🧰 GRADNJA & TEHNIKA => ⚡ ELEKTRONIKA & OPREMA => BATERIJE i PUNJAČI => Topic started by: zajo on November 02, 2012, 05:36:24 PM
Title: najbilja 2200 3s baterija
Post by: zajo on November 02, 2012, 05:36:24 PM
Koja je najbolja 3s 2200 lipo pored vas iz hobby king?
Title: Re: najbilja 2200 3s baterija
Post by: disljenko on November 02, 2012, 06:42:42 PM
Ja mislim da su Rhino baterije za nijansu bolje o drugih brendova sa HK.
Post by: zbabic on November 02, 2012, 07:47:00 PM
Jos jedan glas za Rhino.
Post by: grebic on November 02, 2012, 09:16:20 PM
ove su mi bile najbolje
http://www.hobbyking.com/hobbyking/store/__9318__Rhino_2150mAh_3S_11_1v_30C_Lipoly_Pack.html (http://www.hobbyking.com/hobbyking/store/__9318__Rhino_2150mAh_3S_11_1v_30C_Lipoly_Pack.html)
veceg kapaciteta su nesto teze
Post by: zajo on November 03, 2012, 01:20:04 PM
Merio sam, motor vuce 30A. Mislite da je 30c dovoljno?
Post by: matovic on November 03, 2012, 01:45:06 PM
Quote from: zajo on November 03, 2012, 01:20:04 PM
2200 mah * 30C = 66A u teoriji
Dovoljno  (pijemo)
Post by: grebic on November 03, 2012, 03:42:11 PM
Ja nesto ne verujem tim brojkama. Racun je lep, ali tako *ugrubo* gotovo uvek nepouzdan. Kada bi to bilo tako jednostavno, sve bi bat bile iste. A u praksi su razlike ogromne. (istih karakt a razlicitih proizv) NIje uvek u dvoristu ono sto pise na tarabi.
Ja sam ih koristio za setup koji vuce 45A i nisam imao problema
Post by: zajo on November 03, 2012, 05:59:23 PM
Super  (pijemo) sta bi bez vama :)
RHINO forever :)
Post by: vlada-r on November 03, 2012, 08:52:10 PM
Neces pogresiti i ako uzmes 35 ili 40C, od viska glava ne boli (bar u ovom hobiju). Manje ce baterija da se naduvava.
Post by: matovic on November 03, 2012, 09:22:22 PM
Jeste, ni ja neverujem svemu sto pise zato sam i rekao "66A u teoriji" :)....  u svakom slucaju 100% dovoljno za 30A setup.
HK je generalno macka u dzaku sto se tice baterija, sve se svodi na to sta ti zapadne jer im je kontrola kvaliteta na minimumu. Iz licnog iskustva, zippy 5000mah 20C sam vozio u setup-u od 150A i bile su poprilicno vrele posle voznje ali nisu naduvale niti im je ista falilo posle toga... a opet sa druge strane u istom setup-u vozim nano-tech 5500mah 65C i posle par ciklusa su naduvale.
Sve u svemu za te pare realno ne postoji bolje  :big smile
Post by: dejanxx on November 03, 2012, 10:41:15 PM
Ja sam isto imao problem sa nano tech, duvaju se posle par ciklusa, a zippy 3s 5000mah 20c bez ikakvih problema koristim i sto je jos bitnije sve celije su apsolutno istog napona, odusevile su me...
Post by: vlada-r on November 04, 2012, 11:21:51 AM
Da bi baterije duze trajale drzite ih u frizideru, ne opada napon ni posle 15-20 dana nekoriscenja. I nece da se same do sebe naduvaju kao kad su na sobnoj temperaturi.
Post by: magic on November 04, 2012, 11:51:14 AM
Quote from: vlada-r on November 04, 2012, 11:21:51 AM
Vrlo parcijalan komentar. U kom stanju, prazne, pune, za duzi ili kraci vremenski period ...?
Ja sam protiv drzanja u frizideru jer svaka termicka promena ne prija.
Najbitnije od svega je da ih nepraznite preko 80% nominalnog kapaciteta, idealno 60%.
Post by: tibeteagle on November 04, 2012, 01:07:56 PM
Ako ćemo o tome koja je najbolje iz HK bez obzira na cenu, onda mislim i provereno da je Polyquest (http://www.hobbyking.com/hobbyking/store/uh_listCategoriesAndProducts.asp?idCategory=217).
Imam jedan primarak od 1800mAh 3S od pre 5 godina, kao i mnoge druge iz HK. U izdržljivosti, trajnosti, kapacititetu je veoma dobar. Ni danas ni jedan mehurić nema. Prave se u Južnoj Korei, pa je zato skuplji od ostalih. Veliki broj drugih brendova se proizvodi u Južnoj Korei. Ali ipak kineski novije generacije nisu toliko lošiji, koliko su jeftiniju, pa je odnos cene i kvaliteta na strani Kineze.
Post by: vlada-r on November 04, 2012, 01:59:17 PM
Ovo je tema kojoj nema kraja, svako od nas ima razlicita iskustva sa baterijama koje koristi. Kod nekog se odredjena baterija pokazala dobra a kod nekog ne, od nacina punjenja, procenta iskoriscenja pa do skladistenja. Koristi bateriju kako si navikao da koristis, a vreme ce pokazati da li to pravilno radis ili ne.
Post by: ak on November 04, 2012, 06:23:55 PM
Quote from: dejanxx on November 03, 2012, 10:41:15 PM
Da potvrdim, nano-tech se definitivno lakse naduvaju. Bolje drze napon od zippy-a (3S od 2200mah sam poredio) na opterecenju ali redovno rikne jedna od celija.
Od 4 kupljene 4S 3300mah i 4S 3000mah dve su se nadule posle 10-15 ciklusa a nisu bile praznjene ispod 3.6V po celiji.
Post by: zajo on November 08, 2012, 10:16:31 AM
Quote from: ak on November 04, 2012, 06:23:55 PM
+1 vec sam pisao- i mene nanotech su se nadule dok rhino ne. Sto se tice polyquest, momentalno nemaju skoro nista, vidi se da je ostavstina. Mada nasao sam ovo   http://www.hobbyking.com/hobbyking/store/__5718__Polyquest_2550mAh_3S_25C_Lipoly_Version_2_.html (http://www.hobbyking.com/hobbyking/store/__5718__Polyquest_2550mAh_3S_25C_Lipoly_Version_2_.html)   neke 5-7 usd skuplje, samo 25c, veceg kapaciteta a tezina ista sa 30c 2250 rhino  mmmm
