Author Topic: Kyosho Inferno ST-RR i ST-RR Evo  (Read 13655 times)
Offline sman
« on: January 21, 2012, 08:34:49 AM »
  • Moderator
Re: Kyosho Inferno ST-RR i ST-RR Evo
« Reply #1 on: January 21, 2012, 09:56:01 AM »
Koliko ja znam samo Bigneda ima ST-RR kod nas tako da ce morati na pocetku najvise on da se potrudi oko pisanja  ;). Ja cu malo pretraziti internet za nekim kvalitetnim testom pa cu ga okaciti.
ST-RR
ST-RR Evo
I spisak razlika za Evo verziju
NEW BODY - The most obvious is the completely new re-designed body.This new body is a low-profile cab forward design and narrows down in the rear. Most air flow to the engine as well as more down force are the result of the new shape. It also looks very, very cool! This body has been in use for the last few months by some of the Kyosho team drivers.Overall it has improved steering and handling on the truck! I must say, I can't wait to get my paint scheme on this thing, and I am sure you are thinking the same thing!
RING and PINION GEARS - Ok, this is a big one! Kyosho has designed completely new ring and pinion gears for the ST-RR EVO that replace the older spiral cut gears! After much debate it has been decided that the straight cut gears are stronger and easier to shim than the spiral cuts!
Revised Bulkheads - Re-formulated and harder materials have been used in the new bulkheads to improve reliability and stability for the mesh of the ring and pinion gears to add even mopre reliability to the differentials.
Revised Front and Rear Suspension Arms - New rear arms that include a mounting position for the new mud guards as well as new revised material for the front arms improve stregth and reliability.
WING STAY Mounts - The wing stay has been changed to mount the MP9's wings. No more body clips to hold the wing on!
WING - The EVO kit now includes the Inferno MP9 wing. This wing has more down force than the old wing with more surface area and a new shape. Also it mounts with aluminum washers and screws to the new wing stay for more durability.
ANODIZING - The ST-RR EVO now has the same anodizing as the MP9! It looks much nicer next to its buggy sister with the new color scheme. This seems like a small deal untill you see them together! All the older blue parts are now all re-done in the Gun metal color!
HEX SCREWS - Just like it's sibling the MP9, all the screws in the kit are Hex machine screws (finally)! This has been a treed for Kyosho's race kits that used to come with many Phillips screws and many of the plastic fasteners were self threading. Most of us prefer this over the old Phillips screws!
OUTER HINGE PINS - The ST-RR EVO now included outer hinge pins that are tapered and have locking nylon nuts on them. The older hinge pins had e-clips and some of us have had trouble with them falling off during an event if not maintained correctly! This all but eliminated this problem!
BIG BORE SHOCKS with ADJUST COLLARS - Finally the newer MP9 style threaded shock bodies are now available for the ST-RR! The longest shock bodies are included with the ST-RR so now you can use threaded shocks on your ST-RR and your MP9.
NEW THROTTLE LINKAGE - The ST-RR EVO included the MP( style throttle and brake linkage set. No more fumbling around for the right servo horn for the job! The EVO has the MP9 linkage and it is perfect for the job!
NEW AIR FILTER - Again, borrowed from the MP9 buggy, the new air filter system is lower profile for a lower CG as well a a more efficient design.
ENGINE MOUNT - The ST-RR EVO has a new lower profile engine mount. This gives the truggy a lower overall CG by lowering the weight of the engine in the chassis by approximately  2mm.
FLY WHEEL - The new engine mount also works hand in hand with the new smaller diameter fly wheel. This flywheel is lighter and also improves the lower CG of the truggy. The lower rotating mass of the flywheel also assists in more throttle response in the drive train.
BRAKES - now the ST-RR EVO has vented disks for the brakes, like the MP9 for improved consistency in long mains. You will need these as with the new EVO you will be getting in more long mains!!!
MUG GUARDS - Mud guards are now a standard feature on the ST-RR EVO and they help protect the rear shocks from mud and flying debris, improving the reliability of the shock as well as deflecting some of the hot exhaust gas from the left rear shock preventing thinning of the oil..
« Last Edit: January 21, 2012, 03:12:31 PM by magic »
  • Moderator
Offline Bigneda
« Reply #3 on: January 21, 2012, 11:44:30 PM »
Ne znam sta bih rekao o ovom modelu a da vec nije napisano na netu :)
Vrhunski model evoluirao od prethodnika ST-R sa duzom sasijom i gomilom vecih i manjih poboljsanja koja sva zajedno daju perfektnu kombinaciju ;)
Ono sto bih ja istakao je da je vrlo prost model i bez preteranih komplikovanja i filozofiranja oko izrade delova, opet koristi dosta plasticnih delova od svog prethodnika a i modela pre njega odnosno o vec pominjanom ST RTR modelu, tako da je bar sto se tih delova tice bagatela ;) drugi delovi su napravljeni od najboljih mogucih materijala a to ima svoju cenu pa tako jedna od najskupljih stavki o kojima treba voditi racuna su zupcanici na diferencijalima (opet ko o cemu baba o ustipcima ;)) iako je legura Hrom-molidbena-celika najkvalitetniji materijal nisu potpuno otporni na NEODRZAVANJE i svakako ce propasti ako se to ne radi pravilno !
Sve ostalo je po mojim standardima jeftino i ne preterano tesko za odrzavanje.
Sam model je odlicno izbalansiran i zahvalan za voznju, od svog prethodnika se izdvaja bolja upravljivost i stabilnost na srednjim i velikim brzinama (na uskim i vijugavim stazama prethodnik je ostao bolji zbog svog manjeg medjuosovinskog rastojanja) bolje skace i upija neravnine zahvaljujuci Big-Bore amortizerima i neverovatno dobro koci zahvaljujuci definitivno najboljim kocnicama u Truggy svetu ;) (proizvod firme koja se profesionalno bavi izradom kocnica za trkacke automobile i prototipove tipa F1) ...koliko je to prednost vecina zna ali kolika je to mana retko se objasnjava  mmmm ...posto se kocenje kod ovih modela prenosi od srednjeg diferencijala, preko kardana, prednjeg i zadnjeg diferencijala, poluosovina pa sve do tockova i njihovog kontakta sa podlogom vidimo koliko je mehanickih delova u celom lancu i SVI oni trpe opterecenje !
Kod buggy modela to nije neki problem ali kod modela sa velikom trakcijom to moze biti veeeliki problem, opet najoptereceniji delovi kao i kod pogona su pinjoni i spur-gear-ovi na diferencijalima koji sad trpe kontra opterecenje od onoga koje se javlja prilikom gasa !
Tako da bi jos jedan savet bio da ne preterujete sa kocnicama na truggy modelima, odnosno ne setujte ih da koce u mestu i blokiraju tockove ! ! ! mnogo ce vam duze trajati diferencijali i mnogo ce redje morati da se radi njihova revizija i shimovanje ;)
Toliko za prvu epizodu, kad se setim jos necega bitnog idemo dalje ;)
Offline Vox
« Reply #4 on: March 13, 2012, 04:10:20 PM »
Evo i ja da predstavim novog clana moje garaze. U pitanj je Kyosho ST-RR.
Model je doputovao pre neki dan (<--), i pravo da vam kazem, nije sto je moj, ali stvarno izgleda extra.
Sto kaze Bigneda, ne zna covek da li da ga vozi ili da ga drzi kao ukras u dnevnoj sobi, aliiiii, jedva cekam vikend da ga probam. ;)
A autic u kratkim crtama izgleda ovako-nekao......
Model je u potpunosti fabricki, osim nesto tuning delova koji su stavljeni, a u pitanju su prednje glavcine i nosac servoa od firme KING HEADZ.
http://www.kingheads.com/product_info.php?cPath=17_48&products_id=204&osCsid=28eb03ce202da167393e300025e8bdfa
http://www.kingheads.com/product_info.php?cPath=17_48&products_id=181&osCsid=28eb03ce202da167393e300025e8bdfa
Model je opremljen sledecim servoima:
za upravljanje - Vortex Servo 2015
za gas/kocnicu - Vortex Servo 1409
Gume - LRP
http://www.lrp.cc/en/products/vtec-tyre/18-offroad-truggy/produkt/vtec-18-off-road-truggy-lp-suicide-komplettrad-verklebt-medium-compound/details/
Motor - RB S7
A evo i jos malo slicica:
O samom modelu necu mnogo da vam pricam, jer su Magic i Bigneda, dosada uglavnom napisali elaborate o ovom i njemu slicnoj braci. Kada ga budem provozao, reci cu vam moje utiske, a do tada........ (yay)
Offline Bigneda
« Reply #5 on: March 13, 2012, 04:26:38 PM »
 :)aplauz :)aplauz :)aplauz
 ()-() (res) (pijanoo)
...motor je S7 World ;)
Offline sman
« Reply #6 on: March 13, 2012, 04:38:46 PM »
gledao sam ga i ja, odlican je... kolko si ga platio bez elektronike i motora (ako nije tajna) ;namig
Offline Vox
« Reply #7 on: March 13, 2012, 04:38:53 PM »
Motor je Powerd by Bigneda, tako da mi predstoji upoznavanje i sa njim!!! ;)
Offline Vox
« Reply #8 on: March 13, 2012, 04:54:21 PM »
Model je do Beograda kostao oko 650 eur, a kompletan, sa svom opremom za livadu, racunam da ce da bude malo preko 1000 eur.
Motor koji je na njemu nameravam da vozim jedno vreme dok se ne uhodam. U planu je kupovina novog motora i auspuha,
tako da ce da ode jos koja stotkica, a tu je i nabavka rezervnih delova.
Kosta skoro pa kao pravi auto!!! (pijemo) ;)
Offline sman
« Reply #9 on: March 13, 2012, 05:57:01 PM »
svako zadovoljstvo kosta ,pa i ovo...  ;namig  sa srecom da ga vozis. ()-()
Offline Bigneda
« Reply #10 on: March 13, 2012, 06:01:11 PM »
Ko Borina pesma, "Lutka sa naslovne strane" :)
  • Moderator
« Reply #11 on: March 13, 2012, 08:09:59 PM »
Au kume, i ti volis skupe pesme  "). Pa za te pare si mogao da kupis 2 Losija  lol. Naravno salim se, i zelim ti da se navozas do besvesti.
Kakva nam sezona prestoji  (yay)!
Offline kristijanbgd
« Reply #12 on: March 13, 2012, 10:59:31 PM »
 (res) za auto..
Offline duke
« Reply #13 on: April 04, 2012, 06:51:54 PM »
evo drugari da se pohvalim malo ,ovo sam kupio pre neki dan ;http://www.ebay.de/itm/260988788951?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649    videcemo kakva je kofa kad stigne ... :mhm :mhm
