RAZNO => MATERIJALI / TEHNIKE OBRADE U MODELARSTVU => Topic started by: englez on February 13, 2009, 11:36:22 PM
nasua sam ovo...
http://www.stenulson.net/rcflight/skikits.htm (http://www.stenulson.net/rcflight/skikits.htm)
izglede laku do pravi. sta mislis?
(http://i277.photobucket.com/albums/kk61/nikolash_photo/DSCN2346.jpg)
Ove moje nisu lepe al odlično rade i sklepane su za 15 minuta,(work) od poklopca starog gramofona par letvica i gumica i jednog prstena za osiguranje točka i dužeg šrafa (graničnik hoda).
These aren't pretty, but functional.
To make these you will need: lid from an old HI-FI, some hardwood , pair of wheel collars, pair of long bolts (compatible with collars), and couple of rubber bands, CA glue and some (work)
Dobro izglede, to je to.
Danas jacu probam, ali sa 'taildragger' (res)
Moje vidjenje skija na Lazy Bee, uradjeno danas, za sat vremena,
Skije su od stirena, plastike debele 2mm, dimenzija 20x5 cm glavne i 3x8 cm skija repnog tocka.
(http://i10.photobucket.com/albums/a150/NS_RC_ELECTRICS/LazyBee/LazySkis_01_resize.jpg)
Isecene i obradjene u zeljeni oblik,
(http://i10.photobucket.com/albums/a150/NS_RC_ELECTRICS/LazyBee/LazySkis_02_resize.jpg)
Stiren je meka plastika, koja se lako temperaturom obradjuje u zeljeni oblik , malo grejanja upaljacem, savijanja preko boce spreja WD40 i skije su gotove.
(http://i10.photobucket.com/albums/a150/NS_RC_ELECTRICS/LazyBee/LazySkis_03_resize.jpg)
Nosac skija je drvena letvica 6x15mm, isecena u 4 komada, zalepljena super lepkom na poziciju pored glavnih tockova,
(http://i10.photobucket.com/albums/a150/NS_RC_ELECTRICS/LazyBee/LazySkis_04_resize.jpg)
(http://i10.photobucket.com/albums/a150/NS_RC_ELECTRICS/LazyBee/LazySkis_05_resize.jpg)
Posto je stiren plastika koja ne prima najbolje lepak, spoj je ojacan i vijcima od 2mm,
(http://i10.photobucket.com/albums/a150/NS_RC_ELECTRICS/LazyBee/LazySkis_06_resize.jpg)
(http://i10.photobucket.com/albums/a150/NS_RC_ELECTRICS/LazyBee/LazySkis_07_resize.jpg)
Ucvrscenje na tocak je gumenim trakama, a kaci se na okrugle bambus stapice od 5-6mm, za raznjice,
(http://i10.photobucket.com/albums/a150/NS_RC_ELECTRICS/LazyBee/LazySkis_08_resize.jpg)
(http://i10.photobucket.com/albums/a150/NS_RC_ELECTRICS/LazyBee/LazySkis_09_resize.jpg)
Repni tocak je takodje dobio umanjenu verziju glavnih skija,
(http://i10.photobucket.com/albums/a150/NS_RC_ELECTRICS/LazyBee/LazySkis_10_resize.jpg)
Stabilizacija polozaja skije u letu je resena gumenim trakama i zicom,
(http://i10.photobucket.com/albums/a150/NS_RC_ELECTRICS/LazyBee/LazySkis_11_resize.jpg)
I na kraju, sve je dobilo jedan sloj sive boje, prajmer u spreju, radi zastite i lepseg izgleda,
(http://i10.photobucket.com/albums/a150/NS_RC_ELECTRICS/LazyBee/LazySkis_12_resize.jpg)
Letna ispitivanja sutra, na Ceneju,
Evo moj, na avion "Frankenstein"
(http://i13.photobucket.com/albums/a256/sremskakamenica/Planes/DSCF0053.jpg)
Neme sanse sa sutra, cekam delovi sa "franki" (nene)
Bravo Nenade.
Brzo,jednostavno i veoma modelarski :)aplauz
Ocekujemo izvestaj sa letenja.
Pozz
Englez, koji je to model, nesto mi mnogo lici na moj Spree?
Sto se tice skija, jesi li siguran da ce izdrzati, dosta su male. mmmm
Pozdrav.
Ja nisam siguran sa nista oo))
To je..... http://www.greatplanes.com/airplanes/gpma0205.html
Ali to bio pre 4 mesec!
sad je..
(http://library.ucf.edu/frankenstein/images/Frankenstein.gif)
Danas, 15, Februar, 2009, aerodrom Cenej,
Vreme:
(http://i10.photobucket.com/albums/a150/NS_RC_ELECTRICS/NoviSadvreme-15-2-2009.jpg)
Test flight.
(http://i10.photobucket.com/albums/a150/NS_RC_ELECTRICS/LazyBee-snow_15-2-2009_5_resize.jpg)
(http://i10.photobucket.com/albums/a150/NS_RC_ELECTRICS/LazyBee-snow_15-2-2009_4_resize.jpg)
(http://i10.photobucket.com/albums/a150/NS_RC_ELECTRICS/LazyBee-snow_15-2-2009_7_resize.jpg)
(http://i10.photobucket.com/albums/a150/NS_RC_ELECTRICS/LazyBee-snow_15-2-2009_9_resize.jpg)
(http://i10.photobucket.com/albums/a150/NS_RC_ELECTRICS/LazyBee-snow_15-2-2009_6_resize.jpg)
Na kraju, nista od uspesnog skijanja, lepljiv sneg, dosta trave, nikako nisam uspeo da ubrzam i poletim , model se posle par metara nabijao na nos.
Jedino uspesno poletanje sa skijama, posle lagane"gurke" pri startu, zavrseno je posle desetak sekundi leta, jer su skije pravile takvo vrtlozenje da je model po pravcu bio gotovo neupravljiv.
Pri vetru od 6m u sekundi, sleteo sam grubo i napravio "ciganski" (romski) tocak, ali je model ostao ceo.
Sledeci let, poletanje iz ruke i nesto duzi let se takodje zavrsio grubim sletanjem jer je model i dalje bio jako slabo upravljiv po pravcu.
Sa par naprslih letvica i monokota na trupu, spakovao sam model i vratio se kuci.
Problem upravljivosti po pravcu, kod LazyBee je identican onom koji sam imao proslog leta kada je na njemu bila postavljena kamera za aero foto snimanje.
Model je zbog kratke poluge izuzetno osetljiv na promenu tezista, sto zbog velike dubine krila ne rezultuje losu upravljivost po dubini ali je model klimav po pravcu.
Nadam se da cu sledeci put sa drugim modelom na skijama imati vise srece.
Nenad, bravo, ti si 'braver'(odvažan) nego ja.
Ja probudem, gledaj kros prozor, i vrati do krevet. (spava)
prognoza kaze jos sneg, sledicni vikend idem ja sa Frankenstein.
Privi ja moram pravim vrlo vece skis.
I'm more stupid than brave...
Cenej je danas bio Bbrrrrrr...
Obavezno napravi vece skije (larger ski's), , bar 2x10" (50x 250mm), i ostavi auto sa upaljenim motorom i grejanjem, ne moze se izdrzati duze od 10-15 minuta na vetru od 6-7m i 0 c.
Wish you luck ,less wind and more snow.
Pokrpio trup, promenio stanicu, pa na probni let.
Subota 21. februar 2009.
16,00-17,00
Temperatura 2 stepena, vetar 1-2m/s, slab sneg.
Lokacija , Shodrosh, Novi Sad, kod brodogradilista.
(http://i10.photobucket.com/albums/a150/NS_RC_ELECTRICS/Shodrosh_resize.jpg)
(http://i10.photobucket.com/albums/a150/NS_RC_ELECTRICS/Shodroshpanorama.jpg)
Jedan let od 4-5 minuta, pa sletanje , podesavanje hoda servoa dubine, slomio plasticnu polugicu i kraj za danas.
(http://i10.photobucket.com/albums/a150/NS_RC_ELECTRICS/LazyBee-Shodros-21-2-2009.jpg)
Promenio sam stanicu na LazyBee, umesto Hitec Focus 4, trokanalna Hitec Focus III SS, 72 Mhz, pa je hod kormila dubine bio nedovoljan za potpuno trimovanje, sleteo sam i pokusao da podesim polozaj rucice servoa, ali je smrznuta tanka plastika popustila i slomila se.
Nista, sledeci put bice bolje, bar sam napravio prve letove iznad vodene povrsine, i uspeo da poletim i sletim na prostoru dimenzija 15x50 metara, uz samu obalu.
Slika u letu nema, nije bio prisutan moj zvanicni i najbolji fotograf, Srdjan.
More Winter Flying stories to follow...
Iz treceg pokusaja, danas, 22.2.2009. poleteo LazyBee na skijama.
Cenej, 13,00-14,00, temp 1 stepen, vetar 0-2m/s,5-6 letova od po par minuta, vezbao sletanje i poletanje. Sve radi bez greske, jedino je snega bilo samo u krpama, ali Lazy polece i sa trave sa skijama, zahvaljujuci vernom WELGARDU.
Prvo slikice,
(http://i10.photobucket.com/albums/a150/NS_RC_ELECTRICS/LazyBee-skis-web_1.jpg)
(http://i10.photobucket.com/albums/a150/NS_RC_ELECTRICS/LazyBee-skis-web_4.jpg)
(http://i10.photobucket.com/albums/a150/NS_RC_ELECTRICS/LazyBee-skis-web_2.jpg)
(http://i10.photobucket.com/albums/a150/NS_RC_ELECTRICS/LazyBee-skis-web_3.jpg)
(http://i10.photobucket.com/albums/a150/NS_RC_ELECTRICS/LazyBee-skis-web_5.jpg)
Video to follow, on Youtube...
Bravo Nenad, I see the snow has nearly gone from cenej :mhm
We'll be flying next week oo))
Wait for videos, still uploading two on Youtube, 130 and 109 MB clips.
Cool signature you have :sljus
Just beware of hidden ditch while tug a sleighs with your kids.
(http://i10.photobucket.com/albums/a150/NS_RC_ELECTRICS/WOW_2.jpg)
(http://i10.photobucket.com/albums/a150/NS_RC_ELECTRICS/WOW_1.jpg)
Thanx to Momchilo and the Cheney team, we are at home, not on the Cheney now.
Ako narod trazi skije, dobice skije...
http://www.youtube.com/watch?v=V7aKBT_wLiY (http://www.youtube.com/watch?v=V7aKBT_wLiY)
:)aplauz Nenade,
ovo se zove u zadnji cas, taman je ostalo toliko snijega da ih isprobas ;D
Hats off to you Nenad.
Kad ja sam savršeo moj skis, sneg veravatno idi.
Lazy bee je brzo, nije 'lazy'
Klizavo...
http://www.youtube.com/watch?v=H4vhZK2eO3s (http://www.youtube.com/watch?v=H4vhZK2eO3s)
I jos jedan kratak, pa da zavrsimo sa ovim skijanjem, i ostalim nepodobstinama.
http://www.youtube.com/watch?v=Fw3NCnSbjzY (http://www.youtube.com/watch?v=Fw3NCnSbjzY)
