Author Topic: NightFox Quadcopter  (Read 11533 times)
Offline zbabic
NightFox Quadcopter
« on: October 25, 2014, 10:06:21 PM »
Posto idea ne fali, rekoh, jednu da pokusam da realizujem.
Znam da bi bilo prakticnije kupiti frame, ali uzivam dok pravim model, tako da se ipak odlucih da sam napravim quad, po nekoj svojoj idei.
APM, 40A SimonK ESC, 5000mAh 25C, 12x4.5, RC Timer HP2814(3536)-810KV Multi-Rotor Brushless Motor,
Dijagonala 600 mm, od motora do motora 425mm
Pocetak:
Offline zbabic
Re: NightFox Quadcopter
« Reply #1 on: October 25, 2014, 10:07:11 PM »
Nabavljen je materijal, G10 i aluminijumska kvadratna cev 15x15x1,5 mm
G10 je SaleR precizno iseckao, hvala Sale!
Offline zbabic
« Reply #2 on: October 25, 2014, 10:08:08 PM »
Ploce i cevi ofarbane farbom u spreju.
Offline zbabic
« Reply #3 on: October 25, 2014, 10:09:30 PM »
Elektro radovi,
Offline zbabic
« Reply #4 on: October 25, 2014, 10:10:14 PM »
Raspored bi trebalo da bude ovako nesto
Povezivanje
Offline zbabic
« Reply #5 on: October 25, 2014, 10:11:06 PM »
Postavljen nosac za APM, ESC- ovi ucvrsceni,
Power modul i UBEC postavljeni, pogled od gore
Offline zbabic
« Reply #6 on: October 25, 2014, 10:12:03 PM »
Pogled sa donje strane,
Anti vibro postolje za APM
Offline zbabic
« Reply #7 on: October 25, 2014, 10:12:58 PM »
Toliko se stiglo za sad, nastavak sledi...
Offline zbabic
« Reply #8 on: October 25, 2014, 10:14:54 PM »
Kad sam pokusao postaviti objedinjeno sve, stalno se pojavljuje:
"Forbidden
You don't have permission to access /index.php on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request."
Offline djgorandj
  • www.rcavioni.com
« Reply #9 on: October 26, 2014, 03:30:39 PM »
Ja bi iseko po duzini te plave gumice gde ces montirati apm, dobices bolje performanse kod vibracija, previse je to nateknuto tako kako ga prodaju. 50% otkratim i vec ima smisla. Nemoj samo da preteras. Do recimo nekih 70% max.
Offline zbabic
« Reply #10 on: November 03, 2014, 08:12:47 AM »
Nastavak radova.
Postavljene LED diode
Offline zbabic
« Reply #11 on: November 03, 2014, 08:13:25 AM »
Offline zbabic
« Reply #12 on: November 03, 2014, 08:13:53 AM »
Offline zbabic
« Reply #13 on: November 03, 2014, 08:14:37 AM »
Motori spremljeni
Offline zbabic
« Reply #14 on: November 03, 2014, 08:15:14 AM »
