Author Topic: Krila Alfa trenera  (Read 10333 times)
Offline An-2 colt
  • YU-TKN
Krila Alfa trenera
« on: April 04, 2010, 04:45:07 PM »
Da li je potrebno ulepiti lepkom dve polovine krila na alfa treneru od Hangar 9.U uputstvu pise da se samo bajonet ubode u jedno krilo i onda sastavi,u donjem delu ima pin i kad sve to legne samo na spoj zalepiti traku.Molim one koji imaju alfe ili iskustvo da odgovore! (<--)
Hvala!!!
Offline An-2 colt
  • YU-TKN
Re: Krila Alfa trenera
« Reply #1 on: April 20, 2010, 07:29:42 PM »
Da li neko ima odgovor???!!! ???
Offline cane
« Reply #2 on: April 20, 2010, 09:46:47 PM »
Assembly
There is very little assembly. The entire sequence is presented in the manual as a two-page drawing; you could easily complete the model without reading the text. You'll need a medium Phillips-head screwdriver and a wrench to tighten the prop nut. There is nothing to glue.
Pozz,
Cane
« Reply #3 on: May 18, 2010, 09:27:07 AM »
bilo bi lepo i ulepiti !
