Author Topic: Trex 450 razmatranja pre kupovine i ponesto o delovima i cenama ....  (Read 79993 times)
Offline Xardaz_abc
dobar dan svim zaljubljenicima u rc heli...evo kakva je situacija...vidim da ste u toku imate dosta iskustava sa delovima, pa reko da vidim malo sta mislite o masinici koju hocu da narucim :
-ARF 450 RC Helicopter 6CH 3D R/C Heli CNC Body kit GD
-Brushless Motor 450 For Align Trex 450SE V2
-35A ESC
-Head Lock Digital Gyro RC E-flite TREX 450 Blade 400 V2
-4x Metal Gear 9G Servo For Align Trex 450 V2 V3 Pro RC
-FS 6-CH 6CH 72Mhz Transmitter & Receiver For Trex 450
-11.1v 2200mAh 30C 3S LiPo RC Battery Trex 450 V2
-RC BC6 6 Cell Lipo Pb NiMh NiCd Battery Charger
-i ostalo (neke qool cabine ,rotori carbonski prednji zadnji....) sve ukupno bi mi izaslo oko 180e
...Koliko dugo bi trajala ova baterija ?
...Da nisam nesto ispustio sto bi trebao da narucim ..?
...kakva je cena za sve ovo ? pozzz unapred hvalaaa
ZZZZuuuuuuuuMMMMMMM
My dream is to fly over the rainbow so high !
Offline SaleR
Re: Trex 450 razmatranja pre kupovine i ponesto o delovima i cenama ....
« Reply #1 on: March 23, 2010, 08:38:42 AM »
Moja zamerka za narucene deleove bi bila za ziroskop i stanicu...
Koji su servoi u pitanju?
Sa tom baterijom i tim kapacitetom vreme letenja moze biti ograniceno na 5minuta i tada se baterija ne prazni previse ali bi trebao bar 3 takve baterije da se ugodno letelo.
Naravno pre poletanja simulator...
Sretno!
Offline Xardaz_abc
« Reply #2 on: March 23, 2010, 12:39:02 PM »
Motor :
RPM/V: 4000
Max. efficiency current: 8 - 10.5 A (>75%)
No load current / 10 V: 0,5 A
Current capacity: 40 A/60 s
Weight: 64 g
Gyro:
GAZ Head Lock Gyro
Used for 500 and below Electric helicopters,Dual sensibility adjusting model ,With a built in temperature equalizing electrocircuit ,Used for 3D aerobatic acts
Well and High Quality Control
Input signal:1.0-2.0ms
Input power:4.6-6.0V
Weight:12.5g
mada kad bih dodao 6funti na cenu ovog imam ovaj ziroskop:
GAZ-126 Gyro
Servos :
Weight: 13.5g
Operating Speed (4.8V no load) : 0.12sec / 60 degrees
Stall Torque (4.8V): 10.2oz / in ( >2 kg/cm )
baterija
malo mi je nejasno sto se tice baterije ako se gleda vrednost mAh-a kako ce raditi 5min...jer moj ortak vozi dechatlon rc plane na bateriji od 1000mAh-a 15-20 min :S (do duse njegov avion je od presovanog stiropora dosta je laski )
koju bateriju da narucim da bi voznja trajala maximalno vreme sto moze ...
Da li ova moze da produzi zadovoljstvo ?
Capacity: 2800mAh
Burst Rate : 30C
Continuous discharge rate: 25C
Voltage: 11.1V
Cells : 3
Jel si pod stanicom mislio na transmiter i recever ?
Offline Xardaz_abc
« Reply #3 on: March 23, 2010, 01:40:46 PM »
vidim da svi narucujete sa Hobbyland-a, do sad sta god mi je trebalo narucivao sam preko e-baya, mada mislim da cu sto se helija tice da predjem na HL.com za koliko vremena otprilike stizu delovi nakon narucivanja i da ..kada kupujem preko hobbyland-a u step-u 3 koju opciju birate za    Customs Declaration 10% 20%.... ???
Offline SaleR
« Reply #4 on: March 23, 2010, 02:32:44 PM »
Da, to je neki kineski klon gy401 ziroskopa. Nazalost ne znam kako radi u praksi ali se bojim da ce biti koliko para toliko i muzike...
Sto se tice baterije shvatices da za pocetak je sasvim dosta 5minuta letenja po bateriji, a sa ovom vecom bi mogao 6 minuta da letis. Uporedjivati sa avionmo nema smisla...
Servoi su takodje nepoznatog proizvodjaca i nadam se da ces imati srece da sve lepo funkcionise.
Da, pod stanicom sam podrazumevao predajnik...
Offline Xardaz_abc
« Reply #5 on: March 23, 2010, 03:13:28 PM »
da li mi se onda isplati da uzmem falcon 3D (200e)
Glavni rotor: 630mm
Repni rotor: 152mm
Težina: 530g
Dužina: 670mm
Baterija: LI-PO 11.1v, 1300mah
R/C System: EFLY-100C
6ch,
http://www.hobbyland.rs/Falcon3d.html
pa onda polako da upgradujem delove ?
Offline robi
  • sad si gore,sad dole
« Reply #6 on: March 23, 2010, 10:13:22 PM »
Ma ne falcon  !!!
za trexa imaš dijelova gdje hočeš i kompatibilni su sa copterx-om...a on je još jeftiniji od trexa !
što se tiče gyra ...ma preskoči ove jeftilene. razmisli o spartanu 760,eventualno futaba 501 !!!
Offline Davor
« Reply #7 on: March 24, 2010, 12:45:48 AM »
Ja bih rekao da svakako preskocis modele koji su kopije brendiranih modela.Svakao da su jeftiniji,ali ako imas zelju da se u buducnosti malo ozbiljnije bavis helikopterima "niska cena" ce doci do izrazaja.Znas kako se kaze "ko ne plati na mostu platice na cupriji".Pod ovim iskljucivo mislim na kvalitet elektronike,kasnije nadogradnje na koju ces svakako potrositi dodatni novac...Nemoj pogresno da shvatis,nemam nista protiv niskobudzetnih helija ali vremenom ces napredovati i uciti i vrlo brzo ces shvatiti da ti treba drugi heli jer gorepomenuti nece moci da ispune vecinu tvojih zahteva.Pitanje je na tebi sta zelis od helija?Ako ce ti biti dovoljno da letis najosnovnije stvari i to da ti bude zadovoljavajuci nivo letenja onda je tvoj izbor o.k. ali ako si u razmisljanju da ucis komplikovaniji 3D stil svakako ces morati da razmisljas o necem boljem.Tim pre sto sada moze za relativno malu svotu novca da se sklopi neki heli poput Trex 450,Mini Titana,Gaui Hurricane...cak i Trex 250 je dobro resenje.Sigurno da ce kostati malo vise nego ovi koje ti hoces ali moje misljenje je da ce se isplatiti.A i po pitanju stanice mislim da bi trebao da kupis stanicu nezavisno od helija jer ces je kasnije u buducnosti moci koristiti za druge letelice (helikopteri,avioni,jedrilice),sta vec budes fly-ao,a i daje ti gomilu drugih opcija podesavanja koje stanica iz RTF kompleta nema.
Opet se vracamo na ono sta ti zelis od helija.
Ovo gore je samo moje misljenje tako da je izbor na tebi.
Srecno u svakom slucaju.
Offline Xardaz_abc
« Reply #8 on: March 24, 2010, 01:00:27 AM »
izvinjavam se na greshci navodio sam hobby land umesto hobby king :S
Offline Xardaz_abc
« Reply #9 on: March 24, 2010, 01:05:20 AM »
U pravu ste narucicu dobru stanicu ako mozete preporucite mi neki model sto se kaze da bude zadovoljavajuci...i naruci cu body kit pa delove polako na tenane taman dok se istreniram u FMS-u xD
a recite mi jos za narucivanje preko sajta hobbyking.com za koliko stize na kucnu adresu ? i koju opciju za carinu odabirete na 10% ili vise ?? hvala (res)
Offline Xardaz_abc
« Reply #10 on: March 24, 2010, 01:11:33 AM »
da li ova baterija(Turnigy 3300mAh 6S 30C Lipo Pack ) moze na trex 450 ? i koliko bi trajalo  (<--) sa njom ?
Offline n3mke
« Reply #11 on: March 24, 2010, 01:14:03 AM »
Ne moze nikako za 450 idealna baterija je 2200mah 3s 20C+
Offline Xardaz_abc
« Reply #12 on: March 24, 2010, 01:33:01 AM »
cekaj jel postoji neka fora da se trex 450 vozi duze od 5 min ? osim da se menjaju baterije ? xD
Offline Xardaz_abc
Offline robi
« Reply #14 on: March 24, 2010, 12:24:50 PM »
optimum po kvaliteti,broju kanala i cijeni = SPECTRUM DX7
