AERIAL PHOTGRAPHY > FOTOGRAFIJE i VIDEO SNIMCI
Gnarly HD - 1080P High Definition Sports Action Camera with LCD
<< < (2/3) > >>
flugzeug:
--- Quote from: Gatti.Gatozza on April 21, 2011, 09:58:56 AM ---Da li je ugao od 90 stepeni previše za kameru koja se montira na avion? S obzirom da je ipak na visini, bojim se da se ništa živo ne bi videlo, ili bi bilo previše "fisheye".
--- End quote ---
Previše? nikako! sa 90 stepeni nebi mogao uopste da se orijentises...
1.7mm lens has approximate 170 degree field of view (gopro)
2.1mm lens has approximate 158 degree field of view
2.5mm lens has approximate 147 degree field of view
2.8mm lens has approximate 130 degree field of view
2.9mm lens has approximate 127 degree field of view (Natural Human eye)
3.6mm lens has approximate 92 degree field of view
4.3mm lens has approximate 88 degree field of view
6.0mm lens has approximate 78 degree field of view
8.0mm lens has approximate 58 degree field of view
12 mm lens has approximate 28 degree field of view
kremic:
--- Quote from: Lazo on April 21, 2011, 09:56:10 AM ---GoPro ima odlične optičke i elektronske karakteristike. Tu nema spora. Smeta mi to što je totalno ne-aerodinamična. Jednostavno, dizajnirana je za namenu koja ne podrazumeva potrebu za neku aerodinamičnost. Zato tragam za kamerom koja ima "pakovanje" koje je slično ovoj za koju sam pitao, a da ima što kvalitetniju sliku.
--- End quote ---
evo nesto sto je aerodinamicnije :
http://www.amazon.com/ContourHD-1080p-Full-Helmet-Camera/dp/B002QGSYZ4/ref=sr_1_30?ie=UTF8&qid=1301042037&sr=8-30
i uporedni test:
http://www.technobrains.com/gopro-hd-hero-vs-vholdr-contourhd-extreme-sport-digital-camera/7696/
flugzeug:
Koliko vidim ni ova nema analog video out...
Lazo misliš li je koristiti za FPV ili samo kao "on board recorder"?
Yu-men:
--- End quote ---
Slazem se u potpunosti sa Cika-Lazinim komentarom.  :mhm
Ja se razmisljam da uzmem "Aiptek HD-Camcorder PenCam Trio HD".
Ima solidnu sliku sto je po meni sasvim dovoljno za nase (moje) potrebe.
5 Mega Pixel CMOS Sensor (2592x1944), 1/ 2.5"
HD 720p @ 30fps, 1280x720, 30fps, 16:9
4GB interne memorije
i HDMI und TV-out (NTSC/PAL),
Evo video gde se uporedjuje sa novom FlyCamOne 3 (FCO3).
Ubedljivo bolju sliku daje a jeftinija od FCO3.
flugzeug:
Pogledaj i ove dvije, takodje jeftinije varijante, ovu prvu koristim na easystaru stim da sam promjenio sočivo zbog premalog FOV...
http://www.dealextreme.com/p/12-0mp-cmos-1080p-full-hd-digital-car-dvr-camcorder-w-wide-angle-hdmi-tv-out-sd-2-5-lcd-47859
Ima tv-out analogni, moze da snima sa 60fps, jeste cmos senzor ali kamera zaista nije loša za te pare...
Ovu nisam probao pa ne znam ali se po specifikacijama čini ok...
Ako budem u prilici podignuti ću veceras jedan snimak sa gore prvom navedenom kamerom...
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
