Author Topic: E-savage Road Boy  (Read 30544 times)
Offline matovic
    • ModelSport.rs
E-savage Road Boy
« on: June 18, 2011, 05:17:15 PM »
Pozdrav drustvo, evo konacno i da se ja pohvalim... trajalo je citavu vecnost cini mi se :)
Spisak izmena je sledeci:
GCM Racing Extended Road Boy Aluminum Chassis Brushless Edition
GCM Racing E-Savage Aluminum Chassis Braces (Front and Rear)
GCM Hardened Steel Full Center Dog bone set for BL Edition Chassis
GCM Racing Aluminum SS (short shock) towers (Front and Rear)
GCM Racing Bump Steer (with thicker front and rear Tie Rods)
GCM Racing SS Derlin Upper Suspension Kit (Front and Rear)
GCM Racing Machined Aluminum Lower Suspension Kit (Front and Rear)
GCM CVD Kit (Front and Rear)
Kyosho Twin Force Battery Trays
Ofna truggy/buggy threaded adjustable shocks
Proline 1079 Maxx sized Bow-Ties
Proline moulded Foams
HPI 8-spoke wheels
Proline Ford Truck Body
Brushless motor AquaCraft (brodski :P ) 2030KV
FLUX Q-BASE BRUSHLESS ESC
A evo i slika
Pored svih izmena, zaboravio sam da narucim i pinion gear jer sam mislio da ide uz motor  :hehe . Ima li neko 32p 20-22T pinion da probam ovo cudo dok mi isti ne stigne? Moze pozajmica, kupovina, sta god... samo da ne cekam 20 dana da ga "upalim"  (pijemo)
U zdravlje!  ()-()
« Last Edit: June 18, 2011, 05:19:50 PM by matovic »
Offline dzo.ika
Re: E-savage Road Boy
« Reply #1 on: June 20, 2011, 11:41:37 PM »
svaka cast prava makina valjda ce biti i neki video kad ga sklopis komplet
 (:sok:) (:sok:) (:sok:) (:sok:)
Offline Bigneda
« Reply #2 on: June 21, 2011, 06:24:00 PM »
koliko je izasao kontroler ?
Offline matovic
    • ModelSport.rs
« Reply #3 on: June 21, 2011, 06:53:11 PM »
@dzo.ika
bice naravno samo da mi stigne pinion :)
@bigneda
dosta povoljno sam prosao, komplet motor i ESC (novo) preko ebay-a me kostao $160 USD
Offline matovic
    • ModelSport.rs
« Reply #4 on: June 24, 2011, 09:09:10 AM »
Juce bila prva probna voznja ali pomalo bezuspesno, zaboravio sam da zalepim gume  :_D
Jel moze super lepak i koji?
Offline matovic
    • ModelSport.rs
« Reply #5 on: June 27, 2011, 10:11:31 PM »
Prva voznja klapa dva... ima li neko objasnjenje kako/zasto se ovo desilo?
Svi tockovi su rucno stegnuti kako treba... tocak se istopio posle jedno 20min voznje  (work).
Ne da mi se bas  :sljus
Offline Punto Abarth
« Reply #6 on: June 28, 2011, 12:01:07 PM »
meni se slicna stvar desila kad tocak NIJE bio propisno stegnut, i kad je tocak pretrpeo jak bocni udar.
Ako ti pinion jos uvek treba, imam ja, i iz NS sam. Taj post sam procitao odavno, ali sam tek sad autorizovan na forum :D
predstavim se kad stignem u temi sa svojim modelima...
koliko god da ga istreses, zadnja kap mora pasti u gace
Offline alexaca
« Reply #7 on: June 28, 2011, 02:40:43 PM »
Meni se to isto dogodilo ali nema veze sa stezanjem matice nego je sestougao koji ide u sam tocak je proklizao. To znaci da ce tocak ne okrece a matica koja je na osovini okrece i urezuje u plastiku tocka. Tako je bilo kod mene, a sad moze i ako nije zategnuta matica ali tad obicno spadne tocak ali ne mora. Ja sam stavio podlosku pre matice velicine zljeba na tocku znaci vecu od podloske koju imas na matici i naravno osigurao sestougao koji ude u tocak.
Offline matovic
    • ModelSport.rs
« Reply #8 on: July 01, 2011, 11:58:56 AM »
U pravu si alexaca, nedostajao je "axle pin"... jbg-a nisam proverio svaki tocak... na kraj pameti mi nije palo  (nene)
Hex deo felne je manje vise ne ostecen tako da sam "opravio" juce ali nisam jos probao zbog ovog groznog vremena... vec sam narucio 17mm alu hex-ove i nove felne i gume za svaki slucaj  :jaki:
Nego jel neko skidao lepljene gume sa felni? Nesto sam procitao da se iskuvaju pa lepak popusti (CA)?
« Reply #9 on: July 01, 2011, 04:25:00 PM »
uf, i mene isto interesuje. Ja sam svoje stare sa Evader-a bukvalno isekao skalpelom, i izgrebuckao ostatke gume sa felne. Namontirao druge i to je bilo to. Seljacki pristup.
Offline jake87
« Reply #10 on: July 01, 2011, 04:56:11 PM »
a moze da se skine guma i ovako  lol
Ko visoko leti izgubi domet.
Offline alexaca
« Reply #11 on: July 02, 2011, 04:09:25 PM »
Evo nekih primera:
pa izaberite koji vam se svidja.
Offline matovic
    • ModelSport.rs
« Reply #12 on: July 02, 2011, 11:09:58 PM »
Svaka cast, 2 video je najbezbolniji ali treba cekati 24h + moras da farbas felne  :sljus
Offline vlada.bgw
« Reply #13 on: July 05, 2011, 05:30:42 PM »
Milose , odlicna masina , krivo mi je sto je nismo probali na stazi , ali bice prilika  .
Offline matovic
    • ModelSport.rs
« Reply #14 on: July 05, 2011, 10:49:05 PM »
Bice prilike nego sta samo da opravim makinu po drugi put  :big smile
Sa ovim celicnim diferencijalom ne bi trebalo vise da bude problema... mada nikad se ne zna  (pijanoo)
