Author Topic: Pomoc za setup  (Read 13714 times)
Offline mad_mangod
  • Goran Nis
Re: Pomoc za setup
« Reply #15 on: February 10, 2014, 05:07:24 PM »
E sad sam totalno zbunjen  ") ") ")....
Sa jedne strane ako kupim ovakav setup
Znaci nesto ovako
http://www.hobbyking.com/hobbyking/store/__18166__Turnigy_Aerodrive_SK3_3548_700kv_Brushless_Outrunner_Motor.html
ili
http://www.hobbyking.com/hobbyking/store/__16231__NTM_Prop_Drive_35_48_Series_900KV_815W.html
sa 4s baterijom koji bi tu prop 13x8 ili veci?
neceda se baci, a sa druge imam I glow motor
od 7.5cm3 ali nemam auspuh za njega pa ne znam sta mi je za ciniti.  :sljus
Biti ili (ne)biti,
pitanje je koga.
Goran
YU1SIS
Niš
Re: Pomoc za setup
« Reply #16 on: February 10, 2014, 06:25:37 PM »
Kupi DLG i batali te motore hehehe lol
Offline mad_mangod
  • Goran Nis
Re: Pomoc za setup
« Reply #17 on: February 10, 2014, 10:12:02 PM »
Odgovara. Pise ti u specifikaciji motora kolika je maksimalna struja
Specs:
Model: NTM Prop Drive Series 2826 1350kv
Kv: 1350rpm/v
Poles: 3
Motor Wind: 14T
Max current: 18A
Max Power: 227W @ 11.1V (3S) / 302W @ 15V (4S)
Shaft: 3mm
Weight: 56g
ESC: 25~30A
Cell count: 3s~4s Lipoly
Bolt holes: 16mm & 19mm
Bolt thread: M3
Connection: 3.5mm Bullet-connector
Prop Test Data:
8x3.8 - 11.1V / 158W / 14.2A / 0.736kg thrust
8x3.8 - 14.8V / 310W / 21A / 1.1kg thrust
a ESC ti je od 30A tako da je to ok.
Biti ili (ne)biti,
pitanje je koga.
Goran
YU1SIS
Niš
Re: Pomoc za setup
« Reply #18 on: February 11, 2014, 12:29:20 AM »
@ScipioMject
Da li za ovaj motor http://www.hobbyking.com/hobbyking/store/__21479__NTM_Prop_Drive_28_26_1350KV_302W.html odgovara sledeci ESC http://www.hobbyking.com/hobbyking/store/__2164__TURNIGY_Plush_30amp_Speed_Controller.html , a ako ne odgovara molim da mi preporucite odgovarajuci.
Motor je dobar za tvoje modele.
Ako za motor u opisu piše Max. corrent 18A onda je dovoljan esc od 18-20A.
http://www.hobbyking.com/hobbyking/store/__11615__Turnigy_AE_20A_Brushless_ESC.html
Ne treba veći, jer su teži i skuplji. Koliko će motor vući struje, zavisi od Kv vrednosti motora, prečnika i koraka elise i napona napajanja. Naravno, treba birati takvu elisu i napon napajanja sa kojom neće preći 18A na max gasu ako se želi duže vreme leteti tako. Ima sporih i brzih elisa, pa je moja preporuka za tvoje modele sledeća.
Za delta krilo.
Sa 3 ćelije LiPo će vući 900g sa elisom Slow fly 9x4.7"
Za F22
Sa 3 ćelije LiPo će vući 930g sa elisom APC Sport 9x5" ako stane u otvor, (maks. brzina 66km/h)
ili  bolje sa 4 ćelije LiPo će vući 1100g sa elisom APC sport 8x4"  (maks. brzina 79km/h)
Sa svim navedenim elisama će vući oko 18A na maks. gasu.
Sve se može proveriti sa kalkulatorom  http://www.ecalc.ch/
Predlažem da ga proučavaš...
« Last Edit: February 11, 2014, 12:42:50 AM by tibeteagle »
Re: Pomoc za setup
« Reply #19 on: February 11, 2014, 04:30:00 PM »
Da li si i ovo naručio za motor NTM Prop Drive 28-26 1350KV ?  mmmm
http://www.hobbyking.com/hobbyking/store/__16719__NTM_Prop_Drive_28_Series_Accessory_Pack.html
Kod ovih tipova je jedino potrebno posevno naručiti.  :( Ako nisi, kupi i javi im da ti stave u isti paket. Od elisa je dobro imati barem jednu rezervnu.
