Author Topic: PHANTOM 4  (Read 7206 times)
Offline azoran
PHANTOM 4
« on: March 01, 2016, 08:13:36 PM »
« Last Edit: March 01, 2016, 08:20:41 PM by azoran »
Offline azoran
Re: PHANTOM 4 unboxing
« Reply #1 on: March 01, 2016, 08:22:03 PM »
Offline azoran
Re: PHANTOM 4 karakteristike
« Reply #2 on: March 01, 2016, 08:29:14 PM »
Weight (Including Battery)   1380 g
Max Ascent Speed   6 m/s (Sport mode)
Max Descent Speed   4 m/s (Sport mode)
Max Speed   20 m/s (Sport mode)
Max Service Ceiling Above Sea Level   19685 feet (6000 m)
(Software altitude limit: 400 feet above takeoff point)
Max Flight Time   Approx. 28 minutes
Operating Temperature Range   32° to 104° F (0° to 40° C)
Satellite Systems   GPS / GLONASS
Hovering Accuracy   Vertical:
+/- 0.1 m (when Vision Positioning is active) or +/-0.5 m
Horizontal:
+/- 0.3 m (when Vision Positioning is active) or +/-1.5 m
Obstacle Sensing System
Obstacle Sensory Range   2 - 49 feet (0.7 - 15 m)
Operating Environment   Surface with clear pattern and adequate lighting (lux > 15)
Camera
Sensor   1/2.3” Effective pixels:12 M
Lens   FOV ( Field Of View ) 94° 20 mm ( 35 mm format equivalent ) f/2.8 focus at ∞
ISO Range   100 - 3200 ( video ) 100 - 1600 ( photo )
Electronic Shutter Speed   8 s to 1/8000 s
Max Image Size   4000×3000
Still Photography Modes   Single shot
Burst shooting: 3 / 5 / 7 frames
Auto Exposure Bracketing ( AEB ): 3 / 5 bracketed frames at 0.7 EV Bias
Time-lapse
HDR
Video Recording Modes   UHD: 4096×2160 (4K) 24 / 25p
3840×2160 (4K) 24 / 25 / 30p
2704×1520 (2.7K) 24 / 25 / 30p
FHD: 1920×1080 24 / 25 / 30 / 48 / 50 / 60 / 120p
HD: 1280×720 24 / 25 / 30 / 48 / 50 / 60p
Max Video Bitrate   60 Mbps
Supported File Systems   FAT32 ( ≤ 32 GB ); exFAT ( > 32 GB )
Photo   JPEG, DNG ( RAW )
Video   MP4 / MOV ( MPEG – 4 AVC / H.264 )
Supported SD Cards   Micro SD, Max capacity: 64GB. Class 10 or UHS-1 rating required
Operating Temperature   32° to 104° F ( 0° to 40° C )
Vision Positioning System
Velocity Range   ≤10 m/s ( 2 m above ground )
Altitude Range   0 - 33 feet (0 - 10 m)
Operating Range   0 - 33 feet (0 - 10 m)
Operating Environment   Surfaces with a clear pattern and adequate lighting (lux > 15)
Remote Controller
Operating Frequency   2.400 GHz to 2.483 GHz
Max Transmission Distance   FCC Compliant: 3.1 mi ( 5 km );
CE Compliant: 2.2 mi ( 3.5 km )( Unobstructed, free of interference )
Battery   6000 mAh LiPo 2S
Transmitter Power ( EIRP )   FCC: 23 dBm; CE: 17 dBm
Operating Voltage   7.4V @ 1.2A
Intelligent Flight Battery ( PH4 - 5350 mAh -15.2 V )
Capacity   5350 mAh
Voltage   15.2 V
Battery Type   LiPo 4S
Energy   81.3 Wh
Net Weight   462 g
Operating Temperature   14° to 104° F ( -10° to 40° C )
Max Charging Power   100 W
Offline Saka
  • Leteti leteti i samo leteti
Re: PHANTOM 4
« Reply #3 on: March 01, 2016, 09:27:56 PM »
Zato je pala cena Phatnoma 3 za duplo skoro na nekim online prodavnicama.
Pošto znam kakva je 3 i šta sve može  mogu da zamislim ovaj bezobrazluk, realno ovo nije za hobiste ali da leti za sve pare...leti  (<--)
Offline miticmiroslav
    • www.mmdstudio.net
Re: PHANTOM 4
« Reply #4 on: June 16, 2016, 11:20:53 PM »
Igrao sam se mnogo sa ovom igrackom u poslednje vreme.
Leti napolju ali bogami i unutra i to jako dobro.
Sistem za izbegavanje prepreka je odlican.... mogu da zamislim samo kakv ce novi inspire da bude....
Offline gizmo
Re: PHANTOM 4
« Reply #5 on: June 16, 2016, 11:52:28 PM »
Po meni nema mnogo smisla sto su te senzore za izbegavanje prepreka stavili samo sa prednje strane. Uglavnom ih lupaju neiskusni ljudi koji lete tako sto gledaju
live sliku na ekranu i ako ispred ima neka prepreka videce je. Problemi nastaju kada lete u stranu ili unazad pri cemu opet gledaju sliku na ekranu, ali ne vide da li ima
nekih prepreka okolo, a nema ni senzora da sprece lupanje.
Offline Gatti.Gatozza
  • up the irons!
Re: PHANTOM 4
« Reply #6 on: June 17, 2016, 09:56:32 AM »
Pa mora nešto da se ostavi za Phantom 5.
Offline uroskee
Re: PHANTOM 4
« Reply #7 on: June 17, 2016, 05:38:06 PM »
Bolje da su stavili dva senzora bocno.
