Author Topic: Quadrocopter GAUI 330X-S Quad Flyer  (Read 9893 times)
Offline duca
« on: July 26, 2011, 09:35:33 PM »
Description--
The Gaui 330X-S quad flyer is an all-new UAV (Unmanned Aerial Vehicle) design that uses a quad rotor configuration for extremely stable flight characteristics.
The stability is acheived by the configuration of two pairs of rotor blades spinning in opposite directions, cancelling out any rotational torque, allowing the aircraft to maintain straight and level flight
Offline duca
Re: Quadrocopter GAUI 330X-S Quad Flyer
« Reply #1 on: August 13, 2011, 02:09:03 AM »
NAPOKON U SIMULATORU.
Vidi sajt
http://knifeedge.com/forums/downloads.php?do=cat&id=348
Offline goran.posao
« Reply #2 on: September 13, 2012, 04:29:30 PM »
ja imam problem da poletim ovaj quad, pod punim gasom ne leti, i dalje je na zemlji, prilikom ucitavanje izbacuje problem da ne moze da pronadje elise i koristice neke osnovne. vozim realflight 4.5 verziju? imal ko ideju kako ga naterati da poeti?
Offline vpilic
    • http://www.rcsrbija.rs/
« Reply #3 on: September 13, 2012, 04:45:19 PM »
Jesi li proverio smer  motora i kako si postavio elise.
Pod punim gasom a na zemlji  mmmm
Offline Gatti.Gatozza
  • up the irons!
« Reply #4 on: September 13, 2012, 05:09:00 PM »
mislim da govori o problemu u simulatoru
Offline goran.posao
« Reply #5 on: September 14, 2012, 12:46:18 PM »
pa jedino da probam da vidim oko podesavanja tih elisa, simulator je sam uzeo neke, upacio sam tricopter koji leti sa osnovnim elisama jer ni za njega ne moze da nadje odgovarajuce ali leti. Probacu sa drugom ver relaflighta.
