Author Topic: Potreban plan modela Ki-43 Hayabusa  (Read 40558 times)
Re: Potreban plan modela Ki-43 Hayabusa
« Reply #45 on: April 30, 2011, 01:37:34 AM »
To ce bre da vuce mnogo struje jace baterije jaci motor jace sve a sad bash i nisam spreman za takve skokove ali planovi su tu za na dalje mmmm
Razlika u ceni je mnogo manja od zadovoljstva koje dobijaš.
Motor, ESC i baterija - recimo:
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idproduct=2166
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=3888
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=8853
četiri servoa, ...
Offline nenadejno
« Reply #46 on: April 30, 2011, 02:13:18 AM »
 mmmm ej  nemoj da me nagovarash imao sam u planu da uradim model za zezanje  lol
VIVA PRIMITIVA
Offline Mrpossible
  • after the flight start the landing
    • Misterpossible
« Reply #47 on: May 04, 2011, 09:37:52 PM »
Hi Nenadejno,
here u become a lot of informations, because they have the same project as u
http://www.warbirdforum.de/forum/thread.php?threadid=20068&sid=0deef87345ae86f10d963778551b6eb5&hilight=Ki+43+Hayabusa
The rest of thread i have to read slowly, that i understood ur problem right :-))
videmose
Oilver
ja ucite sad srbski jesik
but i am from Germany and celebrate our hobby ca. 30 years (but often only temporaly, tja, working working :-)
I´m a fan of scale aircrafts but mainly with multiple engines
Offline nenadejno
« Reply #48 on: May 04, 2011, 10:33:15 PM »
Vielen Dank Oliver! Ich lerne gerade Deutsch, um Deutsche RC Forume zu verstehen.  :big smile
VIVA PRIMITIVA
Offline Mrpossible
    • Misterpossible
« Reply #49 on: May 04, 2011, 10:44:04 PM »
ufff :-))) und ich mache mir die Mühe das zu übersetzen  (pijanoo) :_D
Jos jedan put :-))  :jaki:
Ja dobro znam tvoj problem :-)))
Tako sam takođe samo  Mitsubishi A6 Zero ( 1010mm )
Možete da koristite mikro - Isključenja do 1 kg ( oko 6 € par ) .
Ali , počev od trave skoro nemoguće ( travu veoma kratko ) .
Sam dizajn na ovaj način :
snažan motor za uspešan start u ruke .
Za sletanje na stomaku ( sa smolom da bi lepo stabilna ) .
Fiksna sletanje na pistu , točkova .
Ili težini od oko 1,5 kg, to je da se krene od trave , tako da većih modela
pozz
Oliver
und auf deutsch :-))
Ich kenne gut dein Problem :-)))
also ich auch baue gerade eine Mitsubishi A6 Zero mit (1010mm)
Ich verwende ein Mikrofahrwerk bis 1 kg (ca 6 € das Paar).
Aber, das Starten von Gras fast unmöglich (nur sehr kurzer Rasen).
Ich konzipiere so:
starker Motor, damit gelingt der Start aus der Hand.
Zur Landung auf dem Bauch (mit Harz schön stabil machen).
Bei Fester Landebahn, auf den Räder landen.
Oder ab etwa 1,5 Kg gewicht geht es vom Gras zu starten , also Modell größer
