Author Topic: Losi SPEED NT  (Read 8089 times)
Losi SPEED NT
« on: May 16, 2012, 11:29:27 PM »
Evo stigao, izmedju ostalih, jos jedan Losi koji mi je nekako privukao paznju !! ! Lepa kutija, a u kutiji  (res)
Autic je 1/8, maska mi je super, nekako sportska, Glow motor Losi 3.4 High-perfomance, sa 1,8 HP i 34.000 RPM...
Spin-Start system paljenja, SPEKTRUM 2.4 Ghz stanica (Losi MTX Pro) i sa preko 60 Mph max. brzine..
http://losi.com/Products/Default.aspx?ProdId=LOSB0125
Ima digitalne servoe za Throttle & Steering, ALU amortizere, 2 brzine, tunes exhaust system !!!
Elem, malo trosi, mali rezervoar, otprilike 10 min.
Moram reci da je upalio prvi put iz drugog verglanja, nakon toga svaki put iz prve !!
Ono sto je bitno evo posle 10-15 rezervoara, jos uvek mu nisam takao ni jednu iglu na karb. trebalo bi sada vec malo utegnuti gorivo, sto se razradilo, razradilo... Prva tri rezervoara sam ga tu i tamo pazio, lagano, a po sle toga vec, malo ili dosta ostrije... Kad se motor lepo zagreje, dobija pun broj obrtaja jako lako... Lep zvuk kod promene brzine ... (work)
Nevidjeno je brz, i relativno lagan nesto malo manje od 2 kg... pogon normalno samo na zadnje tockove, a ima i "wheelie bar"... propinje se na zadnje ko zdrebac  ;namig
Na suvom mi deluje jako upravljiv, iako do sada bas i nisam imao neka preterana iskustva sa zadnjom vucom, only ...
The 1/10-scale Speed-NT nitro ready-to-run truck is capable of taking fast speed to the extreme. Packed with performance-driven features like a Losi 3.4 high-performance nitro engine, a 2-speed transmission, and a Losi radio system with Spektrum® 2.4GHz DSM® technology the Speed-NT has the power to reach shattering speeds of 60mph or greater.
Type:High-Speed Nitro Truck
Scale:1/10
Length:19.85 in (504mm) with wheelie bar
Width:12.6 in (320mm)
Wheelbase:11.35 in (288.3mm)
Weight:4.4 lb (1995.8 g) without fuel
Chassis:Aircraft aluminum alloy
Suspension:4-wheel independent
Motor or Engine:Losi 3.4 ultra high-performance .20 nitro engine
Radio:Losi MTX Pro with Spektrum 2.4GHz DSM technology
Batteries:Includes 4-AA for the Receiver and 4-AA for the Transmitter
Speed:60mph+
Kit/RTR:RTR
Shock Type:Aluminum oil-filled
Body:Custom Finished Aerodynamic Sport Truck (Available in Red or Blue)
Ball Bearings:Complete
Technical Notes
Gear Ratios for the Speed-NT
1st Gear – Internal – 3.47
2nd Gear – Internal – 3.11
1st Gear Overall (with 22 pinion and 62 spur) – 9.79
2nd Gear Overall (with 22 pinion and 62 spur) – 8.77
Ne prevrce se bas tako lako, zbog zadnje vuce i dobrog balansa, ali zato hoce da mrda guzom  (:sok:)
Offline jovanovic28
Re: Losi SPEED NT
« Reply #1 on: May 17, 2012, 08:59:17 AM »
Mislim da je autic ipak 1/10 scale  (fiu)
  • Moderator
Re: Losi SPEED NT
« Reply #2 on: May 17, 2012, 09:50:18 AM »
Ma zvanicno se vodi kao 1/10 ali je cinjenica da je malo veci od tipicnog 1/10, pre ce biti da je neki 1/9.
Ovo je tipicni basher, za jurcanje po nekom parkingu i izivljavanje i nista drugo. Mana toga je sto to brzo dosadi ...
 4e
Re: Losi SPEED NT
« Reply #3 on: May 17, 2012, 10:22:44 AM »
mmmm
U pravu je kolega Jovanovic28, to je 1/10, greskom sam kucao 1/8... a evo ga i pise dole u "GLOW" specifikaciji   :)aplauz
Da jeste dobar za jurcanje i zajebanciju, i verovatno bi dosadio vremenom, ali moze i on na stazu valjda ??
Nisam ja bas mnogo u automobilima, jesam probao i jurcao okolo naokolo, ali tek sad upoznajem materiju  :sljus
Dace Bog od nedelje, da ih probam na stazi, pa ako se primim...  :_D
Offline n.artur
Re: Losi SPEED NT
« Reply #4 on: May 17, 2012, 01:13:33 PM »
Dosta lici na Traxxas Jato-a i po izgledu i po tehnickim detaljima
http://traxxas.com/products/models/nitro/5507jato33
Po mom skromnom iskustvu za off road je malo teze upravljiv jer je zadnja vuca i tesko ga je kotrolisati,
dok je za on road druga prica.
Ja imam Jato-a, pa ce mo taman da probamo neku zajednicku voznju (trku).
Losi 8IGHT 4.0 + Alpha RyanLutz + Spektrum Servo
Losi 8IGHT 4.0 Elektro + Savox Servo
Losi 8IGHT-T 2.0 RR + P5XL-T + Savox + Spektrum
Spektrum DX4R
Re: Losi SPEED NT
« Reply #5 on: May 17, 2012, 04:00:13 PM »
Da, da vrlo su slicni, da ne kazem isti, svidja mi se njegova crna osnova...
Vazi... za voznju... (pijemo)
