Da li neko ima iskustva sa nekim simulatorom po mogucnosti g4 i sa stanicom futaba 9c koja ima cinc kao za slusalice 3,5mm.
da li neko ima cd sa tim simulatorom
hvala unapred
NapiÃ...¡i mi adresu i poslaÃ,,‡u ti DVD sa G4 simulatorom. Ako imaÃ...¡ USB interfejs nije nikakav problem da prikljuÃ,,ÂiÃ...¡ svoju Futabu na PC, a ako nemaÃ...¡ probaj ovako http://www.flyfreak-hr.org/phpBB2/viewtopic.php?t=6054 (http://www.flyfreak-hr.org/phpBB2/viewtopic.php?t=6054)
Nikola
treba mi neki simulator za letenje-kupio sam eisy cub (multiplex) gde mogu da ga nađem
http://www.der-schweighofer.at/artikel/70011/real_flight_g4.5_mode_2_mit_handsender (http://www.der-schweighofer.at/artikel/70011/real_flight_g4.5_mode_2_mit_handsender)
http://www.der-schweighofer.at/artikel/58584/aerofly_professional_deluxe__und__usb_interface__inkl._addon_1__2_und_3 (http://www.der-schweighofer.at/artikel/58584/aerofly_professional_deluxe__und__usb_interface__inkl._addon_1__2_und_3)
http://www.der-schweighofer.at/artikel/73836/easyfly_2_upgrade-cd_auf_easyfly_3 (http://www.der-schweighofer.at/artikel/73836/easyfly_2_upgrade-cd_auf_easyfly_3)
http://shop.lindinger.at/product_info.php?products_id=75161 (http://shop.lindinger.at/product_info.php?products_id=75161)
itd...
Da li je ovo zimski san svakog modelara- audio to usb konverter?
(http://media.conrad.de/xl/8000_8999/8700/8700/8709/870983_RB_00_FB.EPS.jpg)
http://www1.conrad.de/scripts/wgate/zcop_b2c/~flN0YXRlPTcwMzgxMjc5OA==?~template=PCAT_PRODUCT_DETAILS_DOCUMENT&p_page_to_display=fromoutside&zhmmh_area_kz=U0&product_show_id=0000000000000000000000000000000000870983 (http://www1.conrad.de/scripts/wgate/zcop_b2c/~flN0YXRlPTcwMzgxMjc5OA==?~template=PCAT_PRODUCT_DETAILS_DOCUMENT&p_page_to_display=fromoutside&zhmmh_area_kz=U0&product_show_id=0000000000000000000000000000000000870983)
Ovako uzeo sam SAPAC FT06-B koja ima izlaz banana 3,5mm!imam i banana-banana kablic...dakle MOLIM VAS(kao sto rece gospodin MAT) ako bi neko bio ljubazan da mi nareze CD sa simulatorom ili pusti link za skidanje...i malo detaljnjije objasni kako da povezem stanicu a da sve to radi...Vozio sam G3 na tastaturi i poprilicno lako i vozim i slecem kapiram da ce sa stanicom u pocetku biti mnoooogooo teze...sta i kako sa programima...ja sad kao nesto pokusavam...ali pomoc mi svakako treba!!!
Unapred HVALA!
Ja cu ti narezati DVD, na Vracaru sam pored Hrama, dodji kada hoces po njega 011/2456116, Marko.
Hvala Marko!!!Zovem te ovih dana pre nego sto krenem da vidim dal si kuci!!!
I jos jedno pitanje sastavljeno iz bezbroj pitanja...Znaci kada upalim stanicu,prikacim je na mic ulaz i odmutiram ga i pomeram joy na stanici menja se zvuk na zvucniku...Sto znaci da stanica radi...da ulaz za mic radi...Sve radi...Valjda je tako...E sad skino sam FMS beta 7 ili tako nesto posto sam procitao da je free i da moze sa stanicom da se igra za razliku od demo G3...i pored toga jos sam skinuo PPJoy i SSPConsole...i sta sad da radim...Sve sam pokusavao i nista...NECE!!!SOS SOS SOS
Vidi, ja koristim jednu malu spravicu , sa jedne strane je jack za stanicu, a sa druge USB.
Za igranje mi je potreban samo klasican crack, EMULATOR, i u njemu imaju sva podesavanja.
Stanica mora da je ukljucena sve vreme dok igram, a pre nego sto krenem da igram moram da podesim stanicu u control panel-game controlers-i onda kontroler koji koristim.
Kada podesis igricu i emulator, njih vise ne moram da cackam, ali svaki put kada ukljucim kompjuter moram da podesim u control panelu stanicu.
Znam za taj usb dongl ali on kosta bar 20 evra a ovo je sve za dz...mada dal ovoliko jeb (___) vredi 20e?!?ako se neko ne javi u skorije vreme sa resenjem za moj problem ne preostaje minista drugo...USB
na sledecoj adresi imas uputstvo
http://www.geocities.com/shaul_ei/SmartPropoPlus.html (http://www.geocities.com/shaul_ei/SmartPropoPlus.html)
klikni na step-by-step kao sto kaze korak po korak
takodje imas i kako se povezuju konektori itd
hvala kizmaj resio sam pomocu ovoga sinoc...sa FMS sljaka skroz ok videcu kako je kod ostalih simulatora...pozz
Da li je neko pokusao da izvuce konektor iz stanice, koja inace nema adekvatan port, za audio ulaz (mikrofon) na PC-u mozda?
Cao ljudi.
Mozda neko zna resenje,problem se javlja kada pokrenem G4 :(
Bem ti EMU :sljus Problem resen. Hvala srdjan012 :)
kupio na ebayu za 2.5eura kabel i radi gotovo sa svim stanicama
dobio sam 5-6 nastavaka trenutno ga koristim s dx6i
