Evo moje nove letelice. :o
(http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/PinX15e.jpg)
Radi na jedinstveni sistem sa pomeranjem cele povrsine krila, bez elerona!
Projektovao sam na PC racunaru a delove sam isekao na CNC sekacu za stirodur.
Konstrukcija je od stirodura i plankiran je prednji deo trupa sa materijalom od kojih se prave
case za jogurt. Izmedu plankova je stalo bas sve od delova pogona, prijemnik i servoi za pomeranje krila.
Krilo se samo natakne za sekund na trup, na sistem patent i spreman je za let.
Farbao sam sa farbom na bazi H2O i dekorisao sa samolepljivom folijom.
Slova su rezana na CNC sakacu folije.
Dimenzije: 1000x1000mm
Pogon: brushless Terra Hobby 3630 (ekv. Axi 2808), Lipo 1800 mAh 20C, Regler 30A
Servo: za krila HS81, za rep HS55
Tezak je oko 700g
Napravio sam i probne letove. Leti kao da ima normalne elerone.
Evo nekoliko snimaka o detaljima i video klip.
Uzivajte, T.E.
http://www.youtube.com/watch?v=CiFNqeDQeJ8
(http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/th_IMG_003.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/IMG_003.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/th_IMG_0015.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/IMG_0015.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/th_IMG_0006.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/IMG_0006.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/th_IMG_0011.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/IMG_0011.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/th_IMG_0007.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/IMG_0007.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/th_IMG_0002.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/IMG_0002.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/th_IMG_0050.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/IMG_0050.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/th_IMG_0046.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/IMG_0046.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/th_IMG_0045.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/IMG_0045.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/th_IMG_0041.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/IMG_0041.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/th_IMG_0037.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/IMG_0037.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/th_IMG_0036.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/IMG_0036.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/th_IMG_0031.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/IMG_0031.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/th_IMG_0029.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/IMG_0029.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/th_IMG_0027.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/IMG_0027.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/th_IMG_0024.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/IMG_0024.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/th_IMG_0022.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/IMG_0022.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/th_IMG_0021.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/IMG_0021.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/th_IMG_0020.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/IMG_0020.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/th_IMG_0018.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/IMG_0018.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/th_IMG_0004.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/IMG_0004.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/th_IMG_0001.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/IMG_0001.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/th_IMG_0001-1.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX15e/IMG_0001-1.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/Palic%2003-01-2008/th_IMG_0029.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/Palic%2003-01-2008/IMG_0029.jpg)
Odlican model, odlicno letenje a "patent" je genijalan,
Pitanje, gde moze da se kupi taj materijal (kao case za jogurt)-Polistiren?
Koriste ga i u grafickoj industriji u raznim debljinama.
Moj je 0.5mm debeo.
Pogledaj u najblizoj firmopisackoj ili grafickoj radionici.
Daje se seci, rezati i smirglati. Idealan je materijal za zamenu aero spera.
Tezi je od spera, ali treba uzeti pola tanje nego sto bi se koristio sper.
Ne mora da je od polistirena. Ima ga i u PVC (tvrdi) i drugim varijantama.
Pozdrav, TibetEagle
Ako ne uspes naci, javi mi, i posla cu ti postom manju kolicinu.
Poz. T.E.
Evo novi slican modela u glow verziji sa 4T motorm.
(http://i298.photobucket.com/albums/mm244/tibeteagle/PinX%203D/th_PinX-9.jpg) (http://i298.photobucket.com/albums/mm244/tibeteagle/PinX%203D/PinX-9.jpg)
Detalji ovde:
http://rcfly4um.org/index.php?topic=500.0
Nije da nije izazvalo paznju medju modelarima, nesto vise na Ruskom forumu:
http://forum.rcdesign.ru/f36/thread134428.html (http://forum.rcdesign.ru/f36/thread134428.html)
(res)
(yay) :jaki: ()-()
Kinezi ti maznuli foru...Ova slika je sa nedavno odrzane JR promocije u Kini...
QuoteKinezi ti maznuli foru...Ova slika je sa nedavno odrzane JR promocije u Kini...
Free patent je za svakoga, pogotovo ako se stavi u izlog (internet) bez stakla :big smile
Studenti kineskog univerziteta aeronautike NUAA (http://ice.nuaa.edu.cn/index/index.php) su napravili istu stvar pomeranja celog krila oko uzdužne ose, ali sa drugačijom kinematikom od mog. Oni su unutar trupa koristili polužni sistem, a moj je direkt drajv u pljosnatom uskom trupu. Znači nije kopija, već su koristili i svoj mozak, što je za očekivati.
Mi (evropljani) smo od pre puno naučili od kineza, recimo kako se pravi papir, štampanje, porcujan, testo, leteći zmaj, barut oo)) svila... i mnogo što šta u oblasti filozofije življenja, lečenja..., pa mogu sada da nauče nešto i o avio mehanici od mene. :jaki: .... lol
