💬 DISKUSIJA => 🌿 LIVADA => Topic started by: jake87 on October 15, 2012, 01:03:14 PM
Title: Rc Sub
Post by: jake87 on October 15, 2012, 01:03:14 PM
Vec neko vreme razmisljam da napravim podmornicu na daljinski...
Kao ovo na primer
Underwater Video RC Submarine - U-Boat Hunts Aircraft Carrier (http://www.youtube.com/watch?v=6Tb1ignakMM#)
Najvise me interesuju WWII nemacke podmornice.
Za sada je plan da kupim maketu revell i da u nju ugradim wtc.
Interesuje me da li je neko razmisljao na ovu temu?
I ako imate neke ideje pisite slobodno.
Pozdrav Nikola
Title: Re: Rc Sub
Post by: sasa on October 15, 2012, 03:18:15 PM
El ce na nuklearni pogon da bude  :hehe
Title: Re: Rc Sub
Post by: Anakin on October 15, 2012, 07:51:19 PM
Mislim da to neće piti vodu... tačnije, u ovom slučaju hoće, al' bukvalno... Znači generalno neće... ")
:big smile
Title: Re: Rc Sub
Post by: jake87 on October 16, 2012, 08:52:31 AM
Quote from: sasa on October 15, 2012, 03:18:15 PM
Posto mi se najvise svidjaju podmornice iz drugog svetskog rata pogon ce biti na dizel.  :)
Quote from: Anakin on October 15, 2012, 07:51:19 PM
:big smile
Sto mislis da je neizvodljivo?
Title: Re: Rc Sub
Post by: IvanGrozni on October 16, 2012, 06:40:36 PM
A kako misliš da upravljaš njome, ako je pod vodom??? Kako ćeš videti kuda ide??  mmmm
Title: Re: Rc Sub
Post by: jake87 on October 16, 2012, 07:02:08 PM
Ici ce malo ispod povrsine vode. Plus planiram da ugradim i par led doida koje bi povecale vidljivost i orjentaciju kada je pod vodom
Title: Re: Rc Sub
Post by: miša2002 on October 16, 2012, 10:45:48 PM
 mmmm Teško da će ti diode pomoći pogotovo pri "svetlom" nebu i mutnoj vodi, pa čak i u izuzetno bistroj vodi...
Najbolje je da je vežeš na kanapče...  :_D  oo))
:sljus a kanapče na sistem za "spašavanje"...
Title: Re: Rc Sub
Post by: Anakin on October 17, 2012, 10:42:23 AM
Quote from: jake87 on October 16, 2012, 08:52:31 AM
:big smile
Ne mislim da je neizvodljivo ali mi logika, posto iskustva nemam, kaže sledeće. Revell proizvodi makete (kao i onajčijeseimenepominje  :big smile). Znači jedini uslov koji treba da ispuni je da je što vernija u odnosu na original i da izgleda što autentičnije. I tu svaka priča staje. Tamo niko ne vodi računa da li je vodootporna, gde joj je težište (pretpostavljam da i podmornica ima negi CG), gde su predviđeni servoi, gde motor, prijemnik itd... Znači trebaće ti gomila posla, prepravki, para i velika je verovatnoća da će ispuniti jedan jedini uslov, a to je da će otići pod vodu.
Samo se ti smej ali ovo se testira već godinama i daleko je doguralo.  :mhm
(http://www.corbisimages.com/images/Corbis-IH081521.jpg?size=67&uid=4a5cc6ac-f9f5-4da1-bfba-c6cb65bdb6d4)
Možda ćemo jednog dana pred početak sezone da napunimo "bateriju" i to će biti to za celu godinu a Magic ce da nas savetuje da li su bolji fisioni ili fuzioni reaktorčići i koju elisu na reaktor od 3 mikrotona.  :big smile
Title: Re: Rc Sub
Post by: jake87 on October 17, 2012, 11:14:47 AM
Plan je da se u trup ugradi vodonepropusna cev ili ti WTC u kojoj ce da se nalazi komplet elektronika i balast a model sluzi kao skoljka da bi sve to izgledalo sto realnije...
(http://i122.photobucket.com/albums/o254/alnuci/100_2135.jpg)
(http://richard.conte1.free.fr/Divers/AnnonceEbay/DSC02901.JPG)
Title: Re: Rc Sub
Post by: Anakin on October 17, 2012, 11:46:09 AM
Jbg, mene WTC asocira na World Touring Car a za ovo nikad čuo nisam. Eto, naučio sam nešto novo, hvala. Kako se tu rešava antena, jel smeta voda i, pretpostavljam da takva podmornica može da roni na uvek istoj dubini? Šta ćeš sa bojama, sumnjam da će one standardne da ostanu na podmornici nakon zaranjanja. Gde ćeš da nađeš maleni šampanjac da ga razbiješ pre zaranjanja? :big smile
Title: Re: Rc Sub
Post by: IvanGrozni on October 17, 2012, 12:09:39 PM
Ma kakva dubina Anakin. Pa kako ćeš ga videti u vodi, ako zaroni na 30cm? Jedino u nekom bazenu, manje dubine, do 2m i ako su pločice svetle boje. U jezeru sumnjam da bi se videla podmornica na toj dubini.
Jake87
Meni i dalje nije jasno kako će se upravljati tom podmornicom pod vodom, čak i ako je blizu površine?
Uostalom šta će se tu videti. A ako bude delom iznad površine vode, onda pravi neki čamac.
Title: Re: Rc Sub
Post by: jake87 on October 17, 2012, 12:11:37 PM
Quote from: Anakin on October 17, 2012, 11:46:09 AM
Mene WTC asocira na "world trade center"... Sto se antene tice i ona ce biti spakovana u wtc celom duzinom, a sto se frekfencija tice 2.4 ne radi pod vodom tako da ta opcija propada. Sto se poniranja tice moci ce da zaranja i uzranja u mestu tzv static dive. Plan je da se ugradi mehanizam koji ubacuje i izbacuje vodu kako bi mogla da plovi pod vodom i na vodi. Imace cetri kanala: dva za pravac, jedan za gas i jedan za balast rezervoare. A sto se boja tice o tome nisam razmisljao jer to dolazi na kraj a jos sam u fazi razrade plana.  :mhm
Title: Re: Rc Sub
Post by: Anakin on October 17, 2012, 12:17:47 PM
Ako turiš vodootpornu cevku ili ti WTC, gde će ići rezervoari za tu vodu koja će da zaranja makinu? Na slikama koje si postavio ne izgleda mi da baš ima mesta... Sem ako nisu počeli da prave makete u razmeri 1:1, 1:2 i sl.
Ivane, ja to pitam čisto iz radoznalosti, ne mogu ti objasniti koliko mislim da je ista uzaludna i dosadna ali to je lično mišljenje.
Title: Re: Rc Sub
Post by: miša2002 on October 17, 2012, 03:28:12 PM
@jake87
Vidim da si se baš naložio na podmornicu-e i da nisi došao do konkretnih rešenja, primenjljivih u praksi.
U prethodnom postu sam ti, na šaljiv način, rekao mnogo, tj najjednostavniji način rešenja glavnog problema - daljinskog upravljanja ! Sve ostalo je, relativno, lako rešivo !
Drugi, veći problem, je dihtovanje tj zaptivanje. Do jednog metra i nije baš veliki problem, a preko toga je već malo problematično.
Da ne dužim mnogo priču, za plovidbu po površini - nema problema, za plovidbu na periskopskoj dubini -  pa i nema problema. Znači problemi nastaju sa povećanjem dubine.
"Kanapče" je koaksijalni vod do antene (cca 80cm), a ona se nalazi u hermetičkoj kapsuli, ispunjenoj helijumom !
Za kapsulu je vezan sigurnosni "kanapčić" (cca 79cm) i drugim krajem za, sigurnosni, "kilo-prekidač",a on aktivira sistem za spašavanje... To da ne kupuješ i ronilačku opremu.  :_D
Za stabilno uranjanje i izranjanje, potrebno ti je minimalno dva dvodelna tanka i kanari napred... A da bi stabilno plovio-"ronio" moraš imati i sistem za stabilizaciju (recimo, kao "gyro" na heliikopterima) !...
Itd, itd, itd,..
Title: Re: Rc Sub
Post by: zajo on October 18, 2012, 10:47:59 PM
Znaci i mene zanima proekt. Ako si resio samo napred ali ocigledno neces naci puno pomoci ovde  (nene). Nije da je RC podmornica nova stvar.,ljudi to voze godinama. Samo to da uzmes maketa pa od nju da nesto smuckas mislim da je sigurno losa varianta. Bolje da uzmes podmornicu trener neki  lol nesto sto vec funkcionise pa da od tamo krenes. U svaki slucaj samo napred  (pijemo) (pijemo)
Title: Re: Rc Sub
Post by: matovic on October 18, 2012, 11:22:31 PM
Kako se prica odvija sve mi je interesantnije... prvo sto mi je palo na pamet kad sam video topic je "kako ces da upravljas, tj. da vidis kuda vozis" !? :) misa je pre mene vec to pomenuo, do 1m dubine ajd jos i moze da se vidi ali nije to interesantno... a malo dublje tu vec bez FPV nema nekog smisla... a opet tu je i pritisak  (:sok:)
Nemam sta pametno da kazem sem da bi zaista voleo da vidim da ovako nesto napravis... montiras neku gopro kameru + FPV, pa to bi bili fenomenalni snimci nekog koralnog grebena  :)aplauz
Samo napred!!!
Title: Re: Rc Sub
Post by: Anakin on October 18, 2012, 11:26:06 PM
Quote from: zajo on October 18, 2012, 10:47:59 PM
:_D Legendo, slatko sam se nasmejao.  (res)
Title: Re: Rc Sub
Post by: magic on October 19, 2012, 12:06:40 AM
A moze i ovako
http://www.der-schweighofer.at/artikel/69244/sb_neptune_sb-1_u-boot_rtr (http://www.der-schweighofer.at/artikel/69244/sb_neptune_sb-1_u-boot_rtr)
ili ovako
http://rcmodelsubmarines.co.uk/# (http://rcmodelsubmarines.co.uk/#)
Title: Re: Rc Sub
Post by: sasa on October 19, 2012, 12:34:10 AM
Quote from: Anakin on October 18, 2012, 11:26:06 PM
Pa sta se smejes  (kush) naravno da mora prvo neku trener  :_D ,a posle moze i akrobatsku  :sljus mmmm
Title: Re: Rc Sub
Post by: jake87 on October 19, 2012, 12:43:15 AM
Sto se upravljanja tice icice malo naprad, malo nazad, pa malo zaroni i tako u krug...  :_D Kada je na periskopskoj dubini za sobom ostavlja trag koji se vidi na povrsini vode. Po meni najveci izazov napraviti nesto svoje sto je funkcionalno i sto ce biti sto blize "scale" izgledu. Performanse su nebitne jer da sam hteo da to ide brzo, skace, prevrce se, leti , pada... Napravio bih nesto drugo. Naravno da mora da padne i neka go pro kamerica kako bi se uhvatili dobri kadrovi i to sve izmontiralo u jedan fini klipcic i zakacilo na you tube  :big smile A pravo da vam kazem jos kao mali sam bio impresioniran podmornicama i ovo je i neki nacin da ostvarim decacki san da napravim jednu bas kako sam je zamisljo tada... Sto se materijala za citanje i izradu toga sam skupio jedno par gigabajta tako da se oko toga ne brinem puno. Postavio sam temu na ovom forumu ne da bih nasao resenja nego da vidim kako ljudi razmisljaju, jer se na ovu temu nije pisalo na ovom forumu. I za Kraj...
(http://img.alibaba.com/photo/111635530/RC_Typhoon_submarine.jpg)
(http://i00.i.aliimg.com/photo/v0/111635516/RC_Typhoon_submarine.jpg)
(http://img225.imageshack.us/img225/5839/torp041.jpg)
(http://i242.photobucket.com/albums/ff272/Salvadormoron/DSC049480.jpg)
Title: Re: Rc Sub
Post by: miša2002 on October 19, 2012, 02:47:25 AM
Ja mislio da si rešio da praviš nešto, kad ono (http://img.alibaba.com/photo/111635530/RC_Typhoon_submarine.jpg)
Evo je stigla kući...(http://i1114.photobucket.com/albums/k531/misha2002/BRODOVI-PODMORNICE/RC_Typhoon_submarine.jpg)
No, svejedno, evo par slikica, od pre neku godinu, i zamal da se naložim ...
(http://i1114.photobucket.com/albums/k531/misha2002/BRODOVI-PODMORNICE/tv2bf.jpg) (http://i1114.photobucket.com/albums/k531/misha2002/BRODOVI-PODMORNICE/electro2eb.jpg) (http://i1114.photobucket.com/albums/k531/misha2002/BRODOVI-PODMORNICE/electro2cd.jpg) (http://i1114.photobucket.com/albums/k531/misha2002/BRODOVI-PODMORNICE/electro2cc.jpg) (http://i1114.photobucket.com/albums/k531/misha2002/BRODOVI-PODMORNICE/electro2ca.jpg) (http://i1114.photobucket.com/albums/k531/misha2002/BRODOVI-PODMORNICE/electro2bd.jpg) (http://i1114.photobucket.com/albums/k531/misha2002/BRODOVI-PODMORNICE/electro2bc.jpg) (http://i1114.photobucket.com/albums/k531/misha2002/BRODOVI-PODMORNICE/electro2bb.jpg) (http://i1114.photobucket.com/albums/k531/misha2002/BRODOVI-PODMORNICE/electro2ba.jpg) (http://i1114.photobucket.com/albums/k531/misha2002/BRODOVI-PODMORNICE/electro2a.jpg) (http://i1114.photobucket.com/albums/k531/misha2002/BRODOVI-PODMORNICE/electro1g.jpg) (http://i1114.photobucket.com/albums/k531/misha2002/BRODOVI-PODMORNICE/electro1f.jpg) (http://i1114.photobucket.com/albums/k531/misha2002/BRODOVI-PODMORNICE/electro1c.jpg) (http://i1114.photobucket.com/albums/k531/misha2002/BRODOVI-PODMORNICE/electro2ee.jpg) (http://i1114.photobucket.com/albums/k531/misha2002/BRODOVI-PODMORNICE/radio3c.jpg) (http://i1114.photobucket.com/albums/k531/misha2002/BRODOVI-PODMORNICE/radio3d.jpg) (http://i1114.photobucket.com/albums/k531/misha2002/BRODOVI-PODMORNICE/radio3f.jpg) (http://i1114.photobucket.com/albums/k531/misha2002/BRODOVI-PODMORNICE/radio5a.jpg) (http://i1114.photobucket.com/albums/k531/misha2002/BRODOVI-PODMORNICE/radio5b.jpg) (http://i1114.photobucket.com/albums/k531/misha2002/BRODOVI-PODMORNICE/radio5ba.jpg) (http://i1114.photobucket.com/albums/k531/misha2002/BRODOVI-PODMORNICE/radio5c.jpg) (http://i1114.photobucket.com/albums/k531/misha2002/BRODOVI-PODMORNICE/radio5d.jpg) (http://i1114.photobucket.com/albums/k531/misha2002/BRODOVI-PODMORNICE/radio5e.jpg) (http://i1114.photobucket.com/albums/k531/misha2002/BRODOVI-PODMORNICE/electro1b.jpg)
(http://i1114.photobucket.com/albums/k531/misha2002/BRODOVI-PODMORNICE/tv2c.jpg) (http://i1114.photobucket.com/albums/k531/misha2002/BRODOVI-PODMORNICE/tv2be.jpg)
Title: Re: Rc Sub
Post by: jake87 on October 24, 2012, 05:16:16 PM
Jel zna neko gde ima da se kupi pleksi cev spoljneg precnika 50mm i debljine zida 2-3mm?
Title: Re: Rc Sub
Post by: danko on October 24, 2012, 05:40:52 PM
Quote from: jake87 on October 24, 2012, 05:16:16 PM
http://www.plexiglaspromet.co.rs/ (http://www.plexiglaspromet.co.rs/)
Title: Re: Rc Sub
Post by: jake87 on October 24, 2012, 05:44:23 PM
Quote from: danko on October 24, 2012, 05:40:52 PM
Hvala Pozdrav
