Author Topic: 3DR X8+ odgovor na dji inspire 1  (Read 5077 times)
Offline motorola_la
    • moj fb :)
« on: November 18, 2014, 02:18:37 PM »
3DR X8+ lansirao novi model kao odg na dji inspire sa cenom od 1350$ :)
http://store.3drobotics.com/products/x8-plus/
Our 3DR workhorse octocopter is equal to any task. With a flight time of 15 minutes and a payload capacity of over 800 grams, the X8+ is the perfect platform for aerial video.
The X8+ includes
Controller with live on-screen flight data
Flight battery and charger
Operation Manual and Flight Checklist
Ground station radio with USD and Android adapters
Specs:
Battery: 4S 14.8V 10,000 mAh 10C
Battery Dimensions: 6.6 in x 2.6 in x 1.4 in (16.7 cm x 6.5 cm x 3.5 cm)
Battery Weight: 803 g
Autopilot hardware: Pixhawk v2.4.5
Autopilot firmware: ArduCopter 3.2
GPS: 3DR u-blox GPS with Compass (LEA-6H module, 5 Hz update)
Ground Station Radio: 3DR Radio v2 (915 MHz or 433 MHz)
Motors: SunnySky V2216-12 KV800 II
Frame Type: X
Propellers: APC Propeller 11x4.7 SF (4), APC Propeller 11x4.7 SFP (4)
Vehicle Dimensions: 13.7 in x 20.1 in x 11.8 in (35 cm x 51 cm x 20 cm)
Payload Capacity: 800 g (1.7 lbs). Additional payload possible up to over 1kg with reduced flight time.
Vehicle Weight with Battery: 2.56 kg (5.6 lbs)
Maximum Estimated Flight Time: 15 min
Select from the options below to customize your X8+:
Frequency: Ground station radios allow you to communicate with your aircraft wirelessly in flight. For the US, select 915 MHz. Frequency regulations vary by country, so consult your local airspace communication authority if you're uncertain which frequency is legal in your area.
Extra propellers: The X8+ includes one set of eight propellers. Select this option to add two extra propellers to your order.
Extra batteries: The X8+ includes one flight battery. Select this option to extra batteries to your order.
Camera gimbal: The Tarot T-2D brushless gimbal uses cutting-edge two-axis stabilization technology to ensure great, stable video in any flight condition. The gimbal comes pre-configured and tuned for a smooth out-of-the-box experience. The kit includes: a pre-assembled Tarot gimbal, a mounting plate, and required cables and hardware.
Case: Select this option to add a travel case for your X8+. Please note that the case ships separately from the X8+.
GoPro HERO: Select this option to receive a Go-Pro HERO3+ Silver with your X8+! Please note that we cannot ship GoPro internationally. When using a GoPro with X8+, please ensure that the WiFi is turned off; this can cause interference between the X8+ and the controller.
