RC MULTIKOPTERI > MULTIKOPTERI GENERALNO
TBS discovery quad
<< < (3/3)
ak:
Jeste ga uzeli sa ili bez TBS Core? Planirate da ga letite FPV ili?
djbojan:
--- Quote from: ak on March 11, 2013, 11:24:05 AM ---Jeste ga uzeli sa ili bez TBS Core? Planirate da ga letite FPV ili?
--- End quote ---
ja planiram da letim fpv, ali cekam lepo vreme, zasad mi je obicno zujanje sve sto radim sa  njim, popizdeo sam cekajuci gopro2 , treba drugar da dodje iz nemacke i da donese pa da zakacim video link na nju
djbojan:
Gopro hero 2 je stigla, ali sad imamo jello , moram balansirati motore i elise.
djbojan:
Led monitor, kupljen i cekam da stigne, pa krecem sa fpv
Features:
• 7.0 inch TFT LCD Display
• Ideal for use with FPV
• No "Blue Screen" caused by weak signal input
• 800 x 480 High Resolution Display
• LED Backlight
• 16:9 Display Ratio
• 15ms Response Time
• 500:1 Contrast Ratio
• Wide 6~18V DC Input Voltage Range
• Foldable Screen Shroud for outdoor use included
Specs:
Panel Size: 7.0 inch
Panel Type: TFT LCD
Resolution: 800x480
Backlight: LED
Horizontal Frequency Range: 30~60kHz
Field Frequency Range: 50~75Hz
Dot Pitch: 0.0642 (W) x 0.1790 (H) mm
Display Ratio: 16:9
Brightness: 400 cd/m²
Contrast Ratio: 500:1
Response Time: 15ms
Viewing Angle: 70°/70° (L/R) 50°/60° (U/D)
Input Voltage: DC 6~18V
Power Consumption: ≤ 5W
Working Temperature: -20°C ~ 60°C
Storage Temperature: -30°C ~ 70°C
Dimensions: 182 x 127 x 32mm
Weight: 363g
http://www.hobbyking.com/hobbyking/store/__28907__7_0_Inch_TFT_LCD_Monitor_for_FPV_800x480_LED_Backlight_no_34_blue_screen_34_effect_.html
djbojan:
Posto sam naderao kad sam update-ovao NAZA-u , pukao mi je jedan od propelera, i ne mogu nigde da kupim vise graupnere eprom 10x5,  pa sam kupio 11x5 carbonske na rctimeru, i kad su stigli ja sav happy.... medjutim, mali je razmak izmedju motora, e lepo mi doslo da placem  oo))
Navigation
[0] Message Index
[*] Previous page
Go to full version
