Author Topic: Lst 2  (Read 29458 times)
Re: Lst 2
« Reply #30 on: February 24, 2014, 11:43:53 PM »
Prika… pa ne bih se bas slozio, ja sam ga imao u 2 navrata stari i novi (LST2 i XXL) i bili su odlicni i kidali .. ali oba u nitro verziji originalnoj..
ali evo je sad u Nurenbergu 3 verzija
LOSI LST XXL-V2  (Gas Engine)
Key Features
Innovative .31 cubic inch gasoline engine
AVC™ (Active Vehicle Control™) equipped
Full 4WD capabilities
Waterproof electronics
Extended length XXL chassis with red anodized chassis plates
Ultra-durable suspension and oversized shocks
Spektrum™ DX2E DSMR™ 2.4GHz radio system Included
Comes equipped with a convenient roto-start tool
http://www.losi.com/Products/Default.aspx?ProdID=LOS04002
 :jaki: (pijemo)
Offline mad_mangod
  • Goran Nis
Re: Lst 2
« Reply #31 on: February 24, 2014, 11:57:26 PM »
A koji motor onda da stavim brushled naravno posto je ovaj odradio svoje.  oo))
Da li da uzmem njegove flrenzy originalne ili neki veci? Na ovom sto je na njemu nista ne pise.  :o :o :o
Biti ili (ne)biti,
pitanje je koga.
Goran
YU1SIS
Niš
Re: Lst 2
« Reply #32 on: February 25, 2014, 12:22:31 AM »
Na njega originalnog mini LST idu 2 x Frenzy 370SK i Twin Motor ESC with Reverse: MLST/2
http://www.losi.com/Products/Features.aspx?ProdId=LOSB0835   LOSB0835  u Bgd kosta 17.99 Eur / komad
http://www.losi.com/Products/Features.aspx?ProdId=LOSB0825   nema ga nesto na Gogle
Ako ne najdes taj Brushed ESC original nadji bilo koji brushed malo jaci sa reversed i vezi paralelno oba motora i pici (mislim da to moze tako)
pozdrav Zajko
« Last Edit: February 25, 2014, 12:27:22 AM by zajko »
Offline dusan.milenkovic
  • Dzaba ste krecili...
    • Monster Photography
Re: Lst 2
« Reply #33 on: February 25, 2014, 09:46:53 AM »
Ako vec ovaj ESC ne moze da se nadje, evo ti lep izbor jakih brushed ESC-ova za male pare.... http://dx.com/s/brushed%2besc?category=801
Sa 300+ ampera ce sigurno da ga teraju sa oba motora :)
Za ovaj znam da moze mnogo da trpi http://dx.com/p/dual-way-320a-brushed-esc-speed-controller-for-1-8-1-10-r-c-car-boat-black-silver-red-184660#.UwxVe4VP16s
Trenutno kod drugara tera losijev 540 15t motor a da se jedva malo podgreje...
Ako se ipak odlucis za brushless setup i ne smeta ti da cekas 20-tak dana ovo mogu da preporucim iz licnog iskustva
http://dx.com/p/hobbywing-ezrun-18a-esc-with-5200kv-18t-brushless-motor-and-program-card-combo-set-35771#.UwxWh4VP16s
Stavio sam ga na turningy mini rally extreme i radi savrseno. Cak je i malo brzi od originala.
Offline Bigneda
Re: Lst 2
« Reply #34 on: February 25, 2014, 02:08:00 PM »
Veliki LST su dobri i jaki ali ovi mali (mini LST) su teska djubrad !!!
Kao sto je neko vec rekao treba ti kesa zupcanika da bi mogao da ga vozis iole :)
Stalno crkavaju PLASTICNI zupcanici u prenosu, lageri... a zameniti ih i skinuti srednji diferencijal sa prenosnom kutijom je maltretiranje ozbiljno !
Imao ga i ja i to sa zamenjenim svim zupcanicima na metal i opet je crkavalo jako cesto !
Pun gas na betonu gde ima gripa i puna kocnica par puta i odose plasticni zupcanici i ako su tek sklopjeni !
Offline mad_mangod
  • Goran Nis
Re: Lst 2
« Reply #35 on: February 25, 2014, 02:23:21 PM »
Ma ECS je ok samo je motor riknuo.  :sljus
Sta mislite o ovom motoru http://www.amain.com/product_info.php/cPath/1_221_1889_222/products_id/172911/n/Kyosho-G20-540-Class-Silver-Can-G-Series-Motor
Samo koje zupcanike?
Biti ili (ne)biti,
pitanje je koga.
Goran
YU1SIS
Niš
Re: Lst 2
« Reply #36 on: February 25, 2014, 02:31:11 PM »
to je veca klasa
treba ti 370-380 a ne 540
Offline mad_mangod
  • Goran Nis
Re: Lst 2
« Reply #37 on: February 25, 2014, 06:20:51 PM »
to je veca klasa
Pa mislio sam da stavim jedan veci umesto 2 mala.
Biti ili (ne)biti,
pitanje je koga.
Goran
YU1SIS
Niš
Re: Lst 2
« Reply #38 on: February 25, 2014, 06:33:18 PM »
Pa kazu ljudi koji su ga imali da lomi zupcanike. Ispravite me ako gresim, al po mojoj logici veci motor sa vecim obrtnim momentom lakse lomi zupcanike...
Offline ivanmagd
Re: Lst 2
« Reply #39 on: February 25, 2014, 09:53:04 PM »
Offline mad_mangod
  • Goran Nis
Re: Lst 2
« Reply #40 on: March 25, 2014, 06:33:36 PM »
Kako da odredim koji zupcanik ide na motor a koji na diferencijal?
Ovaj koji sam stavio na motor se greje.  :mhm
Biti ili (ne)biti,
pitanje je koga.
Goran
YU1SIS
Niš
Offline ivanmagd
Re: Lst 2
« Reply #41 on: March 25, 2014, 10:25:54 PM »
Ajd jos malo pojasni, nisam odmah skapirao kako si vezao zupcanike motora i diferencijala?
Greje se zupcanik koji si stavio na motor?
Ili se greje motor?
Re: Lst 2
« Reply #42 on: March 25, 2014, 10:37:18 PM »
Ako si stavio onaj moj motor onda i treba da se greje. I to poprilicno da se greje..... Uvek je bio ko reso, al ide za medalju..... Ako se greje ESC ko lud, i iskace termo zastita, onda stavljaj manji zupcanik na motor.
Offline mad_mangod
  • Goran Nis
Re: Lst 2
« Reply #43 on: March 27, 2014, 05:46:37 PM »
Ili se greje motor?
Pa da mada mozda se greje motor pa onda prenosi. Zupcanik na motoru je sa 23 zuba a na diferencijalu je sa 62. ESC se ne greje skoro uopste.
Nisam stavio taj stavio sam manji.
Biti ili (ne)biti,
pitanje je koga.
Goran
YU1SIS
Niš
Re: Lst 2
« Reply #44 on: March 27, 2014, 07:44:46 PM »
Pih..... manji..... :P
Ako se greje motor pa prenosi na zupcanike, to je ok. Ako se samo zupcanik greje, moguce je da si ih previse tesno upakovao. Ja recimo taj spoj, piinion-spur, posto je uvek otvoren, prskam teflonskim sprejom za lance bicikla. Podmazuje, nije gusto da usporava, a prilicno ostaje na zupcanicima za razliku od obicnog ulja koje se razleti na sve strane.
