Author Topic: Sony hdr-as15  (Read 8833 times)
Offline azoran
Sony hdr-as15
« on: February 05, 2013, 01:44:54 PM »
Posle duzeg razmisljanja da li da kupim neki model Gopro kamere o kojima je bilo puno prica i kod nas na forumu a i na netu,ili neke alternative kojih je sve vise na trzistu odlucio sam se za ovo drugo.Tako da sam kupio Sony hdr-as15 sledecih karakteristika:
Waterproof-To 60 m with waterproof housing-Shockproof-Yes-Dustproof-Yes
Sensor-1/2.3" (7.77 mm) back-illuminated Exmor R CMOS sensor-BIONZ image processor
Pixel Gross-16800K pixels (16:9)-Effective Pixels-11900 pixels (16:9)
Color Filter System-RGB primary color filters-Lens Type-Carl Zeiss Tessar Lens
Aperture-F2.8,Focal Length (35 mm Equivalent)-15.3 mm-Minimum Focusing Distance- 30 cm
Angle of View-170° (without SteadyShot); 120° (with SteadyShot),Focal Distance-2.5 mm (21.3 mm with SteadyShot Mode Active)
Memory Stick Micro; MicroSD/SDHC (Class 4 or higher)
JPEG-Still Image Max Resolution-2MP-Video Format-MPEG4-AVC/H.264
Video Resolutions-1920 x 1080/30p (HQ)-1280 x 720/30p/60p/120p (STD/SLOW/SSLOW) 640 x 480/30p (VGA)
Movie Recording Rate (Average Bit Rate / VBR)-16 Mbps (HQ),24 Mbps (SSLOW)-12 Mbps (SLOW)-6 Mbps (STD)-3 Mbps (VGA)
Audio Format-MPEG-4 AAC-LC (2ch)-Built-In Microphone-Built-In Speaker
Shutter Speed-1/30-1/10,000,Metering Modes-Multi-Segment,Exposure Settings-Auto,Noise Reduction-Yes,White Balance Mode-Auto,Minimum Illumination-6 lux,Backlight Compensation-Yes (auto)
Gain Control-Auto,Wi-Fi-Yes (802.11 b/g/n 2.4 GHz band),HDMI Output-Yes (micro),USB Ports-Yes (micro-B USB 2.0),BRAVIA Sync-Yes,Microphone Input-Yes (stereo mini-jack),Image Stabilization-SteadyShot with Active Mode
Interval Recording-Yes (5, 10, 30 or 60 sec)
Power Consumption-1.7W,Power Requirements-3.6V (battery pack),Battery Type-NP-BX1 ,Charging Time-4.1 hrs
Dimensions (WxHxD)-1.0 x 1.9 x 3.2" (24.5 x 47 x82 mm),Weight (Camera Only)-2 oz (65 g)
Sadrzaj kutije je sledeci
Za razliku od Goproa koji u svom osnovnom pakovanju ima vise dodataka,Sony se bas nije pretrgao sa osnovnim pakovanjem,ali zato kao opcija postoji jako mnogo dodataka kojih kod nas nazalost jos uvek nema u prodaji.
Prvi utisak u dodiru sa kamerom je da je vrlo kvalitetno uradjena ,plastika nema krckanja i sve lepo lezi na svom mestu.
Vodootporno kuciste na prvi pogled izgleda jako dobro,ali njegovu pravu namenu  i kvalitet cu znati tek po njegovom potapanju u neku  vodu.
Pre nego sto sam odlucio da podjem sa podesavanjima kamere uzeo sam uputstvo koje je doslo u kutiji 4e ,i prvo razocarenje :sljus uputstvo je napisano na papiru velicine postera i na moje razocarenje nicemu ne sluzi.Sreca da su podesavanja za kameru vrlo prosta ptako da nije bilo narocitih problema oko setovanja same kamere tako da je sve proradilo iz prve.
Da bi kameru povezali sa PC potrebno je skinuti program Playmemories home,koje lako mozete naci na netu.Prilikom prvog povezivanja sa racunarom automatski su prebaceni prvi inicijalni snimci koje sam napravio dok sam podesavao kameru.Klik na play i moje odusevljenje  (:sok:) kvalitetom snimka u sobnom osvetljenju.Kamera u sebi ima ugradjenu stabilizaciju koja svima nama hvali manje-vise tokom nasih letova i snimaka,a koja stvarno radi svoj posao u potpunosti.Prve snimke kamere cu okaciti prvom prilikom kada ih budem napravio u spoljasnim uslovima. pa cemo moci da ih uporedjujemo sa konkurencijom (yay)
Evo jos nekih slika kamere
Posto kamera ima ugradjen wifi odlucio sam da probam i tu funkciju na delu.Naravno u uputstvu koje je doslo uz kameru ni reci o tome,onda sam se setio da je  prilikom kacenja na pc preko usb porta prijavio dva foldera jedan je bio folder mikro sd kartice a drugi je bio sa internom memorijom kamere.Listanjem tog foldera nasao sam pdf fajl u kome je bilo uputstvo za kameru koje je licilo na uputstvo  (yay).Takodje postoji podfolder info u kome su smesteni podaci za sidd i wireless password ,sto smatram vrlo korisnim.Elem da bi ste mogli da koristite funkcije wifi potrebno je skinuti program (ios,android)koji se zove Playmemories mobile.Odlaskom na market novo neprijatno iznenadjenje nas region nije podrzan za trazenu aplikaciju,odem na Sonijev sajt da se obratim za pomoc,oni traze da se prvo registuje proizvod,novo iznenadjenje Proizvod nije podrzan za vas region.
Totalno zbunjen ne mogu da shvatim da se proizvod pojavio u prodaji u Srbiji  a da za njega apsolutno nema podrske,smatram ovo veoma velikim propustom zastupnistva za Srbiju,jer na ovakav nacin samo prave negativnu kampanju.
Naravno sledi tumarnje po netu u nacinu pronalazenja resenja,posle poseta nekih foruma dodjem do linka ka Sonijevom sajtu u Kini na kojem gle cuda postoji link ka aplikaciji,vodjen nekom intuicijom gde i sta kliknuti posto ne znam Kineski, uspem da skinem aplikaciju i instaliram je na telefon i tab.Na tabu je sve proradilo iz prve ruke,doduse postoji procedura sta i kada upaliti ali o tome drugi put.Dok je na telefonu bilo malo problema vezano za neka podesavanja na telefonu(Samsung S3),ali je na kraju i tu sve bilo kako treba.
Posle tolikih iznenadjenja i razocarenja mogu vam reci da wifi kontrola radi odlicno i da je kasnjenje veoma malo oko 1 do 2 sec.Koliki je domet wifi jos ne znam posto ga nisam testirao napolje,o tome uskoro.Sve u svemu prvi utisci su dobri i mislim da se konacno pojavljuje konkurencija Gopro-u sto ce naravno biti dobro za sve nas.
Re: Sony hdr-as15
« Reply #1 on: February 05, 2013, 02:03:57 PM »
Odlicno, napokon neko da odstupi od gopro-manije koja ruku na srce vise nije ni realna.
Ako planiras (a verujem da da) da kacis kameru na model ima mnogo aerodinamicniji oblik od Gopro-a, sto je veliki plus.
Mozda sam negde propustio, koja je bila cena?
Offline azoran
Re: Sony hdr-as15
« Reply #2 on: February 05, 2013, 02:26:29 PM »
Prevashodno sam je zbog toga i kupio(kacenje na model) ,mozda bude nasla namenu kada odem na more ili na neko jezero.Cenu nisam naveo a kostala je 315 evra.
Offline mihajlo
Re: Sony hdr-as15
« Reply #3 on: February 12, 2013, 03:17:27 PM »
Gde je zapelo.Ima li nekih snimaka ili zapazanja na ovu kameru  ;)
Offline azoran
Re: Sony hdr-as15
« Reply #4 on: February 12, 2013, 03:38:44 PM »
Nikako da nadjem vremena za snimanje,napravicu neki snimak iz ruke ili auta pa ih kacim.
Offline Baky
  • Ljubav preko žice ♪♫
Re: Sony hdr-as15
« Reply #5 on: February 17, 2013, 12:46:03 PM »
Ovo je odlična kamerica, cena kod nas je dranje kao i uvek :-\
Oblik je odličan za ugradnju na avion.
Re: Sony hdr-as15
« Reply #6 on: February 18, 2013, 09:26:16 AM »
Offline svrco
Re: Sony hdr-as15
« Reply #7 on: March 19, 2013, 08:31:49 PM »
Zorane podeli jos koji utisak o kameri sa nama, ja sam se naostrio za nju :big smile
Offline azoran
Re: Sony hdr-as15
« Reply #8 on: April 03, 2013, 10:18:32 AM »
Posle duzeg hvatanja prasine i nekoriscenja kamere ,stariji sin je napravio neke snimke sa montiranom kamerom na svom autu.
Ima nekoliko snimaka iz prve ruke koji dosta obecavaju.
Evo jednog snimka po uglom od 170 stepeni gde je antishake iskljucen
Na ovom snimku je ugao snimanja 120 stepeni
Ugao snimanja 120 stepeni antishake ukljucen ,ali videcete da je teren bas neravan
