Author Topic: parrot-ar-drone  (Read 10065 times)
Offline tihomir
parrot-ar-drone
« on: January 06, 2010, 02:25:41 PM »
Re: parrot-ar-drone
« Reply #1 on: January 06, 2010, 06:58:22 PM »
Auuuu, znam da ovdje dobru ulogu ima i rezija, ali ovo je definitvno mnogo zanimljiva stvar.
S obzirom da dolazi iz Apple-a pretpostavljam da ce biti neka revolucija po tom pitanju cim ga se Kinezi dokopaju.
Re: parrot-ar-drone
« Reply #2 on: April 20, 2010, 11:06:56 AM »
Re: parrot-ar-drone
« Reply #3 on: July 23, 2010, 11:40:12 PM »
Pocela prodaja:
http://www.etamiya.com/shop/ardrone-parrot-iphone-ipod-touch-rc-flying-object-with-wifi-brushless-motor-system-p-90022077.html
A technological first
For the first time, a consumer product encompasses:
A quadricopter made in carbon fiber and high resistance PA66 plastic
MEMS (Micro-Electro-Mechanical Systems) and video processing to ensure a very
intuitive piloting of a radio controlled object
Wi-Fi and video streaming for a modern interface with an iPhone? or iPod touchAR
Images processing software for augmented reality
AERONAUTIC STRUCTURE
High-efficiency propellers(specially designed for the Parrot
AR.Drone)
Carbon-fiber tube structure
MOTORS AND ENERGY
4 brushless motors, (35,000 rpm, power: 15W)
Lithium polymer battery (3 cells, 11,1V, 1000 mAh)
Discharge capacity: 10C
Battery charging time: 90 minutes
FRONT CAMERA: WIDE ANGLE CAMERA
93A° wide-angle diagonal lens camera, CMOS sensor
Encoding and live streaming of images on iPhone
Camera resolution 640x480 pixels (VGA)
Other AR.Drone detection
- Validation of shots fired at enemy drones
- Estimate of distance
- Detection distance: 5 meters(16.4 ft)
3D tag detection
- Positioning of virtual objects
- Calculation of markers of virtual objects
- Detection distance: 30 centimeters to 5 meters (1ft to 16.4 ft)
Video feedback on the iPod touch /iPhone screen
ULTRASOUND ALTIMETER
Emission frequency: - 40kHz
Range 6 meters (19.7 ft) Vertical stabilization
VERTICAL CAMERA: HIGH SPEED CAMERA
64° diagonal lens, CMOS sensor
Video frequency: 60 fps
Allows stabilization even with a light wind
EMBEDDED COMPUTER SYSTEM
ARM9 468 MHz
DDR 128 Mbyte at 200MHz
Wifi b/g
USB high speed
Linux OS   SPECIFICATIONS
Running speed: 5 m/s; 18 km/h
(16.4 ft per second; 11.2 miles per hour)
Weight:
- 380 g with outdoor hull (0.8 pounds)
- 420 g with indoor hull (0.9 pounds)
Flying time: about 12 minutes   DIMENSIONS
With hull:
52,5x51,5cm (20.7 inches x 20.3 inches)
Without hull:
45x29cm (17.7 inches x 11.4 inches)
INERTIAL GUIDANCE SYSTEMS
WITH MEMS
3 axis accelerometer
2 axis gyrometer
1 axis yaw precision gyrometer   SAFETY SYSTEM
EPP hull for indoor flight
Automatic locking of propellers in the
event of contact
UL2054 battery
Control interface with emergency button
to stop the motors
