Author Topic: 1/10 4WD modeli  (Read 5231 times)
1/10 4WD modeli
« on: July 12, 2012, 04:24:16 PM »
Krajem avg.12 izlazi u USA ovaj Novi Losi.. deluje dobro... Poceo losi da ubacuje startere na dugme u automobilcice !!!
http://www.tlracing.com/Products/Default.aspx?ProdID=TLR0129#prodMedia
http://www.tlracing.com/ProdInfo/Files/35753_TLR_TLR0129_HI.wmv
Cena ce mu biti u USA oko 529.99 $ RTR sa SPEKTRUM DX2L (Li-Po RX pack & Charger 1000Mah 7.4V)
Key Features
Remote On-Board Starting System
Waterproof Electronics
Spektrum DX2L Transmitter
3.4 Nitro Engine Performance Tuned Pipe
Aluminum Threaded Big Bore Shocks
Durable, Anodized Aluminum Ten Chassis
3.4 Nitro Engine
Spektrum SR300 Receiver W/ 2.4GHZ DSM
Water Tight, Optimized Gen III Radio Tray
Three Sealable Differentials
Simple-Adjust Motor Mount
Digital, High-Torque waterproof Seering Servo
12mm Wheel Hexes
Losi Exclusive Eclipse™ SCT Tread Pattern
Off-Road Beadlock-Style Wheels
Realistic SC Bumpers With Mud Flap
4mm Adjustable Turnbuckles With Captured Ends
Captured Hinge Pins
7.4V 1000MAH LiPo Receiver Pack And Charger
The 4WD TEN-SCT™ truck has an amazing pedigree. It’s based on the performance-driven TEN-T™ platform and ROAR National Champion TEN-SCTE. The same painstaking engineering that dreamed up the TEN-T vehicle went into the creation of the TEN-SCT. The same aluminum chassis, race-tested suspension and superb handling characteristics have found a home in this no-holds-barred nitro version. Ready-To-Run, the TEN-SCT truck has the heart of a warrior and the chops to tear up any track. With the waterproof servos and a tightly sealed radio box, you won’t have a problem driving in various weather conditions. Rain, snow, or mud Go ahead and get it dirty! Offering extreme power and incredible torque, the 3.4 engine is the most powerful in its class.
[/img]
Fire up the engine with the push of a button on the included DX2L transmitter. Forget glow igniters and pull starting. The TENSCT is equipped with the Remote Onboard Starting System (R.O.S.S.). With the push of a single button on the included Spektrum DX2L transmitter, the glow plug is heated and electric starter engaged for instantaneous hands-free starting-no glow driver, no handheld and no more pull starting.
Product Specifications
Type:   4WD Nitro Short Course Truck
Scale:   1/10
Length:   21.34 in (524mm)
Width:   11.65 in (295.8mm)
Wheelbase:   13.15 in (334mm)
Weight:   6.75lb (3.06 kg)
Chassis:   Anodized Aluminum
Suspension:   4-wheel independent long-travel
Drivetrain:   4WD
Motor or Engine:   Losi 3.4cc
Radio:   Spektrum DX2L
Kit/RTR:   RTR
Shock Type:   Aluminum
Fuel Tank Capacity:   82cc
Needed to Complete
- 20–30% Nitro Fuel
- Fuel Bottle
« Last Edit: July 16, 2012, 12:25:20 AM by magic »
  • Moderator
Re: 1/10 4WD modeli
« Reply #1 on: July 16, 2012, 12:32:12 AM »
Modifikovao sam naslov topika kako bi se ovde pisalo o 1/10 4WD modelima. Poenta je da ako se skupi dovoljno modela onda se moze organizovati takmicenje i u ovoj kategoriji. Znaci mogu se takmiciti BILO  KOJI 1/10 4WD modeli, i glow i elektro, a u slucaju elektro pogona su dozvoljeni isti motori kao i za 2WD kategoriju tj. do 3.300kV i 2S baterija (vidi spisak http://www.rcfly4um.org/index.php/topic,7448.msg62644.html#msg62644).
Evo jednog interesantnog takvog modela na HK:
http://www.hobbyking.com/hobbyking/store/__20997__Turnigy_1_10_4WD_Brushless_Short_Course_Truck_ARR.html
