Author Topic: Fpv antene  (Read 47233 times)
Offline Drazen82
Fpv antene
« on: November 15, 2015, 12:32:48 PM »
Mozete li mi pomoc oko odabira istih? Nemam bas iskustva sa njima. Rijec je o antenama za 5,8. Hvala
Offline Birdum_Bardum
Re: Fpv antene
« Reply #1 on: November 15, 2015, 01:45:23 PM »
Iz licnog iskustva(imam ih gomilu), najbolje su se pokazale:
https://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=77911
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=65918
Offline Drazen82
Re: Fpv antene
« Reply #2 on: November 15, 2015, 03:22:00 PM »
Ove druge sam sad narucio. Hvala puno. Jel moguce da pri samom stavljanju antene transmiter ode? Kupo sam neke jeftine.
Offline Drazen82
Re: Fpv antene
« Reply #3 on: November 15, 2015, 03:23:09 PM »
Znaci samo kopcanje. Nisam letio pa da kazem nesto. Vec samo ih probao na kucnom stolu.
Offline goodgod
Re: Fpv antene
« Reply #4 on: November 15, 2015, 04:44:03 PM »
Uzeo sam ovde (oko 12e komplet):
http://rcherobg.com/index.php?route=product/product&path=33&product_id=593
Iznenadio sam se koliko dobro rade.
Offline Asterix
Re: Fpv antene
« Reply #5 on: November 15, 2015, 05:33:13 PM »
Drazen82, sta koristis tj koji imas prijemnik i predajnik za fpv?
Re: Fpv antene
« Reply #6 on: November 15, 2015, 05:53:46 PM »
Transmiter, rekao bih, bilo koji NE SME se ukljucivati bez ANTENE.... odmah CRKNE   !!!
Offline Drazen82
Re: Fpv antene
« Reply #7 on: November 15, 2015, 06:43:00 PM »
Mislim da sam sa antenom, nesmijem tvrditi sad.
Offline Drazen82
Re: Fpv antene
« Reply #8 on: November 15, 2015, 06:45:53 PM »
A koristim RCX TS5828 5.8GHz 32CH i
RCX RC832 5.8GHz 32CH
Offline Drazen82
Re: Fpv antene
« Reply #10 on: November 15, 2015, 08:31:23 PM »
Ja sam ove skopcao, i odma je stalo sa radom sve
http://www.myrcmart.com/58ghz-fpv-antennas-straight-sma-female-p-8075.html?osCsid=t3egtkcih9fc6k4ach9jofs0c7
A neznam kako, nove.
Hvala svima na prijedlozima.
Offline zbabic
Re: Fpv antene
« Reply #11 on: November 15, 2015, 08:50:25 PM »
@Drazen82
A zasto ne napravis sam? Nije tesko, a imas kalkulatore na netu  ;namig
Offline matic
Re: Fpv antene
« Reply #12 on: November 15, 2015, 10:14:42 PM »
Ja sam uzeo antene sa ebay
15752-0
Nekako mi se cini da panel antena nije bas dobra nisam radio test sa antenama. Nesvidja mi se kako je napravljena.
15754-1
Sta vi mislite vredi nesto ova antena ili da narucim drugu?
« Last Edit: November 15, 2015, 10:16:40 PM by matic »
Re: Fpv antene
« Reply #13 on: November 15, 2015, 11:19:50 PM »
Stavi pa vidi kako rade.
Ako imaš neki jak predajnik tipa 500-600 mw provozaj kroz neki parkić sa drvećem pa vidi kako izgleda slika.
Ako ne uzmi pa pravi sam. Imaš gomilu tutorijala sa neta i te koje praviš sam budu vrlo često bolje od kineskih.
Ne možda bolje od fatshark ili sličnih brendova ali ne mnogo ni gore.
zgred od tih antena ako ništa možeš iskoristiti konektore i koaksijelni kabal koji ne moraš da lemiš za konektor posle.....
Jednostavno je
Re: Fpv antene
« Reply #14 on: November 15, 2015, 11:41:40 PM »
Uvek proveri konektore pre kupovine antena, kao sto rece Zajko TX(transmitter) bez antene ce odmah da crkne, to vazi isto ako stavis antenu sa pogresanim konektorom.
