Author Topic: Ojha  (Read 11106 times)
Offline Fly_boy
    • www.diair.net
Ojha
« on: June 09, 2009, 01:31:12 AM »
Moje ime je veljko Ivancevic, moje kolege modelari zovu me mrca.
Bavim se Vazduhoplovstvom radim u Montenegro Airlines-u tenutno zaposljen kao kopilot.
Zivim i radim u Podgorici.
Bavim se modelarstvom kao hobijem i smatram da nema nista bolje od ovog hobija da zaboravis probleme i nezgode koje se desavaju svakodnevno.
Ups ima jos i pivo koje je sastavni dio modelarstva.(kad se zavrsi letjenje naravno ide se na pivo ukoliko se ne radi sjutra. ()-() )
Evo i mog malog hangara
Toliko od mene i pozdrav!
« Last Edit: June 09, 2009, 01:35:00 AM by Fly_boy »
Ivancevic Veljko (Mrcha) live's for today because yesterday's over and tomorrow may never come!
Offline Fly_boy
    • www.diair.net
Ojha
« Reply #1 on: June 09, 2009, 01:38:18 AM »
I ova dva su u izradi. Pozz
Offline Fly_boy
    • www.diair.net
Re: Ojha
« Reply #2 on: June 09, 2009, 02:37:03 AM »
Evo specifikacija
F-4U Corsair 120 (CMPro)
Wing Span         1920mm
Weight              5100g ~ 5300g
Length              1320mm (52'')
Wing Area          57.6 dm2
Wing Loading.     90 g/dm2
Airfoil                Naca-2515
Engines             2c 90-108, 4c 120
Radio                5-6 channels, 6-7 servos
Spitfire MK2 90   (CMPro)
Wingspan     1800 mm
Weight              4.5~4.7 kg
Length              1420 mm
Wing loading      74~77 g/dm2
Wing area          61 dm2
Airfoil                NACA 2415
Engine
2 stroke               .91~1.08
4 stroke            .91~1.20
Radio                channel 5~6, servos  5~7
Extra 300s 90    (Graupner)
Wingspan          1600 mm
Length             1140 mm
Wing area         42,4 dm²
Weight approx.  3000 g
Extra 300s  EP (The World Models)
Wing Span      1030 mm
Wing Area       18.6 sq mm
Weight           750 g
Length            880 mm
Radio             4-channel radio, 4 micro servos,
Motor             Outrunner w/ Propeller Adaptor, 20A Brushless ESC, 3 cells 11.1V 2100mAh Li-Po battery & charger
Cessna 182 140 (CMPro)
(Nije letan)
Wingspan        2100mm
Length            1600mm
Weight           5.1~5.3 kg
Loading          98~102 dm/2
Airfoil             AKM 2412
Wing Area       52 dm/2
Radio Control   5 Ch 7 Servos
2 Stroke Engine   108~120
4 Stroke Engine   120~140
Stari dvokrilac (Rucni rad)
(Nije letan)
Nepoznate
Gemini EP        (Multiplex)
Wingspan       920 mm
Overall fuselage length 920 mm
Weight          840 g
Wing area      34 dm²
Loading         22 g / dm²
Calmato 40    (Kyosho)
Length           1300mm
Wingspan       1600mm
Weight          2400-2500g
Wing Area      43.0dm²
Airfoil           Original semi-symmerty
Motor            2 STROKE 40-46
Radio            4-5 channel 4 Servos
Pozz!
« Last Edit: June 09, 2009, 02:49:30 AM by Fly_boy »
Re: Ojha
« Reply #3 on: July 02, 2009, 03:07:45 PM »
Pozdrav!
Ekstra ti je Cessna! Kao model,jako mi se sviđa... Tokom zime nameravam da kompletiram za sebe jedan veći model (1700 mm raspon krila) i jako se dvoumim da li da to bude Cessna ili Mentor. Naravno elektro konfiguracija... I ćerkica uči na jedrilici pa mi Mentor odgovara zbog kuke za vuču jedrilice, jer ako nauči redovno,možemo uvežbati jedan interesantan "program"  (<--) .... Kakvi su utisci sa Cessnom?
Offline Fly_boy
    • www.diair.net
Re: Ojha
« Reply #4 on: July 02, 2009, 05:40:09 PM »
mislim da nisi dobro procitao gore pise u karakteristikama da cessna nije letna sto znaci nisam ni namjeravao da je letim. sve jedno
mogu ti pomoci
pitaj coku za utiske jer je on letio tu istu cessnu od jednog njegovog prijatelja a ja sto mogu da ti kazem to je samo sa strane publike koja je gledala taj avion kako leti
mislim da je model super za letjenje ili je to coka morao da radi vjezbe za prste da to izgleda sve kako treba ;)
pozz
Offline coka
Re: Ojha
« Reply #5 on: September 18, 2009, 09:54:20 PM »
  Flyboy, prelep ti je onaj stari dvokrilac. Da li je to ARF od SEAGUL-a, pa doradjen ili je sve rucni rad? Da li je to ikada letelo i ciji je?  Takodje, ko ga je pravio?
Offline coka
Re: Ojha
« Reply #6 on: September 19, 2009, 09:46:35 PM »
Offline Fly_boy
    • www.diair.net
Re: Ojha
« Reply #7 on: September 24, 2009, 05:29:30 PM »
molio bih moderatore da pobricu sve osim slika modela i karakteristika i ako bi kako moglo da se zakljuca post
unaprijed hvala
