RC MODELI AVIONA - ELEKTRO => SCALE MODELI => Topic started by: aerofly on April 16, 2013, 10:34:39 PM
Title: Wilga PZL
Post by: aerofly on April 16, 2013, 10:34:39 PM
Wilga PZL u elektro varijanti,raspon 1800..za sada je samo trup u izradi a nakon toga i ostali elementi.Od materijala u primeni je avio sper 3mm narocito na trupu zbog specificnosti geometrije a plank bi bio od balze 2.5mm
Necu nesto posebno pisati tokom postova baziracu se samo na fotografijama!Pozdrav..
(http://i.imgur.com/bLa2BQ5.jpg)
(http://i.imgur.com/3wvfJik.jpg)
(http://i.imgur.com/GztYrvf.jpg)
(http://i.imgur.com/Z5oDN9P.jpg)
(http://i.imgur.com/2VbZRWh.jpg)
(http://i.imgur.com/NyN73u9.jpg)
(http://i.imgur.com/H4aQeLL.jpg)
(http://i.imgur.com/If39WcD.jpg)
(http://i.imgur.com/ERF2OGZ.jpg)
(http://i.imgur.com/9hVsspo.jpg)
(http://i.imgur.com/P7brgmc.jpg)
(http://i.imgur.com/l59KPSa.jpg)
(http://i.imgur.com/utTyJJB.jpg)
(http://i.imgur.com/YVk6BRu.jpg)
(http://i.imgur.com/NnvPtgf.jpg)
(http://i.imgur.com/39WMaId.jpg)
(http://i.imgur.com/NBVunp7.jpg)
(http://i.imgur.com/9DNdtTJ.jpg)
(http://i.imgur.com/XFYK5jF.jpg)
(http://i.imgur.com/QEAzckO.jpg)
(http://i.imgur.com/D4SSO2m.jpg)
Title: Re: Wilga PZL
Post by: misha on April 16, 2013, 11:20:34 PM
Prelepo ruzan avion. Hteo sam da ga pravim, ali nisam mogao da nadjem nijedan dobar plan,
Je li ovaj model kit?
Post by: aerofly on April 17, 2013, 08:37:35 AM
Plan je home made kao I sve sto radim..jbg ;namig. Dosta je zahtevan   model bas zbog svoje lepote..
Post by: Sava on April 17, 2013, 10:59:04 AM
Model je prelep i svaka čast na  "home made" izradi. Jedna mala primedba, bez namere da filozofiram. Sva ugaona pojačanja ja radim od špera debljine od 3-5mm u zavisnosti od pozicije. Balzu izbegavam , bar u izradi trupa, jer se lako pocepa po godovima bez obzira kako je okreneš. Ja bih jedino one trouglove na glavnom rebru, koje uzgred i krila nosi uradio od špera, može i topola.
Pozdrav   :)aplauz
Post by: aerofly on April 17, 2013, 05:41:31 PM
To na slici Savo je samo vizualizacije radi.morao sam sve te elemente pre lepljenja postaviti,premeriti..da steknem nekakav utisak..taj deo je sada ulepljen naravno sperom kao I sve ostalo na trupu ..jedino je plank od balze cak u jednom delu oko vesanja krila ide plank I od spera! Pozdrav ;namig
Post by: aerofly on April 18, 2013, 06:37:47 PM
(http://i.imgur.com/Tr4TkzI.jpg)
(http://i.imgur.com/FgYpJR1.jpg)
(http://i.imgur.com/zoujxvp.jpg)
(http://i.imgur.com/TSiepWZ.jpg)
(http://i.imgur.com/oIPRC03.jpg)
(http://i.imgur.com/iDBXzbC.jpg)
(http://i.imgur.com/4OnHCVh.jpg)
(http://i.imgur.com/5rgGLeO.jpg)
(http://i.imgur.com/SYOce6m.jpg)
(http://i.imgur.com/e83DHPZ.jpg)
(http://i.imgur.com/grDTVhu.jpg)
(http://i.imgur.com/89ecNUH.jpg)
Post by: aerofly on April 20, 2013, 07:50:26 PM
(http://i.imgur.com/iXNThsb.jpg)
(http://i.imgur.com/UvAPn5L.jpg)
(http://i.imgur.com/M7UbJln.jpg)
(http://i.imgur.com/5EeFi62.jpg)
(http://i.imgur.com/GDIkuBG.jpg)
(http://i.imgur.com/qasmQgU.jpg)
(http://i.imgur.com/NYq1iOy.jpg)
Post by: aerofly on April 21, 2013, 03:17:12 PM
(http://i.imgur.com/bKEunsj.jpg)
(http://i.imgur.com/g6oqQDM.jpg)
(http://i.imgur.com/vKULvBZ.jpg)
(http://i.imgur.com/njibdxR.jpg)
(http://i.imgur.com/k7FVGsP.jpg)
(http://i.imgur.com/rkct8HS.jpg)
(http://i.imgur.com/M0KryLF.jpg)
(http://i.imgur.com/qhD4Pcv.jpg)
(http://i.imgur.com/H6WsEnx.jpg)
Post by: aerofly on May 07, 2013, 10:17:52 PM
(http://i.imgur.com/GQbOLpt.jpg)
(http://i.imgur.com/EIh2lU7.jpg)
(http://i.imgur.com/cqGI33T.jpg)
(http://i.imgur.com/WCPsJ95.jpg)
(http://i.imgur.com/hVZ7YXT.jpg)
(http://i.imgur.com/eCOEbl9.jpg)
(http://i.imgur.com/GxKYYnE.jpg)
(http://i.imgur.com/rZfoRPV.jpg)
(http://i.imgur.com/MnGqKoK.jpg)
(http://i.imgur.com/u5LHLGk.jpg)
(http://i.imgur.com/vRFNmVD.jpg)
(http://i.imgur.com/kVV2Qpb.jpg)
(http://i.imgur.com/mHBXgh5.jpg)
(http://i.imgur.com/Zu3P3mX.jpg)
Post by: mirce on May 08, 2013, 12:21:01 PM
Vrlo lepo i pedantno odradjeno do sada... Biće to lep model...
Nego, imaš li planove? Mogli bi se povećati, pa da se napravi Wilga za šlepanje jedrilica.
Post by: nedbojsa on May 08, 2013, 12:57:17 PM
Koliko znam Stanka, a mislim da ga dobro znam, on pravi iz glave, bez planova.
Post by: aerofly on May 08, 2013, 03:09:02 PM
Pa planove klasicne i nemam vise su to neki crtezi sto sa neta izmenjeni i prepravljeni sto iz glave..dosta togu mogu onako usput sto se kaze kada sve to vizualizujem u svojoj glavi,koristim takodje razne fotografije pa samim tim imam i bolju percepciju kako to treba na kraju da izgleda..  !Da imam nekog Martina pri ruci bilo bi daleko lakse ;namig ovako mozda izgleda da je haoticno i neplanski ali nista se ne radi otprilike,vec svaki naredni korak i detalj imam spremljen (ali u glavi) :big smile :big smile!
Na samom modelu nacice se i jedan servo koji ce sluziti za kacenje i otpustanje kanapa tokom slepa ali verovatno nekih manjih jedrilica..da je ovaj model za mene bio bi sigurno vecih dimenzija barem 2.5m (___)
Pozz
Post by: sova on May 08, 2013, 04:13:22 PM
vidim ja utva zavrsena pa si krenunu u "stancanje" veoma lep rad do sad! :)aplauz :)aplauz :)aplauz
Post by: SDmodelar on May 09, 2013, 01:08:43 AM
Što se tiče šlepanja jedrilica evo jedne ptičice http://www.rcfly4um.org/index.php/topic,11305.0.html (http://www.rcfly4um.org/index.php/topic,11305.0.html)
Izvinjavam se zbog ometanja topika.
Nikola
