Author Topic: WKM Wookong  (Read 15750 times)
Offline vpilic
    • http://www.rcsrbija.rs/
WKM Wookong
« on: December 10, 2012, 05:39:42 PM »
OUR WKM have new version of GPS without bug.
Attitude mode maintains precise altitude hold for indoor flight while GPS mode provides superb position hold outdoor. External LED flight mode indicator light can easily be observed by pilots under any condition.
WK-M can be flown in one single full auto (GPS-Atti) mode from take-off to landing; or in Atti mode while manual mode has stabilization activated. The system is easy to install with user friendly software allowing on-line firmware and software upgrade.
Features
 •GPS ATTI - GPS (inclusive) Position, Altitude hold and Heading hold
 •3-AXIS GYRO+Barometer - Attitude mode using accurate barometer sensor for altitude hold
 •The counter ESC - Use regular over the counter ESC
 •Three flight modes - Three flight modes - manual, Attitude and GPS Attitude
 •Fail-Safe - Fail Safe Hover, Go Home & Auto Landing
 •Low voltage protection - Two-level low voltage protection
 •Power Module - Versatile power module for MC power supply,voltage monitoring and CAN bus connections 3A Switching BEC
 •D-Bus - D-Bus supports S-BUS receiver system
Specifications
 •Multi Rotor Types: Quad-Rotor / Hex-Rotor / Octo-Rotor
 •Supported ESC output: 200Hz refresh frequencys
 •Recommended Transmitter: PCM or 2.4GHz with minimum 5 channels and Failsafe function available on all channels
 •Recommended Power Supply: DC 4.8 ~ 12V
 •Power Consumption: MAX 5W (0.9A@5V, 0.7A@5.8V,0.5A@7.4V,0.4A@8V)
 •Operating Temperature: -5°C to +60°C (You have to keep the IMU warm if you want to use it under low temperature, could be -5°Cor lower.)
 •Flight Performance (can be effect by mechanical performance)
 •Hovering Accuracy: Vertical: ± 0.5m / Horizontal: ± 2m
 •Suitable Wind Condition: < 8m/s (17.7mph)
 •Max Rotate Angle: 30°
 •Vertical Speed: 3m/s
 •Packaging &Shapes
Dimensions
 •Main Controller: 61mm x 39.6mm x 15.8mm
 •IMU: 40mm x 31mm x 26mm
 •GPS & Compass: 50mm (diameter) x 9mm
 •LED Indicator: 25mm x 25mm x 7mm
 •Total Weight: <= 150g
Built In Functions
 •Auto-pilot
 •Fail-safe Hover
 •Gimbal Stabilization
 •Voltage monitor
 •Go Home & Auto Landing
http://www.dji-innovations.com/products/wookong-m/overview/
Za vise informacija javite nam se putem maila: prodaja@rcsrbija.rs
RcSrbija daje 10% popusta na svim DJI proizvodima porucenim do 28.12.2012
