🛩️ MODELI => 🚀 Dronovi & FPV => Topic started by: mor_phin3 on January 07, 2018, 07:58:18 PM
Title: FPV Racing Quad - setup
Post by: mor_phin3 on January 07, 2018, 07:58:18 PM
Planiram da uzmem neki racing quad, FPV sistem, stanicu itd. Razmišljam da za početak uzmem Emax Babyhawk ali model R, stanica FrSky Q X7, 2 seta propova od po 6 parova(dok se uhodam u kontrole) i neki cvikeri tipa Quanum v2. Eh sad, cilj je da to uklopim sve u budžet od oko 200e. Uspeo sam da nadjem dron, stanicu, i propove za 220e (bez naočara). Zanima me vaše mišljenje o ovoj priči. Ima li boljih rešenja? Dron već ima fpv kameru, fpv tx, motori su brushless, ima 12A esc-ove i svidja mi se. Evo linkova navedenih stvari:
Quad - https://www.aliexpress.com/item/EMAX-Babyhawk-Race-112mm-RS1106-5-8g-VTX-switchable-25-200mw-Micro-CCD-Sensor-Camera-FPV/32847908133.html
Taranis - https://www.aliexpress.com/item/FrSky-ACCST-Taranis-Q-X7-QX7-2-4GHz-16CH-Transmitter-Without-Receiver-For-RC-Multicopter/32839454348.html
Propovi - https://www.aliexpress.com/item/Best-Deal-6-Pairs-Emax-AVAN-Micro-2-Inch-CW-CCW-4-Blade-Propeller-for-1106/32847096626.html
Naočare sam mislio sa HK-a da nabavim
Title: Re: FPV Racing Quad - setup
Post by: matic on January 07, 2018, 09:20:23 PM
Ne postoji nikakve sanse da sve to kupis za 200e.
Post by: mor_phin3 on January 07, 2018, 09:53:39 PM
Quote from: matic on January 07, 2018, 09:20:23 PM
Mislio sam bez naocara, ali svakako si upravu. Bez 260e nista
Post by: alzo on January 07, 2018, 11:32:36 PM
Nemoj zaboraviti i barem 100 eura za carinu. mmmm Ja sam pre par godina naručio neke instrumente i na 200 era imao sam oko 8000 carine..... BG carina radi savesno  ::) ::)
Post by: serGolden on January 08, 2018, 12:27:47 PM
Ako se druzis ponekad sa lemilicom ne bi bilo lose da narucujes u delovima tu skoro neces imati carine i jos veceg Pdv-a, jedino na Taranis ces imati 3600din toliko je mene izaslo pre par dana sve carina+pvd+postanski troskovi, ali ne zalim, googles ce te isto kostati carine, znaci sve sto nije veliko bice ok
Licno sam poceo od 5`quad ali sada posle skoro godinu dana mislim da sam trebao poceti sa nekim od 3`filing je slican a jeftiniji delovi pogotovo baterije. Za 5`ti treba vise prostora za manervisanje 3`je potaman za start.
Ako ti je problem oko novaca za googles toplo ti preporucujem Eachine EV800 FOV  mu je ogroman :) ne znam nemam tacan podatak ali su ti oci ispunjene ! Ima i drugih naravno ali Fov + prijem sama velicina bez zamerki.
Post by: mor_phin3 on January 08, 2018, 03:21:28 PM
Quote from: alzo on January 07, 2018, 11:32:36 PM
Znam, I za to sam se pobrinuo
Post by: mor_phin3 on January 08, 2018, 03:27:08 PM
Quote from: serGolden on January 08, 2018, 12:27:47 PM
Nasao sam bolje resenje, vec sklopljen full quad, sa frejmom blade 150, 4000kv motori itd. Stanicu moram posebno, najverovatnije frsky q x7. Ostaju naocare da se nabave.
