 grama, videcemo na prvom poletanju da li je to prava mera.
Nisam siguran da sam razumeo Mircetovo pitanje u vezi antena.Antene sam postavio pod uglom od 90 stepeni u horizontalnoj ravni.Neznam mozda je to greska,odnosno da li treba druga antena da stoji u vertikalnoj ravni takodje po 90 stepeni.Ovako ugradjenu antenu imamo na Extri i nikakvih problema nije bilo. U svakom slucaju, ako sam pogresio veoma sam zahvalan Mircetu na ukazanom.
Rado cu odgovoriti kolegama na pitanja oko izrade modela.
Post by: magic on December 07, 2009, 10:02:58 PM
Ja koliko vidim antene stoje pravilno!
Post by: englez on December 07, 2009, 10:18:12 PM
Izgleda dobro, mogu ja prvi da letim?   :mhm
Post by: Sava on December 07, 2009, 10:39:51 PM
Englez prvi da leti samo pod uslovom da Mirce bude prisutan da ga skida sa drveta. :_D (yay)
Post by: misha on December 08, 2009, 12:01:31 AM
Sve cestitke na lepom modelu. sto se tice boje u potpunosti se slazem. iako obozavam Cub-a, uzasava me ona zuta boja.
kada polece? ako bude mogucnosti bilo bi lepo da bude i neki snimak.
pozdrav iz kragujevca
Post by: mirce on December 08, 2009, 12:06:13 AM
Meni se čini da obe antene idu prema napred... Ona stegnuta čičak trakom ide definitvno a, ova druga izlazi prema rezervoaru pa, onda 180 stepeni pa, u istom smeru sa prvom...
Možda grešim...
Ipak ja nosim naočare, da dobro vidim verovatno mi ne bi trebale...
Post by: POSEIDON on December 08, 2009, 11:00:33 AM
Ništa...još ja da osposobim mog Piper super cub (bivšeg mishinog) za let,pa na proleće...a što da ne i zimi napravimo jedan Piper Cub skup (<--)
Post by: Sava on December 08, 2009, 02:31:55 PM
Model je potpuno zavrsen, natrimovan i samo ceka lepsi dan, sipamo gorivo i prvo poletanje pripada sinu Banetu.Planiramo i neke slike sa letenja pa na forum.
Sto se tice antena, prva je smestena u cevcicu ispred servoa gasa i stoji upravno na trup.Druga antena takodje stoji u plasticnoj cevcici ali odmah ispod levog prozora i uzduzna je na trup,sto cini njihov medjusobni ugao od 90 stepeni.Sivi kablovi pa i onaj ispod cicka (da ne landara) su dovodni koaksijalni kablovi do samog aktivnog dela antene.To je onaj ogoljeni deo antene, koji je u stvari antena.Mozda sam u zabludi,ali na ovaj nacin smo namestali u tri modela i nije bilo problema.Drugim recima sivi koaksijalni deo moze biti dugacak koliko i model,aktivan je samo ogoljeni deo.Proizvodjac isporucuje ovu kracu varijantu,ali je moguce produziti u nekim prilikama sam dovodni deo da bi se antena postavila van trupa ukoliko ima puno metalnih delova.Inace najbolji polozaj ovih antena i jeste van trupa.
Saru za ovog Pajpera sam pozajmio od Hangar9 ,ali je sam model radjen po Carl Goldbergu.
Post by: uzvarb on December 08, 2009, 04:09:11 PM
Pozdrav evo slike iz futabinog uputstva o antenama. antena je samo onaj kraj, duzine nekih 20mm ,a onaj deblji deo je koaksijalni kabl. Znaci bitno je da krajevi antene zadnjih 20mm ili tanji deo iste budu pod uglom od 90 stepeni i ravne.
Post by: mirce on December 08, 2009, 05:40:00 PM
E, to nisam znao, mislio sam da je ceo kabel antena. Hvala na informacijama...
Mir;e
