🛩️ MODELI => TRENAŽNI MODELI => Elektro => Topic started by: radisa.radic on May 23, 2013, 05:05:23 PM
Title: pomoc pocetniku
Post by: radisa.radic on May 23, 2013, 05:05:23 PM
Pozdrav pre svega ljubiteljima ovog hobija . Poceo sam da se i ja malo zanimam ovim hobijem pa posto sam totalni pocetnik napravio sam jedan trenazni model ali imam par nedoumica na motoru mi nema nikakve oznake pa neznam dali je to mnogo bitno okacicu slike modela pa ako neko moze da mi pomogne.Nmogu da ubacim slike u pitanju je model TUFFY A MOTOR JE BIO NA MODELU TESKOM OKO 1000 GRAMA SAMO STO JE ELISA BILA MNOGO VECA NEGO SADA.Neznam dali ce moci da ga odrzi u vazduhu to jest dali ima dovoljno potiska .
Title: Re: pomoc pocetniku
Post by: magic on May 23, 2013, 05:43:57 PM
Radisa dobrodosao. Ako je tvoj model slicne tezine kao onaj na kom je motor prethodno bio onda to moze da prodje pod uslovom da stavis istu elisu i bateriju koja je terala i prethodni model, u suprotnom mi treba mnogo vise podataka vezano za motor i pogonsku bateriju koju planiras.
Post by: radisa.radic on May 23, 2013, 05:57:15 PM
Pre svega hvala na brzom odgovoru ovaj model je mnogo laksi nego onaj na kom je bio motor planiram elisu 8x4 a bateriju 3s 1000 ukupna tezina je oko 500grama
Post by: magic on May 23, 2013, 07:04:51 PM
A koja elisa i baterija su bili na prethodnom modelu?
Post by: radisa.radic on May 23, 2013, 07:30:16 PM
evo linka koji model sam ja napravio http://www.rcgroups.com/forums/showthread.php?t=1000670&highlight=tuffy (http://www.rcgroups.com/forums/showthread.php?t=1000670&highlight=tuffy) bez elerona a na onom modelu bila je 3s 2200 baterija a elisa 12x4 pozz
Post by: aco on May 24, 2013, 07:58:35 AM
Baterija:   http://www.hobbyking.com/hobbyking/store/__6306__ZIPPY_Flightmax_2200mAh_3S1P_20C.html (http://www.hobbyking.com/hobbyking/store/__6306__ZIPPY_Flightmax_2200mAh_3S1P_20C.html)
Motor:      http://www.hobbyking.com/hobbyking/store/__2106__KD_A22_20L_Brushless_Outrunner_Motor.html (http://www.hobbyking.com/hobbyking/store/__2106__KD_A22_20L_Brushless_Outrunner_Motor.html)
kontroler: http://www.hobbyking.com/hobbyking/store/__2163__TURNIGY_Plush_25amp_Speed_Controller.html (http://www.hobbyking.com/hobbyking/store/__2163__TURNIGY_Plush_25amp_Speed_Controller.html)
stanica:    http://images.rcuniverse.com/art/kits/XP662.jpg (http://images.rcuniverse.com/art/kits/XP662.jpg)
elisa:        http://www.hobbyking.com/hobbyking/store/__8033__Master_Airscrew_propeller_11x6.html (http://www.hobbyking.com/hobbyking/store/__8033__Master_Airscrew_propeller_11x6.html) -- stim da smo probajuci predhodni model polomili 2 nove apc 11x6 pa smo u nedostatku drugih stavili ovu koja je bila ostecena pa skracena na otprilike 8x6
Post by: radisa.radic on May 24, 2013, 10:55:16 AM
hvala aco na zalaganju valjda cemo ga poleteti....
Post by: Andi on December 16, 2013, 07:43:26 PM
Vozdra raja
Ja sam iz Sarajeva, nazalost u nasoj zemlji nema aktivan forum o modelarstvu, nazalost :( .
Nadam se da to nema veze jer ja i dalje hocu da udjem u ovaj hobi.
Nemam nikakvog iskustva sa avionima ili bilo kojim rc stvarcicama, osim naravno onih autica, ali to je bilo davno prije 5-6 god.
Nego da predjem na stvar.
Znaci hocu da se polako pocnem baviti modelarstvom, gledao sam ovdje teme i cackao i dosao do zakljucka da kupim Bixler v1.1  jer su ga nahvalili i govore kao da je idealan za pocetnike, a i meni se svidja jer mu propeler nije na nosu nego tamo iza i onda ne mogu da ga pokvarim prilikom slijetanja.
Pregledao sam sve epizode od Maher Hangar-a i zaista mi se svidja sve ovo. Prije je izgledalo komplikovano a sad sa vizualnim objasnjenjem je puno lakse.
Kupio bih ovo http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=16544&gclid=COLsyIzgtLsCFWmWtAodYBcAVw
Znaci trebaju mi uz taj model 1. ESC 2. kontroler 3. resiver 4. baterije 5. punjac
Sto se tice kontrolera vidio sam po youtubu da dosta ljudi koristi http://www.hobbyking.com/hobbyking/store/__28494__OrangeRx_T_SIX_2_4GHz_DSM2_6CH_Programmable_Transmitter_w_10_Model_Memory_Mode_2_.html
To je onaj orange rx 6ch.
E sad mozete li mi reci razliku izmedji njega i ovog
http://www.hobbyking.com/hobbyking/store/__9042__Hobby_King_2_4Ghz_6Ch_Tx_Rx_V2_Mode_2_.html
Vjerovatno je domet, a posto ne vidim nigdje da pise koliki je domet ima li koji forumas da ima oba ili jedan pa da mi kaze utiske...
Ili je najbolje da jednostavno kupim ovaj bixer 2 sa ready to fly
http://www.hobbyking.com/hobbyking/store/__39677__Hobbyking_Bixler_2_EPO_1500mm_Ready_to_Fly_w_Optional_Flaps_Mode_2_RTF_.html
Sad ako je kod ovog transmitera slab domet onda bih prije da uzimam kako sam gore naveo...
To je to sto me interesuje za sad :D
Hvala svim ljudima koji mi odgovore i pomognu da se priblizim modelarstvu
Post by: Gatti.Gatozza on December 16, 2013, 08:01:29 PM
Nemoj da razmišljaš o ovoj stanici bez displeja, jer za bilo kakvo menjanje parametra moraš da je kačiš na kompjuter. Ja je imam i koristim za simulator.
Uzmi ili Orange, ili 9X. Jeftini full range prijemnici... 9X se dosta koristi kod nas, i u principu su ljudi zadovoljni. Za Orange neka kaže neko ko ga je koristio.
Sve navedene stanice i njihovi prijemnici imaju domet koji ti je više nego dovoljan za svaki avion koji letiš na optičkoj vidljivosti. I sa jednom i sa drugom sam leteo jedrilicu od 1,8m na visini gde se ona jedva videla.
