RAZNO => MATERIJALI / TEHNIKE OBRADE U MODELARSTVU => Topic started by: sasa on December 06, 2020, 09:20:30 PM
Title: BALZA
Post by: sasa on December 06, 2020, 09:20:30 PM
Gde kupiti balzu ...
Title: Re: BALZA
Post by: Milos 94 on December 07, 2020, 09:00:24 AM
Sitologika
Title: Re: BALZA
Post by: Velicki on December 07, 2020, 09:38:17 AM
Sitologika, na Zelenom vencu i ima u u URADI SAM
Title: Re: BALZA
Post by: sasa on December 07, 2020, 01:33:44 PM
Hvala vam ,ali za ove znam ima li negde drugde.
Sitologika 410 km
Uradi sam losa i nema sve
Title: Re: BALZA
Post by: Milos 94 on December 07, 2020, 02:16:47 PM
Pera CVM u Timočkoj?
Title: Re: BALZA
Post by: sasa on December 07, 2020, 02:39:12 PM
410km  :mhm
Title: Re: BALZA
Post by: SABURO on December 07, 2020, 03:07:24 PM
Negde u januaru sam jurio laganu/takmicarsku balzu od 2.5mm, na kraju je porucio iz Kine  8) cekao je par meseci, al je stigla. Ako trebas tako nesto ovde kod nas, jedino se moze izabrati u sitologici, al opet, trebalo bi da je sam odaberes u tom slucaju. Eventaulno vidi s Vladom iz RC srbije da li ima nesto na lageru i sl
Title: Re: BALZA
Post by: sasa on December 07, 2020, 03:18:58 PM
DEZINFORMACIJA
Nemaju je već duže vreme
Nidžo,to i jeste problem ,odabiranje,a ja iz KŠ-a ne mogu da biram na daljinu.Od Pilića (rc srbija) sam uzimao i vlada to odabere super ,ali je već duže vreme nema.
Ide zima...šta da se radi... :sljus
Title: Re: BALZA
Post by: coka on December 07, 2020, 08:29:54 PM
Sale
Posaljes mi sta ti i kakva treba, ja odem do sitologike, odaberem, kupim i posaljem ti....npr
 Inace, Sitologika je trenutna jedina opcija nabavke balze.
Coka
Title: Re: BALZA
Post by: dejan_ts on December 07, 2020, 10:34:15 PM
posteno , treba je izabrati ako se vec radi neki dobar proekat preko zime ,
Sale , a Neca .........
Title: Re: BALZA
Post by: sasa on December 08, 2020, 10:37:06 PM
Hvala Coko,javicu ti ako mi bude trebala tvoja pomoc.  (pijemo)
Samo da Dejan nadje te fajlove za rezanje.. :sljus
Pozdrav...
Title: Re: BALZA
Post by: Nemanja on December 27, 2020, 09:00:00 PM
Ja ću poručiti da mi dođe na adresu iz sitologike. Zamolio sam lika da mi probere, nemam uvek vremena da idem tamo ali naravno nađe se ponekad pa ako treba tu sam.
Ono što sada mene muči je gde da nađem avio šper od 3mm? I sa koliko slojeva da tražim za Rascala 140cm?
Title: Re: BALZA
Post by: Stanko BG on December 27, 2020, 09:22:50 PM
Proverio sam kod Vlade Pilića na sajtu - u Rc Srbiji izgleda nema 3mm brezovog aviošpera na stanju. Odlična zamena za brezov višeslojni aviošper je topolov šper - lagan i dovoljno jak. I Sava Užvar i ja smo mnoge modele iz samogradnje pravili upotrebom topolovog špera. Mislim da je dovoljno jak troslojni topolov šper, a idealno bi bilo da ima šetiri sloja, mada nije neophodno. Topolov šper je ranijih godina pravila firma ,,Mitros šper" iz Sremske Mitrovice, ali mi se čini da je ta firma propala.
Sada tog špera ima na mnogim mestima i lako se nabavlja - oplemenjen i impregniram epoxy smolom daje sasvim dobre mehaničke karakteristike:
Evo, probaj za početak u ovoj firmi da se raspitaš za šper ploču od topole 3mm debljine:
https://www.frischeis.rs/shop/SPERPLOCA-TOPOLA-ABBB~p1160921 (https://www.frischeis.rs/shop/SPERPLOCA-TOPOLA-ABBB~p1160921)
Title: Re: BALZA
Post by: Nemanja on December 27, 2020, 11:36:11 PM
Znači sada samo ostaje da vidimo kome sve treba šper od 3mm u ovoj predloženoj izvedbi obzirom da je tabla poveća
2520x1870, i pretpostavljam da se drugačije ne može kupiti??  (work)
Title: Re: BALZA
Post by: grebic on December 28, 2020, 09:54:06 AM
ako vec zoves, pitaj i za sper od 8 i 10mm...treba mi za neke gluposti
A sto se tice debljine od 3, treba meni. Pitaj samo da li seku ne neke manje dimenzije
Meni odgovara nekih, okvirno 1000*600....
Kapiram da bi bilo ok podeliti tablu na ~935*630...tako se dobije 6 tabli te dimenzije
Title: Re: BALZA
Post by: Nemanja on December 28, 2020, 09:55:41 AM
Drvopromet - Kula u Beogradu ima šper od breze 3mm u tri sloja. Tabla je 1500x1500mm u varijaciji sa obe strane lice 1312din i lice i naličje, vodootporna 1046din.
Da li vredi pokušati sa ovoim???
Title: Re: BALZA
Post by: pnedic on December 28, 2020, 10:03:51 AM
Ovo bi bilo idealno ako bi mogli iseci na komade 500x500 ili 500x1000. Pa da par nas podelimo tu tablu.
Title: Re: BALZA
Post by: misha on December 28, 2020, 10:24:14 AM
Kada je u pitanju JAF ili frischeis.rs imaju svega. I ja sam sa sve modele koje sam pravio, sper kupovao kod njih.
Ima i spera od 1 i 20, 25 mm debljine (za Gogija).
Najveciu problem je cena i velicina, cena (bar kod ovih vece debljine) jer je skuplji od iverice
a velicina je problem jer ne seku. Tj, mogu da iseku ali mora da se najavi nekolio dana ranije,
a za nas iz unutrasnjoti to malo bude problem.
Title: Re: BALZA
Post by: grebic on December 28, 2020, 10:40:27 AM
Deee ssiiii Miso...... (pijanoo)
Hm mmmm  taj od 25mm je dobar za jedrilice.... mmmm
Ne znam ni koja je cena ni kakva je procedura...ne verujem da moze da bude nesto preterano skup ovaj od 3mm ")
Ako @Nemanja odluci da narucuje, neka se javi. Ako mu treba jedna tabla, ja cu uzeti ostalih 5 ako mogu da iseku na one dimenzije
Title: Re: BALZA
Post by: Nemanja on December 28, 2020, 10:53:44 AM
Ako Nedić kaže da je bolja varijanta uzeti brezu 1500x1500 onda bih ja uzeo nju, i iscimao ih da nam iskeku po krojnoj listi kako se nas trojica dogovorimo. Meni treba 300x500, a možemo i podeliti na jednake delove, ali ne znam koja je debljina reza, tako da će biti tri table koje su malo manje od 500x1500.
Title: Re: BALZA
Post by: dejan_ts on December 28, 2020, 11:32:39 AM
Dimenzije table treba da budu 1520x1520mm ,
Title: Re: BALZA
Post by: dejan_ts on December 28, 2020, 11:35:33 AM
Lepa cena Balze u sitologici ,nasvirali je bas bas fino ,kad se saberes i oduzmes za raskala ti treba oko 70e samo u balzi ,gde je secenje gde je jos ostatak ,bogami lepa cena za model u ovo doba godine
Title: Re: BALZA
Post by: Nemanja on December 28, 2020, 11:54:57 AM
I ja sad baš rešio da pravim :)
Title: Re: BALZA
Post by: dejan_ts on December 28, 2020, 01:18:33 PM
Bitno je da se pravi nesto a sta i koliko kosta nije ni bitno ovaj hobi nema granicu od do
Title: Re: BALZA
Post by: pnedic on December 29, 2020, 09:22:14 AM
Odvaljuju ! Rekao sam im da zato i imaju balzu jer ubijaju od cena !
Title: Re: BALZA
Post by: misha on December 29, 2020, 10:59:30 AM
A sto se ti brines za 3 mm. Pa imas kod Dekija sigurno spera 3 mm?
Title: Re: BALZA
Post by: Nemanja on December 29, 2020, 11:24:15 AM
U firmi : https://www.frischeis.rs/
Topola 3mm, 2520x1070, 637din/m2 - Ima na stanju
Topola 8mm, 2520x1070, 1147.5din/m2 - Ima na stanju
Topola 10mm, 2520x1070, 1261.5din/m2 - Ima na stanju
Sečenje se može vršiti po krojnoj listi sa napomenom da je debljina reza 4.6mm
Isporuka kuriskom službom je moguća ukoliko su parčići mali (oni rade sa sitijem). Ili ukoliko kupar pošalje kurirsku i unapred dogovori veličinu transtoprnog materijala.
Rezanje je moguće od 12.01.2021.
U firmi : Drvopromet
Breza 3mm, 1520x1520, klasa 3b, 1312din tabla, sečenje  košta ukupno 1050 din i čeka se 15 dana, Pančevački put 80a,
Breza 3mm, 1520x1520, klasa 4b, 1050din tabla ali je na bližoj lokaciji, Zrenjaninski put 43b
Dakle epilog je sledeći,
Ja cu sutra otići autom do ,,Zrenjaninski put 43b,, i sebi kupiti jednu tablu breze 3mm, jer sečenje ne želim da čekam, tako da ko želi neka se javi na PP i ostavi mi svoj broj telefona
Title: Re: BALZA
Post by: grebic on December 29, 2020, 12:46:32 PM
Ima kod Dekija...ali nece da naplati. Ne mogu da se prepirem...treba mi 5-6 tabli
Title: Re: BALZA
Post by: grebic on December 29, 2020, 12:48:29 PM
Hvala (<--)
Title: Re: BALZA
Post by: misha on December 29, 2020, 02:07:13 PM
Onda da uzmem ja, a ti plati meni :)
Title: Re: BALZA
Post by: Rale on March 29, 2021, 11:06:08 AM
U "Brico S" na Novom naselju, u Novom Sadu, je stigla balza !!
Title: Re: BALZA
Post by: pnedic on April 01, 2021, 10:26:56 AM
Nema je na njihovom web site-u  :(
