Author Topic: MIG-29 by Flyer  (Read 90159 times)
Offline mariomdw
Re: MIG-29 by Flyer
« Reply #45 on: January 11, 2014, 02:02:27 PM »
https://www.youtube.com/watch?v=2P9aAMiP5KE&feature=youtu.be unatoc tezini od 710gr ovo cudo leti i na 40% gasa :D
Offline firebird
  • Bojan , Kragujevac
Re: MIG-29 by Flyer
« Reply #46 on: January 11, 2014, 02:11:26 PM »
Pa slusaj, velike su mu nosece povrsine pa zato i leti i to bas lepo koliko sam video, bravo...
Offline mariomdw
Re: MIG-29 by Flyer
« Reply #47 on: January 11, 2014, 02:42:24 PM »
Hvala na konplimentu,stvarno nisam ocekivo da ovako lijepo leti idemo sada jos malo uzivat u ovom vremena i letit :D
Offline dovlasmith
Re: MIG-29 by Flyer
« Reply #48 on: January 11, 2014, 03:01:41 PM »
Super leti, cestitam! :)
Offline mariomdw
Re: MIG-29 by Flyer
« Reply #49 on: January 11, 2014, 03:04:49 PM »
Hvala :) ali doso sam do par zakljucaka 1. je da cu morat dodat kfm2 radi hower-a inace nema nista od hower-a jer rus ko rus stalira dosta lako a 2. je da ovaj avion nece bit dobar za akrobacije jer ne moze radit roll (pre mali otkloni na servima a ne zelim ih preopterecivat jer su 9gr plasticna) uz to malo je zafrkano letjet s ruderom ali je super sticat nova iskustva  (yay)
Offline dovlasmith
Re: MIG-29 by Flyer
« Reply #50 on: January 11, 2014, 03:07:36 PM »
Kad kazes "hower", mislis na "lift" (uzgon)?
Offline mariomdw
Re: MIG-29 by Flyer
« Reply #51 on: January 11, 2014, 03:16:50 PM »
sa hower mislim na akrobacijsku figuru kada avion skoro stoji u zraku
Offline dovlasmith
Re: MIG-29 by Flyer
« Reply #52 on: January 11, 2014, 03:27:08 PM »
Ok, nisam znao da konkretno taj model moze to da izvede, pa sam zbog toga mislio da je zabuna u pitanju :)
Offline mariomdw
Re: MIG-29 by Flyer
« Reply #53 on: January 11, 2014, 03:30:03 PM »
ma moze to skoro svaki model ali je na ruskim srednjomotorcima dosta tesk jer stvarno lako padaju u stall
Re: MIG-29 by Flyer
« Reply #54 on: January 11, 2014, 06:46:25 PM »
Video je odličan i svaka čast da si sve sam snimao i letelo.  (thumb) Sviđaju mi se tvoji zadasi na klipu, što ukazuje da si bio pod stresom i adrenalinom, što si muški podneo.  :jaki:
Model je odličan i bez brige, može sve akrobacije da radi pa i roll. Odkloni su OK pa i malo veliki za visinu. Pa ako i ti budeš OK, mislim dovoljno uvežban i miran, moći ćeš da ih probaš.
Za huverovanje je potrebna elisa sa manjim korakom ali duža, ako stane, da ima jak potisak, a da ga ne ubrza naglo. I težište treba pomeriti više nazad. Sa ovim treba malo više vežbati i probati razne režime odklona i ostalo.
Roll probaj tako da izvedeš da je model malo višlje i nos modela prema gore za 45 stepeni i daj potpuni odklon na elerone i ništa više. Posle 2-3 kruga pusti palicu i smiri model. Vremenom ćeš da osetiš koliko treba držati za koliko okreataja. Kasnije probaj sporiji roll sa kompenzacijom visine. Stabilnost zavisi i od toga gde je težište modela visinski. To kod ovako malih pločastih modela nije baš na stredini, pa će se malo bacati pri roll okretanju.
Samo nalred.   ;namig
« Last Edit: January 11, 2014, 06:49:53 PM by tibeteagle »
Offline mariomdw
Re: MIG-29 by Flyer
« Reply #55 on: January 11, 2014, 09:53:09 PM »
hvala najveca,uvijek sam pod stresom kada se ide na maiden ali s vremenom sam se naviko donekle,sto se tice akrobacija ako si gledao vide-e vidio si da sam na f16 savladao sve akrobacije bez problema malo vremena i truda i savladat cu i mig-a tako,evo veceras sam stavio kfm2 tako da sutra ide novi video i vidjet cemo kako ce se ponasat s njim  (pijemo)
Offline rajker
Re: MIG-29 by Flyer
« Reply #56 on: January 12, 2014, 07:35:08 AM »
 :)aplauz :)aplauz :)aplauz Svalka cast  :big smile :big smile :big smile
Offline mariomdw
Re: MIG-29 by Flyer
« Reply #57 on: January 12, 2014, 12:14:19 PM »
Kfm 2 je isproban i stavlja se upravo novi video,i ako je bilo dosta vjetra osjeco sam da mi je avion puno stabilni,zbog vjetra nisam mogo testirat kakav ce bit na niskim brzinama ali bit ce prilik.Novi video se uploada i onda cu ga proslijedit kolegi da izmjeri brzinu s nekim programom koji radi na principu doplera il tako nesta sta ja znam  :big smile
Offline mariomdw
Re: MIG-29 by Flyer
« Reply #58 on: January 12, 2014, 01:41:36 PM »
https://www.youtube.com/watch?v=FNVthKEKH_I&feature=youtu.be prvi prelet 82,14 km/h a drugi prelet 72 km/h  (<--)
Offline mariomdw
Re: MIG-29 by Flyer
« Reply #59 on: January 12, 2014, 02:08:20 PM »
upravo sam si dokazo da ovaj avion i te kako moze radit i roll :D
