RC MODELI AVIONA - SUS > SCALE MODELI
SCALE ORIGINALI
tibeteagle:
Posto vidim da je ova kategorija jos siromasna materijalom, evo nesto vredno.
Da bi neko znao da napravi, ili barem da vrednuje skejl modele, prvo treba upoznati originale.
Evo jedne retke prilike da se vide najstarije letelice pionirske aviacije na jednom mitingu, pa makar i na videu.
Uzivajte :)
Ko ima jos ovakve slicne materijale neka stavi.
T.E
tibeteagle:
A kada je platno i drvo izaslo iz "mode", nastupilo je doba gvozda, aluminium i magnezium.
Evo serije videa o avionima II Sv. rata. Ko se pali na ove avione, neka ih pogleda.
Ostale delove videa mozete naci na Youtube.
T.E.
zajko:
Imam takav ali R/C scale model Sopwith Camel 60 ARF HANGAR 9
Specs
Wingspan:61 in (1549mm)
Overall Length:44 in (1118mm)
Wing Area:1288 sq in (83.1 sq dm)
Flying Weight:7.5-8.5 lb (3.4-3.9 kg)
Engine Size:Glow version: Evolution .61NT 2-stroke; Saito FA-91 4-stroke
Motor Size:Electric version: E-flite Power 46 outrunner
Radio:4 channels with 5 servos
Trim Scheme Colors:Olive Drab (HANU904), True Red (HANU866), Grey (HANU882), White (HANU870), Deep Blue (HANU873), Silver (HANU881)
Recommended Battery:Electric version: 1 14.8V 6000mAh 4S3P or 2 7.4V 4200mAh 2S2P Thunder Power Li-Po packs
zajko:
Specs
Wingspan:80.7 in (2050mm)
Overall Length:63.0 in (1600mm)
Wing Area:851 sq in (54.9 sq dm)
Flying Weight:13.5- 15.5 lb (6.1 kg-7.0 kg.) (glow 2 stroke, or Elec)
Engine Size:.36- .40 2-stroke glow engine
Motor Size:Power 46 BL outrunner motor
Radio:6 channels or more
Servos:10 servos 11with retracts (8 servos, 9 for electric conversion with retracts)
Trim Scheme Colors:Gray (HANU882), Olive Drab (HANU904), Sky Blue (HANU875), Dark Yellow (HANU889)
CG (center of gravity):3 3/4 in (95mm)
Wing Loading:36.5 - 42.0 oz/sq ft
Prop Size:10.5x4 3-Blade (EVOE100P) to 11 x 4 2-blade(APC11040) for 2-stroke glow or 13x8E(APC13080E) for electric.
Spinner Size:3/4" Spinner nut (TRU7A140) 1/4-28 threads or 3/4" Spinner nut (TRU7C516) 5/16-24 threads
Hardware Included:Yes
Speed Control :60 Amp
Recommended Battery:Thunder Power 4S 14.8V 3850 mAh to 4200 mAH Li-Po (2 required)
Flaps:Yes
Retracts:Optional
maxa:
--- Quote from: zajko on November 05, 2008, 10:29:21 AM ---Imam takav ali R/C scale model Sopwith Camel 60 ARF HANGAR 9
--- End quote ---
Vidim da imate Sopwith Camel 60 model, možete li mi reći po dosadašnjem iskustvu kakav je u letu, tj. kako se ponaša i koliko je upravljiv na palicama?
Navigation
[0] Message Index
[#] Next page
Go to full version
