🛩️ MODELI => 🚀 Dronovi & FPV => Topic started by: zloxi on May 11, 2017, 07:06:33 PM
Title: Dobar i jeftin set za pocetnike
Post by: zloxi on May 11, 2017, 07:06:33 PM
Za manje od 100â,¬  :hehe
https://www.banggood.com/Realacc-X210-4mm-Frame-w-F3-6-DOF-Racerstar-BR2205-2300KV-Motor-RS20A-V2-ESC-Kingkong-5X4X3-Prop-p-1076477.html?p=MI02017998062014105Q (https://www.banggood.com/Realacc-X210-4mm-Frame-w-F3-6-DOF-Racerstar-BR2205-2300KV-Motor-RS20A-V2-ESC-Kingkong-5X4X3-Prop-p-1076477.html?p=MI02017998062014105Q)
Sa 30A ESCs 103â,¬ https://www.banggood.com/Realacc-X210-4mm-Frame-w-F3-6-DOF-Racerstar-BR2205-2300KV-Motor-RS30A-V2-Blheli_S-5X4X3-Prop-p-1078118.html?rmmds=detail-left-hotproducts (https://www.banggood.com/Realacc-X210-4mm-Frame-w-F3-6-DOF-Racerstar-BR2205-2300KV-Motor-RS30A-V2-Blheli_S-5X4X3-Prop-p-1078118.html?rmmds=detail-left-hotproducts)
https://www.youtube.com/watch?v=6vLjwNHTmTU (https://www.youtube.com/watch?v=6vLjwNHTmTU)
Title: Re: Dobar i jeftin set za pocetnike
Post by: rajker on May 11, 2017, 09:05:56 PM
i ima da te naguze na carini ,,pa ces platiti jos toliko,,,,, :big smile a mozda se i provuces    mmmm ;namig
Post by: zloxi on May 12, 2017, 12:17:19 AM
Quote from: rajker on May 11, 2017, 09:05:56 PM
Usr'o sam se i jos drhtim uz to :D Nema carine kod mene do 150â,¬ a sve sto je preko 150â,¬... EU shop-ovi odrade svoje ;)
Kome se ne svidja moze da sam mota svoje motore i pravi ramove od stiropora :D  :hehe :_D :hehe :_D
Post by: rajker on May 12, 2017, 12:12:22 PM
Quote from: zloxi on May 12, 2017, 12:17:19 AM
Oket,izvini nisam znao za take velike sume kod carine.
Post by: drej37 on May 13, 2017, 07:49:01 PM
Odličan setup !
Do sad sam tri poručio iz Kine i nikakvih problema sa carino nije bilo, pregledaju naplate pdv možda simbolična carina ili ne, u svakom slučaju sve pohvale za izbor , pružiće ti mnogo više od očekivanig.
Post by: zloxi on May 13, 2017, 09:14:41 PM
Nemam taj setup... sklapao sam za prijatelje par komada i testirao naravno, zveeeeer...
Zbog promene zakona ovde gde zivim sam presao na set ispod 250g.
Eachine Falcon 120 Frame
Emax RS1306 4000kv Motori
DYS XM20A ESC (Multishot 14.85)
DYS 3045 Tri Propeller
Mini 20x20mm PBF3 EVO FC (PIKO BLX clone)
Eachine VTX03 25/50/200mW
Runcam Swift 2 (Pre Foxeer)
FrSky XSR
Turnigy Nano-Tech 4s 850mAh 45/90c / Tattu 850mAh 4s 75c
Kome treba samo dobar frejm evo predlog:
http://www.ebay.de/itm/QAV-X-214mm-FPV-Racing-frame-with-4mm-arm-Matek-PDB-XT60-5v-12v-for-QAV-210-/381978219720 (http://www.ebay.de/itm/QAV-X-214mm-FPV-Racing-frame-with-4mm-arm-Matek-PDB-XT60-5v-12v-for-QAV-210-/381978219720)  (<--)
Post by: marko.jovanovic on May 13, 2017, 10:41:56 PM
Pa to je isti ovaj frejm tj pandan onog realacc x210.
Ja imam jedan takav sa donjom pločom od 4mm.
Jednostavno neuništivo.
Zaštićenost komponenti odlična.
Padova zilion
Do sada promenio samo vezice koje drže esc-ove i TX
30A ESC-ovi su bespotrebni ako se ne vozi veći setup od 4S
Ja imam dys 20A multishot i propelere 5x45x3
Motori emax 2205rs 2300 kv
Setup je taman
Post by: sloba_b on March 19, 2018, 08:32:49 PM
Porucio sam sl ESC-ove https://www.aliexpress.com/item/4PCS-Racerstar-RS20A-Lites-20A-Blheli-S-16-5-BB2-2-4S-Brushless-Motor-Support-Dshot600/32820593061.html
Ideja mi je da vidim da sklopim neki kvad bez zurbe..dok pocnu da stizu delovi i sl. Zanima me da li ima nekih predloga za jeftine motore, mislio sam sa HK da uzmem one najjeftinije  https://hobbyking.com/en_us/brushless-motor-c2206-2300kv-ccw.html
Ako neko ima link za neki dobar popust ili akciju sa aliexp. ili bangod-a neka posalje :)
npr https://www.aliexpress.com/item/4-6-8-pcs-2204-Brushless-Motor-KV2300-For-RC-Aircraft-Plane-Multi-copter-Brushless-Outrunner/32721819295.html?spm=2114.search0204.3.47.60321472ROO9QY&ws_ab_test=searchweb0_0,searchweb201602_3_10152_10151_10065_10344_10068_10342_10343_10340_10341_10696_10084_10083_10618_10307_5711215_10313_10059_10534_100031_10103_10624_10623_443_10622_5711315_10621_10620_5722415-normal#cfs,searchweb201603_25,ppcSwitch_2_ppcChannel&algo_expid=f84c47f1-2256-4016-8bdc-e13b8cffa2f5-6&algo_pvid=f84c47f1-2256-4016-8bdc-e13b8cffa2f5&priceBeautifyAB=0
https://www.aliexpress.com/item/F18558-A-4Pcs-Set-CW-CCW-2204-2300KV-Brushless-Motor-for-DIY-Mini-Multirotor-Quadcopter-Racing/32795554452.html?spm=2114.search0204.3.222.1b3b1472vGmoDW&ws_ab_test=searchweb0_0,searchweb201602_3_10152_10151_10065_10344_10068_10342_10343_10340_10341_10696_10084_10083_10618_10307_5711215_10313_10059_10534_100031_10103_10624_10623_443_10622_5711315_10621_10620_5722415,searchweb201603_25,ppcSwitch_2_ppcChannel&algo_expid=73590e72-1f05-4d65-9b97-dcbc6a72e32c-33&algo_pvid=73590e72-1f05-4d65-9b97-dcbc6a72e32c&priceBeautifyAB=0
Sto se tice FCU gledao sam u smeru
-OMNIBUS F4 Pro V3 Flight Controller Board Built-in Barometer OSD TF Slot For FPV Quadcopter
-OMNIBUS Betaflight F4 V2 PRO Flight Controller Board w/ Baro Built-in OSD With Power Supply For RC FPV Mini Racing Drone
