🛩️ MODELI => 🚀 Dronovi & FPV => Topic started by: varadero on August 23, 2018, 08:58:56 AM
Title: Freestyle racing drone build
Post by: varadero on August 23, 2018, 08:58:56 AM
Pozdrav (nakon dugo vremena).
Krenuo sam u sastavljanje 230mm racing drona, pa ću u ovaj thread stavljati kako budem napredovao.
Dosta sam se raspitivao o komponentama kod naših renomiranih letača (MrRockwell).
Pa da krenem sa prvim postom.
Frame:
GEPRC GEP Mark 2 frame kit sa Banggooda:
https://goo.gl/5vmxhy
I naravno video:
https://youtu.be/wWU1iXvwvRg
Title: Re: Freestyle racing drone build
Post by: varadero on September 07, 2018, 10:45:14 AM
Evo me opet, sorry svima što to brže ne radim, ali ne stignem.
Na redu je 4u1 ESC
https://goo.gl/eES4gE
https://youtu.be/u6MddNDsaSQ
Post by: rajker on September 07, 2018, 09:14:01 PM
 :)aplauz (res)
Post by: varadero on September 23, 2018, 07:29:13 AM
Na redu je FC.
https://goo.gl/7bJN1v
http://www.youtube.com/watch?v=OPDtT_Jjq4c
Post by: varadero on October 07, 2018, 06:55:39 PM
Stigao Kakute F7 AIO :)
Još samo motori koji su na putu....
https://youtu.be/litAtjDDf08
Post by: varadero on October 19, 2018, 05:38:30 PM
I evo zadnji dio, motori
https://goo.gl/ZjoF2P
Sad još kad se sve to posloži, i onda ću napraviti video :)
https://youtu.be/eRE1_q0mGEs
Post by: rajker on October 19, 2018, 07:20:19 PM
 :)aplauz (res) :)aplauz
Post by: varadero on December 06, 2018, 02:19:42 PM
Evo ga, konačno je gotov :)
https://youtu.be/RbCivLWZfXA
►Frame: https://goo.gl/5vmxhy
►4 in 1 ESC: https://goo.gl/eES4gE
►Camera: https://goo.gl/FT8Ah9
►VTX: https://www.akktek.com/products/vtx/infinite-dvr-vtx.html?acc=91
►Flight Controller: https://goo.gl/GmPorf
►Motors: https://goo.gl/ZjoF2P
►Antenna: https://goo.gl/k3pBSD
Post by: rajker on December 06, 2018, 06:20:46 PM
 :)aplauz  dobro,lepo je to ispalo  :)aplauz Nek leti dobro,bez padova  ;namig
Post by: varadero on December 24, 2018, 11:07:41 AM
Evo i prvi testni let, konačno.
https://youtu.be/REJXOTfWU7A
Post by: marko.jovanovic on December 26, 2018, 07:45:32 AM
Za fc si mogao da izabereš kiss v1 jer bi te koštao sigurni manje a daleko lepše i bolje lete od svih do sada BF fc-ova. POgotovo od tih sa osetljivim žiroskopima jer oni moraju baš dobro da se izoluju od vibracija da bi radili u svom punom kpacitetu. Ipak je za sadqa gyro 6500 neprevaziđen.
Jedino što nema to je osd koji moraš dodatno da dokupljuješ ali na svim danas kamerama imaš ono što ti je najpotrebnije a to su ime letelice, vreme i napon baterije. ostalo sve zna da  smeta na ekarnu....Tako da ti OSD faktički i ne treba.
Motore si trebao uzeti emax rsII koštaju koji dolar ili evro skuplje ali bar imaš titanijumsku osovinu. Mada po meni zatvoreni motori su ipak bolji jer kod tih lite i otvorenih motora koji su namenjeni za trke vrlo često otpada dno i krivi se.
Kod zatvorenih to nije tako rasprostranjen slučaj Jer su drugačije i jače konstrukcije dole a i ako se nešto pokrivi imaš da kupiš rezervno zvono sa magnetima i osovinom, ne moraš ceo motor. Ja koristim još uvek rs2205s motore i šta su ti preživeli ne mogu ti opisati tako da EMAX što se tiče motora je u samom vrhu rame uz rame sa tornado , kobra, luminear, brotherhobby.
ESC takođe un pogodak jer DYS takođe u samom vrhu... Za te 4 u 1 nisam siguran kakvi su ja uglavnom koristim na armovima klasične i prezadovljan sam. Ljudi generalno imaju problema sa 4 u 1 esc-ovima jer oni imaju lošije hlađenje od ovih na armovima. Doduše sve su do sada bili raznorazni prc drc esc-ovi koji su crkavali ali ipak...
Meni s recimo desilo na jednoj trci ove godine da mi quad padne na travu okrene se i počne da motor i elisa drljaju po travi i zemlji. u tom uzbuđenju zaboravih da disarmujem quad. Kada sam došao imam šta i da vidim. miris paljevine, motor i ceo arm ne smeš pipnuti kao ni esc a motor se vrteo i elisom pravio krater u zemlji. Inače to je trejalo sigurno 2 minuta dok se trka nije završila i dok ja nisam došao do njega. Donosim i svima pokazujem kao se dimi..... POsle 15 minuta hlađenja. arm i udri dalje. MOtori gore pomenuti emax rs2205s esc-ovi dys xs20a znači 20A. Malo koji to može da podnese...
Što se tiče VTX-ova znam da radiš za AKK i solidna je to firma ali TBS je majka i otac za sve VTX-ove. Imaju VTX zove se unify pro race 200-25 mw. VTX koji košta nešto oko 20 eura na N-factory.de ali vredi nemaš pojma koliko. Tih 200 mw ponekad mislim da su 500-600.
Kamera pa šta znam caddax je sada novi u celoj priči i ne sumljam u kvalitet ali ja lično ipak nekko volim runcam. TRenutno imam swift 3 a imam i predatora V3 mikro mislim da su ako izuzmemo eagle najnoviji kamere za veliki respekt. Do tada sam probao mnoštvo raznoraznih ali ove 3 su top....
Sve u svemu solidan quad si sastavio.
Post by: varadero on December 26, 2018, 08:47:29 AM
Hvala,
Sve u svemu, niti jednu komponentu nisam kupio :)
Sve su mi poslali sa Banggooda da napravim review, komponentu po komponentu uglavnom ono što sam tražio i mogao dobiti đabe  ;D
Složio mi ga je na kraju MrRockwell, istestirao i podesio pošto ja baš nisam vičan quadovima koliko avionima.
Solidan quad za 0$
(pijanoo)
Post by: rajker on December 26, 2018, 11:08:51 AM
Bravo za prvi let  (res) Ovo ti je dobro,,0 dinara,, :)aplauz Tako bi i ja rado sastavljao kvadove  (yay).Marko je nas cenjeni clan,ako  nisi siguran sta bi trebao da uzmes,samo treba ga pitati  :big smile .Lepo letenje inace.
Post by: marko.jovanovic on December 28, 2018, 07:51:20 AM
Ako nisi ništa kupio to je onda najbolji quad na svetu sa najboljim komponentama koje postoje :)
I nek služi do potrošenog ležaja na motoru a i dalje kada zameniš iste :)
