🛩️ MODELI => 🚀 Dronovi & FPV => Topic started by: bandit89 on December 07, 2012, 10:16:02 PM
Title: pomoc oko tricoptera
Post by: bandit89 on December 07, 2012, 10:16:02 PM
cao svima
evo ovako imam problem oko tricoptera konkretno ne mogu da ga nastelujem sta god da uradim podize rep
kapiram da ako nastelujem drugacije da ce podizati prednji deo ne  kako god nastelujem on podize rep znacci motor na repu radi brze
eto to je ukratko i najprostije kako sam mogao da vam objasnim svoj problem
ovo mi je prvi tricopter ruku na srce i ne razumem se toliko u ove spravice  .
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=6247&aff=61689 (http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=6247&aff=61689)
http://www.hobbyking.com/hobbyking/store/__13429__HobbyKing_30A_BlueSeries_Brushless_Speed_Controller.html (http://www.hobbyking.com/hobbyking/store/__13429__HobbyKing_30A_BlueSeries_Brushless_Speed_Controller.html)
http://www.multircshop.com/site/index.php?route=product/product&product_id=591 (http://www.multircshop.com/site/index.php?route=product/product&product_id=591)
Title: Re: pomoc oko tricoptera
Post by: kole_niš on December 08, 2012, 12:19:15 AM
reverse pitch gyro
pozz
Post by: bandit89 on December 08, 2012, 10:09:27 AM
Ostavi mi mail ili broj ako mozes.
Post by: bandit89 on December 08, 2012, 08:06:38 PM
Ja stvarno neznam kako da uradim ovo, ako mozes malo jasnije da mi objasnis bio bih ti zahvalan.  :-[
Post by: gizmo on December 08, 2012, 10:24:23 PM
Nisam nikad imao KK, ali mozda ovde nadjes resenje
http://www.fpvpilot.com/Pages/MulticopterBoard.aspx (http://www.fpvpilot.com/Pages/MulticopterBoard.aspx)
Post by: bandit89 on December 08, 2012, 11:42:36 PM
ovaj klip sam vec gledao moja kartica u opste ovako ne radi probao sam ovo 100x
na mojoj kartici ima jos 1 opcija kako shto je yaw roll i pitch
zove se GYURO REF VOLTAGE Adj-vref cemu ona sluzi ?????
Post by: vpilic on December 09, 2012, 12:40:41 AM
Stavi koju sliku:
Stanicu koju koristis
KK kartice
Smer motora
A jos bolje snimi i postavi na youtube
Pozz..
Vladimir
Post by: bandit89 on December 09, 2012, 01:36:12 PM
Ovo sam ja pravio nije nesto ali bar lici na tricopter.
(http://s16.postimage.org/3otndvlvp/black_tri.jpg)(http://s16.postimage.org/3q3l7anph/DSCN0307.jpg)
(http://s16.postimage.org/up7g2ga6d/DSCN0309.jpg)(http://s16.postimage.org/pf2hb5pxh/DSCN0312.jpg)
Post by: gizmo on December 09, 2012, 01:41:41 PM
 mmm  mmmm ako se dobro secam mog prvog trikoptera mislim da bi motori 1 i 2 trebali da se vrte u istom smeru, a motor 3 (yaw) u suprotnom.
Post by: bandit89 on December 09, 2012, 10:46:33 PM
a cekaj dali  mozes da postavis smer okretanja kakav ti hoces ili to zavisi od onog programiranja (firmware)
Post by: gizmo on December 09, 2012, 10:50:03 PM
Naravno da mozes. Samo zameni dve zice koje idu od esc-a do motora.
Post by: bandit89 on December 10, 2012, 10:17:22 AM
znaci ono programiranje nema veze sa tim smerovima motora
probao sam ja druze i povezao sva tri motora da se okrecu u istom smeru cito da probaM I opet nista jaci je rep tj zadnji motor okrece brze
Post by: vpilic on December 10, 2012, 11:18:09 AM
Jesi li uradio kalibraciju na sva tri ESC-a?
Vidi ako mozes postavi snimak da vidimo sta se desava.
Pozz
Post by: kole_niš on December 22, 2012, 08:14:13 PM
Sale, sređen Tricpter, sad leti ko zmaj! Slabiji je malo snimak, pošto smo snimali telefonom... Srećno!
http://youtu.be/uPOkW7YKxJo (http://youtu.be/uPOkW7YKxJo)
Post by: Vaci on December 22, 2012, 08:31:49 PM
I bandit89 je Nislija? Ne znam zasto niko u profilu ne stavlja odakle je....
Jedva cekam da vam se pridruzim... ne znam nikog ko je cekao na delove iz HK ovoliko kao ja :(
Post by: djbojan on December 22, 2012, 10:06:26 PM
Quote from: kole_niš on December 22, 2012, 08:14:13 PM
Opa bato !  Pa si si bre kole postao opasan multirotoraš  :)aplauz  Samo moras preci cifru od 4, bar 6 ili okto.  ()-()
Post by: kole_niš on December 22, 2012, 11:03:00 PM
Bandit  se zaglavio negde sa Tricopterom, pa smo se odmrsili, sada je ok. Sledeći projekat: pooooooooopravljam kišobrane oo))
Post by: tibeteagle on December 23, 2012, 03:21:46 PM
Quoteprobao sam ja druze i povezao sva tri motora da se okrecu u istom smeru cito da probaM I opet nista jaci je rep tj zadnji motor okrece brze
Smerovi okretaja prednjih elisa moraju imati suprotne smerove okretaja, kao po šemi na slici od gore. Trebaš imati i takve elise, levu i desnu. Ovo ne zavisi od slobodne volje, već od zakonisosti mehanike. Zadni motor može u oba smera da se okreće, jer njegov obrtni momenat kompenzuje komponenta horizontalne sile, koja nastaje od ugla ose motora i kraka nosača. Znači osa zadnjeg motora, čak i u letenju u mestu, odstupa od predljih i to znatno za oko 5%. To treba da odredi upravljačka elektronika preko servoa koji menja taj ugao motora. Ovaj slučaj je samo kod trikoptera. I iz ovog aspekta kvadrokopter je bolji.
Predajnik ti definitivno ne valja za mikrokoptere. Mislim na skromnu ili nikakvu mogućnost podešavanja i sigurnost.
Post by: kole_niš on December 31, 2012, 12:09:59 AM
Bolje je po nekima da se sva 3 vrte u smeru suprotnom od kazaljke na satu, daleko su stabilniji. Opet, zavisi od firmware-a i od pilota ...
Post by: tomaja on January 17, 2013, 12:04:24 AM
Pozdrav!
Čestitam na uspešnom letu. Stvarno izgleda izuzetno stabilno.
I ja sam počeo sa nabavkom delova za trikopter (radim po uzoru na http://rcexplorer.se/projects/2011/09/the-tricopter-v2-5/ (http://rcexplorer.se/projects/2011/09/the-tricopter-v2-5/) samo sam kupio KK2, nadam se da to nije greška). I ovaj bandit89-ov dosta liči na rcexplorer 2...
Prvi put ću praviti i leteti RC letelicu, trikopter mi nije delovao kao previše težak zadatak  mmmm, da li grešim? Ako grešim, šta mi je bolje za početak?
Trenutno vežbam pomoću simulatora(TGY9x + FMS)
Nadam se da ćete mi pomoći kad zagusti :)
