Author Topic: QX90 - dali ga neko ima  (Read 116123 times)
Offline srkipa
Re: QX90 - dali ga neko ima
« Reply #182 on: June 16, 2017, 08:59:55 AM »
Neznam zasto izbacuje tako
https://www.banggood.com/Racerstar-Racing-Edition-1103-BR1103-8000KV-1-2S-Brushless-Motor-Dark-Blue-For-50-80-100-Multirotor-p-1113139.html?rmmds=search
Evo ga sad. Na 2s bateriji i kingkong 65mm 89g trust 4.66a to i neki frame 100mm extra kombinacija.
Offline mikijus
Offline brankelot
« Reply #184 on: June 16, 2017, 11:19:52 AM »
Zavidim vam .Lep provod  (pijanoo)
Offline mikijus
« Reply #185 on: June 16, 2017, 08:52:43 PM »
Danas se koliko ja znam letelo na dva mesta u Beogradu....
Na uscu kod muzeja ......Andrej i ekipa sa velikim (250) i
ekipa sa micro quad-ovima na topcideru...dva super druzenja    :)aplauz :)aplauz :)aplauz
probao sam srkipa  Eachine Racer 130 i odusevio se  :) :) :)
sve moze ko qx90 :)
a evo i skijev video
« Last Edit: June 16, 2017, 09:13:38 PM by mikijus »
« Reply #186 on: June 16, 2017, 10:16:54 PM »
Airmode može da bude aktiviran i u akro, angle ili bilo kom drugom modu.
airmode nije način stabilizacije i korišćenja žiroskopa nego samo iskorišćavanje komandi pri malim obratajima gasa.
Offline srkipa
« Reply #187 on: June 16, 2017, 11:46:46 PM »
Letelo se danas lepo na Topcideru neki su prolazili kroz gejtove a neki smo ih i rusili  (fiu)
evo malo slika micro druzine a i jedan kombinovan snimak.
« Last Edit: June 17, 2017, 12:45:43 AM by srkipa »
Offline srkipa
« Reply #188 on: June 17, 2017, 12:00:17 AM »
Evo i snimak  recer-a 130 u freestyle ali na samom kraju baterije
« Last Edit: June 17, 2017, 12:44:59 AM by srkipa »
Offline mikijus
« Reply #189 on: June 17, 2017, 12:05:28 AM »
samo ja ne znam flipove :)
« Last Edit: June 17, 2017, 12:17:32 AM by mikijus »
Offline srkipa
« Reply #190 on: June 17, 2017, 12:49:48 AM »
I da dodam da recer-a niko nije leteo preko 75-80% gasa
Offline Asterix
« Reply #191 on: June 17, 2017, 01:29:08 AM »
Menjaj tu fpv antenu ili probaj da stavis neki micro lc filter otice ti oci  :big smile
Offline srkipa
« Reply #192 on: June 17, 2017, 01:35:22 AM »
Antena jeste losa ali u toku leta nema toliko smetnji a i mi smo na drugoj strani tih drveca pa tako da su smetnje najvise staticke od samih krosnji ali u svakom slucaju treba da se zameni antena
Offline Asterix
« Reply #193 on: June 17, 2017, 01:40:25 AM »
Tebi treperi i kada miruju tj kada je pao, zbog toga ti kazem nesto ne stima tu :big smile
« Reply #194 on: June 17, 2017, 07:37:55 AM »
Kada je pao bio je okrenut naopačke i zabijena natena u travu zato je snimak zezao, lc filter ti treba kad se pojave horizontalne linije pri dodavanju gasa tj kada esc-ovi prave smetnje. Ugavnom sva napajanja na današnjim pločama imaju lc filtere tako da više nije potrebno zezati se sa tim. i onako se sastoji od 2-3 komponente što je rešivo i što su svi uradili (proizvođači).
Inače na DVR-u koliko sam shvatio i koliko su mi ljudi pričali daleko više smetnji snimi nego što ih ti vidiš ili uočiš dok letiš.
Džaba tu i dobra antena kada su ti mikro TX-ovi blagi užas. a  i rade na 25 mW što bi trebalo da pojača probojnost u zatvorrenom prostoru i  gustišu ali na tarabi piše jedno a u stvarnosti je drugo na žalost. u ostalom sve je to ok jer treba da budemo zadovoljni šta su do sada uspel da spakuju u tako mali prostor tih quadova i da pri tome koliko toliko radi posao.
DO pre 3-5 godina niko nije ni sanjao da će biti ovako neka zezancija...
