🛩️ MODELI => 🚁 HELIKOPTERI => SUS HELIKOPTERI => Topic started by: iva71 on June 12, 2012, 09:46:40 PM
Title: potreban savet
Post by: iva71 on June 12, 2012, 09:46:40 PM
Pozdrav svima na forumu.
nakupilo se od porudžbina za popravku dosta viškova pa sam mislio da mogu da sklopim od toga jednu kompletnu postavku elektronike za heli. Pokušao sam da uparim ovo        http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=13431 (http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=13431)
                                                        http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=11430 (http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=11430)
                                                        http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=4370 (http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=4370)
                                                        http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=6775 (http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=6775)
                                                        http://www.helipal.com/walkera-devo-10-10-channel-2-4ghz-digital-radio-system.html (http://www.helipal.com/walkera-devo-10-10-channel-2-4ghz-digital-radio-system.html)
                                                        http://www.helipal.com/leopard-lc450-3500kv-brushless-motor-450-class.html (http://www.helipal.com/leopard-lc450-3500kv-brushless-motor-450-class.html)
medjutim posto sam ja totalno elektronski nepismen desilo se to da ne mogu nikako da pokrenem motor
na prijemnik su nakaceni i rade svi servoi i giro ali motor ni da da znake zivota a kad ga stavim na KDS-a (originalna kds postavka) motor radi normalno. moze li neko naći vremena da mi napise kako odraditi programiranje sa karticom koju imam jer ono sto sam nasao na youtube-u ne lici ni najmanje na ovo sto imam i ono najbitnije meni da li taj motor moze uopste da radi sa tim ESC-om. Napominjem da su svi moji pokušaji bili odrađeni nasumice jer smo ja i engleski u teškoj zavadi
HVALA svima koji su ovo makar procitali do kraja.  ()-()
Title: Re: potreban savet
Post by: iva71 on June 15, 2012, 05:09:21 PM
Znam da sam naporan ali moze li mi neko makar reći gde pravim grešku pa motor neće da startuje?
Pokusao sam da uparim ovaj esc  http://www.hobbyking.com/hobbyking/store/__11430__HobbyKing_40A_BlueSeries_Brushless_Speed_Controller.html (http://www.hobbyking.com/hobbyking/store/__11430__HobbyKing_40A_BlueSeries_Brushless_Speed_Controller.html)
sa ovim motorom http://www.helipal.com/leopard-lc450-3500kv-brushless-motor-450-class.html (http://www.helipal.com/leopard-lc450-3500kv-brushless-motor-450-class.html)
Post by: ivanmagd on June 15, 2012, 05:47:15 PM
Probaj da reversujes kanal za throttle, ako ne probaj da spustis trim na throttle palici na minimum, ako ne proveri da ti nije aktiviran throttle hold...
Jel stanica programirana za heli mod?
Sta ti znaci kad motor stavis na KDS-a? Jel na njemu prikacen na drugi esc? jel prikacen na drugu stanicu?
Sta god da radis skini glavne rotore sa helija pa onda probaj sve ostalo jer se moze dogoditi da se heli ispali u punom gasu u sobi sto je veoma rizicno, cak i flybar ako ne pazis moze da te dobro povredi....
Podrav Ivan
Post by: todor on June 15, 2012, 09:29:49 PM
Quote from: iva71 on June 15, 2012, 05:09:21 PM
1.Spoj esc sa motorom ali nemoj spajati esc sa baterijom,
2 Upali stanicu i stavi throttle na mah
3. spoj esc sa baterijom
4. Sacekaj par sekundi i motor bi trebao da "zapisti",
5. Vrati thottle na min
6. tacka po 4
7. raskaci bateriju sa esc
8. ugasi stanicu
E sad kad si sve uradio probaj normalno da upalis stanicu i motor bi trebao da radi.
Takodje trebas da vodis racuna o onome sto ti je ivanmagd rekao.
pozz
Post by: sova on June 16, 2012, 11:29:36 PM
sto ne probas ono klasicno podesavanje motora preko stanice???
nakacis motor skinut sa helija na esc i postavis rucicu stanice u gornji polozaj i upalis stanicu ona daje neke tonove koji nisu kao klasicno paljenje motora na hobbykingu obicno na dnu stranice ima podesavanje motora rucno bez kartice za ovaj nisam na ovom sajtu nasao
Post by: milos78 on June 17, 2012, 12:40:01 AM
 :sljus
Post by: iva71 on June 17, 2012, 04:42:37 PM
Hvala ti bože što stvori pametne ljude koji napraviše rcfly4um
i hvala ti što dade smirenost svima koje smaram svojom glupošću i neznanjem
a posebno hvala sto stvori ljude koji svoju mudrost ne štede
i koji se trude da i nas nepismene nauče nečemu što bismo voleli da naučimo.
Hvala na savetima momci motor je proradio problem je bio do stanice bio je ukljucen throttle hold. Sad radi sve normalno čim budem sklepao HK450 izbacujem slike padova. Jos jednom hvala na savetma.
Post by: sova on June 17, 2012, 09:46:54 PM
ne slike padova nego letova druze moj (yay) (yay) (yay) (yay)
