🛩️ MODELI => 🚀 Dronovi & FPV => Topic started by: Wulckdroff on March 06, 2020, 01:26:39 PM
Title: Problem sa mini OSD-om i FPV
Post by: Wulckdroff on March 06, 2020, 01:26:39 PM
nadam se da mi neko može pomoći, ukoliko je imao sličan problem. Naime, povezao sam mini OSD na moj Pixhawk 2.4.8. i montirao fpv. Problem je sledeći...kada uključim video izlaz samo sa mini OSD-a na FPV predajnik, dobijam savršenu sliku sa svim potrebnim informacijama Telemetrije. Kada uključim samo kamericu, dobijam sjajnu sliku bez ikakvih smetnji.
Međutim, kada povežem kamericu i mini OSD kako bi trebalo da se poveže (video izlaz sa kamere na mini OSD i sa njega video out na predajnik) javlja mi se smetnja i slika se totalno poremeti.
Šaljem slike u nastavku:
(https://static.rcgroups.net/forums/attachments/8/2/7/4/3/1/a13216847-238-Screenshot_20200301-110025_Go%20FPV.jpg)
(https://static.rcgroups.net/forums/attachments/8/2/7/4/3/1/a13216849-105-Screenshot_20200301-110134_Go%20FPV.jpg)
(https://static.rcgroups.net/forums/attachments/8/2/7/4/3/1/a13216851-136-Screenshot_20200229-154429_Go%20FPV.jpg)
(https://static.rcgroups.net/forums/attachments/8/2/7/4/3/1/a13216853-114-IMG_20200229_154842.jpg)
(https://static.rcgroups.net/forums/attachments/8/2/7/4/3/1/a13216855-85-IMG_20200229_154902.jpg)
Ima li neko ideju?
Title: Re: Problem sa mini OSD-om i FPV
Post by: uros2002 on March 06, 2020, 05:58:37 PM
Postoji grupa na Viberu koja se bavi dronovima i trkama.
Tako ima dosta ljuci koji mozda mogu da pomognu u resavanju problema.
Mozda ovo pomogne nesto.
Probaj da ne dovodis 12V na OSD.
https://ardupilot.org/plane/docs/common-minim-osd-quick-installation-guide.html?highlight=pixhawk%20mini%20osd (https://ardupilot.org/plane/docs/common-minim-osd-quick-installation-guide.html?highlight=pixhawk%20mini%20osd)
Ako neresis posalji mi broj telefona da te ubacim u grupu na Viberu.
pozdrav Dejan
Post by: Wulckdroff on March 07, 2020, 05:41:11 PM
Quote from: uros2002 on March 06, 2020, 05:58:37 PM
pozdrav Dejan
Hvala puno, čekam da mi stigne FTDI da probam da update-ujem firmware od Mini OSD-a....ako ni to ne uspe...javljam se.
Još jednom hvala na odgovoru. Ne vredi, sve moguće varijante sam probao...neće. I zajedničku masu...i 12V...i 5V...
Post by: firebird on March 09, 2020, 09:48:46 AM
Proveri NTSC i PAL podesavanja. Ovakve stvari se desavaju kada je na osd recimo NTSC a na kamerici PAL ili obrnuto.
Post by: Wulckdroff on March 09, 2020, 10:56:47 AM
Quote from: firebird on March 09, 2020, 09:48:46 AM
Hvala na predlogu...ima logike. Ukoliko postoji podešavanje kome se može pristupiti iz app, pokušaću. U suprotnom, čekam FTDI. ;)
