Author Topic: Naza m GPS - da li izlazi nova naza ?  (Read 21684 times)
Offline dino mumi
« on: April 27, 2013, 09:58:39 PM »
Pozdrav.. dobio sam neprovjerenu info. da bi trebala da izadje nova Naza M... Da li ima ko pouzdanu info. da li je ovo istina ili ...dezinformacija...
Offline vpilic
    • http://www.rcsrbija.rs/
Re: Naza m GPS - da li izlazi nova naza ?
« Reply #1 on: April 28, 2013, 03:05:55 AM »
Da izlazi nova Naza  V2 ali moze se ubaciti novi firmware i u staru.
Ja nisam imao problema sa starim ali ima nedelju dana kako sam ubacio novi firmware i umesto trenutne verzije 2.02 koristim 3.03 beta.
Nakon odlicnih rezultata na quadu ubacio sam 3.03 u sve modele koje imam.
Imao sam slucaj pucanja elise na hexi teske oko 3kg i bez problema uspeo sam da sletim. Nikad ranije nisam imao pucanje elise dok je bila starija verzija 2.02 pa nemam pojma kako bi se hexa onda ponasala.
Za koji dan napravicu snimak poletanja i sletanja bez jedne elise.
Hocu da sastavim jedan okto tezine oko 3-4kg. koji ce koristiti Nazu.
Vladimir
What’s new with the NAZA V2 : Firmware and functions
- New attitude stabilization algorithm, provides
better flight performance / maneuverability;
- New flight control performance, provides better flight experience; (flight control is smoother, take-off is easier, and solved the swinging problem when descending at high speed.)
- Support for Octo-rotor;
- One-motor stopped still can land safely (Hexa-rotor, Octo-rotor)
- Automatic course deviation compensation, reduced the effects of magnetic disturbance; interference around the compass detection & warning;
- Added IMU advanced calibration, error identification and warning, reduced the impact of sensor error to the flight performance
Offline mihajlo
« Reply #2 on: April 28, 2013, 10:11:15 PM »
 vpilic
Gde moze da se nabavi 3,03 verzija za nazu
Offline vpilic
« Reply #3 on: April 29, 2013, 12:50:26 AM »
Zvanicno jos nije pustena   (fiu)
Poslacu ti na PM uputstvo kako da ubacis 3.03
Pozz
Vladimir
Offline dino mumi
« Reply #4 on: April 30, 2013, 01:32:47 PM »
Koliko sam te skontao Vladimire neće biti razlike u vanjskom izgledu i dr u sadašnjoj u novoj NAZI osim novih i poboljšanih programa... Jel imaš kakav link za ovu novu Nazu ili to možda kao Trgovac imaš info. unaprijed... Hvala
Offline vpilic
« Reply #5 on: April 30, 2013, 04:52:15 PM »
Nemam informacija o izgledu, cim saznam nesto javicu.
Offline cakra
« Reply #6 on: April 30, 2013, 05:17:23 PM »
Nisam NAZA fan ali evo i po koja slika-slucajno nabasah na netu...e sad da li je fake ili?
http://www.rcgroups.com/forums/showthread.php?t=1880602
Offline vpilic
« Reply #7 on: April 30, 2013, 06:53:09 PM »
Dejane video sam to, mislim da nije fake.
Prosledio sam upit za novu Nazu.
Javljam se cim saznam nesto.
Meni stari tip Naze radi odlicno ako nova Naza ima istu ili slicnu cenu a da radi jos bolje od stare zamenicu je ako ne ostajem sa proverenom :)
Offline damirmih
  • Keep it simple.
« Reply #8 on: May 01, 2013, 07:30:10 PM »
Ukoliko vam nije tesko, posaljite I meni link ka 3.03 software-u. Hvala unapred.
Keep it simple.
Offline r-xx
« Reply #9 on: May 02, 2013, 08:29:40 AM »
    Ubacih sinoc 3.03 i ne mogu verujem, stavio sam u moje tri naze i sve probao, kazhem bruka... Toliko je drastichno poboljshanje da ovo nije normalno, ja brutalno letim i ovo brutalno dobro radi.. Mislim da necu kupiti woo jer mislim da od ovog nema bolje...
                   (pijemo) (pijemo) (pijemo)         (<--) (<--) (<--)      (<--) (<--) (<--)
Offline vpilic
« Reply #10 on: May 02, 2013, 11:15:11 AM »
damirmih poslao sam ti PM
Napominjem da verzija 3.03 beta jos uvek nije zvanicno pustena od DJI, kad izadje zvanicna  verzija moguce  da ce biti jos bolja od ove ili bar ista :)
Ja sam takodje ubacio u sve quadove i u par hexi, do sad nakon duzeg testiranja nisam imao problema. Sve radi odlicno.
Offline vpilic
« Reply #11 on: May 02, 2013, 03:22:36 PM »
Mi o vuku a vuk...  :big smile
Malo pre dobio sam mail da je pustena u prodaju nova Naza M V2.
Kupovinom PMU V2 i ubacivanjem novog firmware stara Naza imace iste funkcije kao nova.
"You can buy Naza-M PMU V2 and install firmware upgrade , so that you can get the same function as the Naza-M V2 version"
Vise:
http://www.dji-innovations.com/product/naza-m-v2/
Offline vpilic
« Reply #12 on: May 02, 2013, 10:22:34 PM »
PRILIKOM UBACIVANJA VERZIJE 3.03, OBAVEZNO SKINITE ELISE!!!!
djbojan-u su se upalili motori prilikom ubacivanja firmwara i elisa ga dobro opalila po prstima.
Offline damirmih
  • Keep it simple.
« Reply #13 on: May 03, 2013, 04:54:01 PM »
Hvala najlpese, ispeo sam ubaciti verziju 3 softvera I kao sto r-xx kaze sada je jos bolja. sve pohvale za DJI sto su omogucili ovo I za prvu verziju naze!
Keep it simple.
Offline banga
    • Modelari Sl. Brod-a
« Reply #14 on: May 03, 2013, 07:20:16 PM »
moze i meni upute kako ubaciti 3,03 i gdje skinuti.
ujedno koje prednosti vidite u odnosu na zadnji dji firmware jer meni naza leti savrseno davao sam cak model pocetnicima tj ljudima koji u zivotu nisu vidjeli a kamoli drzali stanicu u rukama te nisu imali nikakvih problema
Samo je nebo granica
