Author Topic: Hitec Aurora 9 +Reciver Optima 7 + batery 1300 mA 350EUR  (Read 21450 times)
Offline vpilic
    • http://www.rcsrbija.rs/
« on: February 07, 2013, 11:01:18 PM »
   Hitec is proud to introduce our new flagship radio, the Aurora 9. The Aurora 9 is a “pure digital” 2.4GHz system for that “connected” feeling. Featuring a large backlit 5.1 inch touch screen display, 30 Model memory, assignable switches and customizable programming menus, the Aurora is a true 3 in 1 radio with sophisticated programming for sail planes, helicopters and all kinds of power planes. With all these features and a price that can’t be beat, there is no doubt the Aurora 9 will become the radio of choice for the most sophisticated pilots.
Features
Basic Features
    AFHSS 2.4GHz / PPM / PCM Compatible
    Easy to Read 5.1 Inch Wide Backlit Touch Screen
    Customizable Menus
    One-Stop Model Type Setting
    3 Multi-Tasking Digital Trims
    Fully Assignable Control Switch, Knob, Stick and Digital Trims
    Highly Sensitive 8 Ball-Bearing Gimbals with Adjustable Tension
    Full-Sized Comfortable Hand Grips Featuring Top Quality Elastomer
    Selectable Control Stick Mode / Change Hardware without Opening Case
    Power Management System (Adjustable Backlight & Auto Shut-off Time)
    Digital Trim Nano-Adjuster (Approx. 0.025deg per step up to 5deg)
Standard Programming Features
    9 Assignable Control Channels
    3 Model Types (ACRO/GLID/HELI) Programming
    30 Model Memories
    20 Character model name
    8 Flight Conditions with 10 Characters
    Throttle Lock
    Fail-safe
    Channel Function
    EPA
    Dual Rate & EXP*
    Sub-Trim
    Servo Reverse
    Servo Speed (Up to 25 sec in Each Direction)
    Servo Monitor (Monitor & Servo Test)
    8 Programmable Mixes (5 x 2-Point , 3 x 7-Point Curves)**
    Trainer Port
Advanced ACRO Programming
    9 Wing Type (6 Main Wings, 3 Flying Wings)
    5 Tail Type (Main Wing: Normal, V-Tail, Ailevator) (Flying Wing: 1 Servo Rudder, 2 Servo Rudders)
    Quick Model Options Select (Dual Engine, Retracts gear, Airbrake, Fuel mixture)
    7 Point Throttle Curve*
    Throttle Cut
    Idle Down
    Fuel Mixture*
    Airbrake
    Airbrake to Elevator Mix**
    Aileron to Rudder Mix**
    Elevator to Camber Mix**
    Rudder to Aileron Mix**
    Aileron Differential*
    Aileron to Flap Mix**
    Camber Mix**
    Flap Control*
    3 x Gyro Sensitivity (ex: AILE/ELEV/RUDD)*
    Snap-Roll (4-Way Switching Multi Direction)**
    V-Tail**
    Delta Mix**
    Ailevator**
    Advanced GLIDER Programming
    9 wing Type (6 Main Wings, 3 Flying Wings)
    Five Tail Type (Main Wing: Normal, V-Tail, Ailevator) (Flying Wing: 1 Servo Rudder, 2 Servo Rudders)
    Quick Model Options Select (Motor, Retracts Gear, Airbrake)
    Motor Control (Switch on/off)**
    Airbrake
    Launch (Stick Position Auto Cut Function)**
    Camber Mix**
    Flap Control*
    Butterfly**
    V-Tail**
    Delta Mix**
    Ailevator**
Advanced HELI Programming
    6 Swash Types (90° Type: 1 Servo, 3 Servos, 4 Servos; 120° Type: 3 Servos; 140° Type: 3 Servos; 180° Type: 2 Servos
    Quick Model Options Select (Governor, Needle Control, Fuel Mixture)
    7 Point Pitch Curve*
    Throttle Cut
    Gyro Sensitivity*
    Needle Control*
    Swash to Throttle Mix*
    Rudder to Throttle Mix*
    Fuel Mixture*
    Throttle Hold***
    Swash Mix (Swash Rate/Calibration )***
    Revolution Mix*
    Governor (Three Rates)*
* Capable of  a Maximum of 24 rates by 8 flight conditions and 3 switch positions
** Capable of a Maximum of 8 Rates by 8 Flight Conditions
*** Capable of a Maximum of 3 Rates Using 3-Swicth Positions
Kolicine su ogranicene, molim sve zainteresovane da se jave putem maila na prodaja@rcsrbija.rs
