RAZNO => MATERIJALI / TEHNIKE OBRADE U MODELARSTVU => Topic started by: leonardofibonacci on September 03, 2010, 11:43:17 PM
Title: Velicina balse?
Post by: leonardofibonacci on September 03, 2010, 11:43:17 PM
Da li se balsa uvek sece u 10x100, ili ima i drugih varijanti? Trebalo bi da isecem jedan deo, koji ne staje na tu plocu, a mora da bude iz jednog dela . . .
Title: Re: Velicina balse?
Post by: misha on September 04, 2010, 12:12:04 AM
sastavis. imas na forumu vec objasnjeno. mislim da je drugi post na prvoj strani
http://rcfly4um.org/index.php?topic=570.msg3456#msg3456 (http://rcfly4um.org/index.php?topic=570.msg3456#msg3456)
Post by: leonardofibonacci on September 04, 2010, 01:00:32 AM
Znam da se to tako radi, ali ja bih iskljucivo jedan deo.
Post by: IvanGrozni on September 04, 2010, 12:58:47 PM
Do sada nisam video balzu širine veće od 10cm i dužine veće od 100cm. Čini mi se da nećeš naći.
Post by: grebic on September 04, 2010, 01:00:12 PM
Ako lepo zalepis dva dela jedan za drugi Henkel belim lepkom, spoj je jaci od same balze. Ako te to brine.Probaj sa dva manja parceta i videces da uvek puca van spoja. Samo lepo obradi ivice koje lepis jednu za drugu, da da budu 100% ravne, da imas sto bolje naleganje i nemas problema. Pozdrav
Post by: tibeteagle on September 04, 2010, 10:23:51 PM
U sirinu pa i u dužinu se mogu sastavljati plankovi. Evo jednog klasičnog načina lepljenja ivica:
http://www.airfieldmodels.com/information_source/how_to_articles_for_model_builders/construction/edge_join_balsa_sheet_skins/index.htm (http://www.airfieldmodels.com/information_source/how_to_articles_for_model_builders/construction/edge_join_balsa_sheet_skins/index.htm)
Balza šper:
http://www.airfieldmodels.com/information_source/how_to_articles_for_model_builders/construction/make_balsa_wood_plywood/index.htm (http://www.airfieldmodels.com/information_source/how_to_articles_for_model_builders/construction/make_balsa_wood_plywood/index.htm)
Neki proizvođači balza poluproizvoda prave veće plankove za modelare koji prave velike skejl modele. Evo jednog nemačkog sajta:
http://www.thomabalsa.de/ (http://www.thomabalsa.de/)
