Author Topic: ALIGN APS GYRO  (Read 18997 times)
Offline nebeski
ALIGN APS GYRO
« on: May 22, 2012, 11:32:44 AM »
Pogledajte ovaj spisak mogućnosti:
  • Semi-autonomous take off / Landing (Activate system, semi-autonomous takeoff into position and altitude hold, hovers in attitude hold with strong holding ability to prevent drifting, suitable for hover and flight training)
  • Failsafe (Activate system, automatic return home during loss of signal situation)
  • Auto flight (Activate system, transmitter can execute multiple waypoint settings, enabling point to point automatic flights.)
  • Emergency bailout stabilization (loss of orientation, activate system, aircraft flips right side up, goes into position and altitude hold hover, and wait for further command).
  • Autonomous return home (Completion of mission, activate return home command)
  • Simple logical setting through transmitter (APS system does not require complex PC setups)
  • Supports software upgrades
Kontroleri za helikoptere i multikoptere polako počinju da liče jedni na druge.
Biće veoma interesantno videti gde će cenovno Align da smesti ovaj proizvod.
Konkurentski sa sličnim karakteristikama su oko1K$ (DJI Wookong-H). Ako bi ovo bilo makar upola jeftinije (ala sam optimista   oo)))
možda bi moglo o tome i da se razmišlja  mmmm.
Ovakva spravica definitivno može da bude isplativa investicija ako bi makar jednom spasila neki heli ranga Trex600 ili Trex700.
Re: ALIGN APS GYRO
« Reply #1 on: May 22, 2012, 12:16:51 PM »
To je super spravica za pocetnicko letenje helisa, kada se pocetnik zbuni, a ima vremena da klikne dugme i ukljuci sistem.
Nemojte se zanositi cinjenicom da ce vam ALIGN APS GYRO spasiti helikopter pri nekom 3D letenju blizu zemlje.
M. (pijemo)
Offline pericamitic
Re: ALIGN APS GYRO
« Reply #2 on: May 22, 2012, 12:26:16 PM »
Super,
A gde je tu čar čekanja, sastavljanja, letenja, padanja, čekanja, sastavljanja, letenja, padanja,čekanja, sastavljanja, letenja, padanja... ()-()
Offline nebeski
Re: ALIGN APS GYRO
« Reply #3 on: May 26, 2012, 12:57:30 AM »
Evo jos malo snimaka:
Sa ovog sledećeg se može zaključiti da je APS u stvari dodatak za 3GX:
« Last Edit: May 26, 2012, 01:01:38 AM by nebeski »
