Author Topic: ALIGN starter  (Read 11154 times)
ALIGN starter
« on: March 27, 2010, 12:06:58 AM »
evo jos jedne nove 'stvarcice".
zove se "Align" i prodaje u dve varijante Heli (HFSSTQ01) i Avionska (HFSSTQ02),
(verzije HFSSTQ06 i HFSSTQ07 su druge kombinacije boja)
starter ima svoju kutiju u kojoj postoji izliveno mesto i za heli i plane verziju
nastavka (koji se mogu kupiti odvojeno) tako da na jednom mestu mozete imati
univerzalni starter. preporucena baterija je lipo 3s, 2300, 16c.
proizvodjac kaze da je sa ovom baterijom moguce napraviti 500 startova!!!!!!
ovaj starter (bar tako kazu) se moze koristiti za startovanje motora do 50cc.
posto sam ja uzeo avio a coka heli verziju zainteresovani se mogu obratiti sa pitanjima
za obe varijante. evo malo i slika i karakteristika.
● Ergonomically designed for optimal hand grip to prevent slippage, light
weight, and easy to assemble/disassemble for transport ease. Suitable
for fixed wing airplanes or helicopters, engine can be started with a
simple one hand press on the button.
● Suitable for up to 50cc gasoline engine or 300 class nitro engine.
● Designed for user replaceable, common 450 heli sized
3S1P 1900~2300mAh/16c lipo batteries. Fully charged battery is
capable of 500 starts and beyond. Battery packs are charged with any
T-REX 450 battery chargers.
● Starting adaptor includes double one way bearing design.
● High efficiency motor providing high starting power, and low reacting
force.
● LED battery voltage indicator and over-discharge protection circuitry.
● Battery undervoltage protection.
● Overheating protection
● Protection against stalling by flooded torque overloading engine.
●Suitable battery:Li-Po 3S1P 11.1V 1900~2300mAh 16C and above(maximum size 112x35x24mm)
●No load rotation speed:2300rpm
●Battery undervoltage:10.8V
●Quiescent current:0 mA
●Motor overheat protection:80°C
●Decelerate gear ratio:5.3:1
●Size:80x60x390mm
●Weight:700g (w/o battery)
ovde mozete pogledati test
Offline tihi
Re: ALIGN starter
« Reply #1 on: March 27, 2010, 10:17:07 AM »
najbitnije kolika je cena ovog lepog startera  :big smile
Re: ALIGN starter
« Reply #2 on: March 27, 2010, 10:45:52 AM »
od 75-120 eur.
Offline n3mke
Re: ALIGN starter
« Reply #3 on: March 27, 2010, 04:52:19 PM »
Cini mi se da se neko mucio da njime obrne motor od cirka 7-8cc na skupu... mozda gresim  :-\
Offline coka
Re: ALIGN starter
« Reply #4 on: March 27, 2010, 07:49:13 PM »
 Moja malenkost je bila inicijator ove kupovine.
Posto cele prosle sezone vozim benzince, a sada se flota povecala, ukljucujuci tu i fenski avion kao i Raptora sa 15ccm glo motorom, pozeleo sam mali kompaktan starter, po mogucnosti bez kablova i baterija.
 Ovaj starter sam prvi put video kod Kreme na proslogodisnjem skupu u Beogradu.
 Bila je to ljubav na prvi pogled ali mi se bas nije davalo 130 ili 180 e koliko su ih cenili.
 Misa je u slicnoj situaciji,  kao i ja sa benzincima, tako da smo se vrlo brzo u zeljama i potrebama, nasli.
 U Budimpesti smo ih drzali u ruci, u Modelhungariji, ali se nismo odlucili da ih pazarimo, ni sam ne znam zasto.
 Sada,u Sloveniji, bilo je sudjeno.
 Anlaseri su savrsenstvo.
 Planiram da kupim jos i nastavak koji ce mi omoguciti da palim i avionske motore.
 Na forumima, pronasao sam nekoliko primedbi na snagu ovog startera.
 Bez izuzetka, uvek je u pitanju bila baterija i njen "mali c", tj nedovoljna struja koju moze da da.
 U moj starter sam stavio jednu vec podosta koriscenu Lipo 3s, 20c, 2450mah, sa kojom bez problema starter okrece YS 91 st, na Raptoru.
 Kada pocne letenje, napisacemo vam impresije sa ovim starterima, koji nisu jeftini, ali , nadamo se, vrede sve pare.
Offline adam
Re: ALIGN starter
« Reply #5 on: March 27, 2010, 07:51:08 PM »
ovaj starter je jedan od najjacih na trzistu ja sam pre par meseci doneo tri komada dva za beograd i jedan u vrsac ,kupci su bili prezadovoljni!!!dobar izbor u svakom slucaju
Offline kremic
Re: ALIGN starter
« Reply #6 on: March 27, 2010, 08:45:30 PM »
Greska je. Na istom skupu vrteo je bez problema Saita 150!!!
Krema
Offline ff7
Re: ALIGN starter
« Reply #7 on: March 29, 2010, 07:37:09 PM »
I ja posjedujem ovaj starter i za sada sam vrlo zadovoljan sa njim.Kad sam ga narucivao narucio sam i nastavak za avione i sve lijepo stane u mali kofer.U njega sam ubacio lipo 3s 2250 mah 25C i starter vrti odlicno benzinski motor od 20 cm3 i to u helikopteru a tu je dosta teze da ga zavrti zbog sistema prenosa.Na netu mozete naci i video gdje ljudi vrte benzinske motore na avionima od 50 cm3 bez problema.U svakom slucaju solidan starter i samo njegovo pakovanje,jedino je malo pitanje cijene koja i nije bas mala.
