Author Topic: zna li neko  (Read 4581 times)
zna li neko
« on: August 18, 2013, 08:59:55 PM »
Imam EDF 64mm  sa motorom 2853, KV 4800, zna li neko njegove podatke, dozvoljeni napon kao i struju koju vuče. Ja nemogu ništa valjano da pronađem.  mmmm
Re: zna li neko
« Reply #1 on: August 18, 2013, 10:09:49 PM »
Vidi ovde nesto Kume...
EDF 64 Ducted Fan W/ 2853 290W 4800KV Brushless Motor SAME with SAPAC brand
PAIR WITH  "BLACK TORNADO" MOTOR FOR DUCT, THE DUCT WILL BE MORE EFFICIENT
Note,it come without SAPAC Brand logo,but it's 100% same with SAPAC Brand,it made by The same supplier.
-Duct: 64mm
-Duct length: 42mm
-Weight: 28g (Fan)
-Fitting Motor: 20mm grade OD. Diameter of Axle 3mm, Innerrunnner or outrunner motor
-Rotor Blade: High tensile and high recision 6 blade rotor
-Max RPM of Rotor Blade: 60000 RPM
Weight: 109g/3.82oz (motor and Ducted Fan)
Voltage: 3S lipo
ESC recommend: 40A-60A
Motor size (mm) 27.7X67
Maximum scurrent: (A) 55A
Shaft diameter: (mm) 3.0MM
Noload current :(A) 2.8A0.2A
Motor Weight: (g) 80g
Internal Resistance (mΩ) 19.0/18.4/18.8
Power (W) 290W
Thrust (g) 550g -800g
KV (rpm/V) 4800
Including:-1 x Ducted fan W/ Brushless motor
Re: zna li neko
« Reply #2 on: August 19, 2013, 06:32:49 AM »
Kumašine svaka čast, to je to. Sada znam tačne podatke. Nisam bio siguran i tražio sam po netu, ali Ti ga ubode od prve.  (pijemo)  4e
Vidimo se u LeskOvac,  Pozdrav
Re: zna li neko
« Reply #3 on: August 19, 2013, 07:40:43 AM »
Bog je na nebu,a na zemlji je kum!  :_D
