RC MODELI AVIONA - ELEKTRO => SCALE MODELI => Topic started by: bjanko on November 17, 2013, 03:04:43 PM
Title: Fieseler fi 156 Storch
Post by: bjanko on November 17, 2013, 03:04:43 PM
Fieseler Fi 156 Storch elektro, razmah krila oko 2500 mm(http://i39.tinypic.com/2a681hw.jpg)(http://i39.tinypic.com/axny4k.jpg[/IMG[IMG]http://i39.tinypic.com/uamuf.jpg)(http://i41.tinypic.com/2uqj9l0.jpg[/IMG[IMG]http://i44.tinypic.com/2uxz7f8.jpg)
Title: Re: Fieseler fi 156 Storch
Post by: bjanko on November 17, 2013, 03:15:32 PM
(http://i44.tinypic.com/2uxz7f8.jpg)
Post by: SABURO on November 17, 2013, 03:16:35 PM
Opa, jos jedna roda  (res)
Bas lepo izgleda za sada. Veruj mi da ces uzivati u letenju.  (pijemo)
Post by: bjanko on November 17, 2013, 03:17:04 PM
(http://i39.tinypic.com/4jm2bt.jpg)
Post by: bjanko on November 17, 2013, 03:20:19 PM
Hvala ti Saburo roda je stvarno prelep avion a o letnim karakteristikama sta reci pravi avion moze da sleti na 30 metara
Post by: bjanko on November 17, 2013, 03:45:13 PM
(http://i43.tinypic.com/2l89p4y.jpg)
Inace model sam poceo da radim sa ovog plana koji je predvidjen za dosta manji model i dosta je uproscen.Ja sam malo nesto izmenio pa videcemo.Malo ima planova na internetu
Zahvaljujem se ovomo prilikom modelaru Rajevicu iz Valjeva jer on mi je sredio plan na potrebne dimenzije
Post by: rajevic on November 17, 2013, 07:23:01 PM
Bravo majstorcino vidim da se Storch lepo razvija sa aluminijumskim letvicama. Jedva cekam da vidim dalje radove ali evo da zagolicam mastu jedan Storch vec je leteo i letece i dalje postavicu ovde po koju sliku. U pitanju je manji model raposna 1m20cm od kolege Stojana Filipovica koji je ovo cudo napravio.
(https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-ash2/25061_4448575246052_1313929962_n.jpg?lvh=1)
(https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-ash2/423169_4685871138301_509576388_n.jpg)
(https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-ash2/216109_4685882378582_857766245_n.jpg)
(https://fbcdn-sphotos-f-a.akamaihd.net/hphotos-ak-prn1/11517_4918959365361_77636240_n.jpg)
Post by: bjanko on March 21, 2014, 07:19:59 AM
Nesto se malo radilo na rodi (work)(http://i61.tinypic.com/2uek934.jpg)(http://i61.tinypic.com/kco0hy.jpg)
Ide lepse vreme pa se prebacije u radionicu i trebalo bi ici malo breze.Uradio sam deo poda i poklopac sa gornje strane za prilaz bateriji i servoima
Post by: banbo on March 21, 2014, 08:15:08 AM
E ovo je lepo videti, prava ljubav  (res)
Post by: misha on March 21, 2014, 09:07:46 AM
Zelja mi je da napravim Rodu, ali do sada nisam uspeo da nadjem neki plan a da mi odgovara velicina.
Samo napred.
Post by: rajevic on March 21, 2014, 11:36:30 AM
Misho velicinu odredi koju zelis i isto tako plan ja cu ti razvuci plan koji zelis na zeljenu duzinu i spakovati u poster varijanti A4.  (work)  (pijemo)
Post by: bjanko on March 21, 2014, 03:31:19 PM
Da meni je Rajevic sredio plan gore ima slika sasvim solidan plan, ma roda ima da leti samo tako
Post by: bjanko on March 21, 2014, 03:41:40 PM
Negde sam nasao podatak da 30 godina nijedan avion nije mogao da obori njegove letne karakteristike. Ja sam bas fasciniran ovim avionom i bila mi je zelja da ga napravim i krenuo sam (work) (work)
Post by: Gabor on March 23, 2014, 09:13:06 PM
Biće lep model   :mhm  Pratim gradnju...   4e
Post by: rajevic on March 23, 2014, 09:51:49 PM
 (res)  (res)  (res)
http://www.youtube.com/watch?v=1p8W5z_DOGc&list=UUDouiXM5Nux_JnAFGjuRVfA&feature=share&index=5 (http://www.youtube.com/watch?v=1p8W5z_DOGc&list=UUDouiXM5Nux_JnAFGjuRVfA&feature=share&index=5)
Post by: rajevic on September 13, 2014, 01:41:36 PM
Dokle je stigla gradnja ???
Post by: bjanko on September 13, 2014, 05:02:05 PM
Kakva slucajnost danas sam uzeo nesto oko krila da radim inace nisam radio na njemu 3 ili  4 meseca nista i evo sad sam uzeo malo krila da mu sredim i materijal sam dobio pre neki dan tako da bice nesto trebalo bi
Post by: bjanko on October 26, 2014, 10:00:59 AM
(http://i57.tinypic.com/24mg5rc.jpg)
(http://i62.tinypic.com/2wbstpx.jpg)
Roda je dobila krila
Nego da li ce moci ovaj motor za njega bice tezak oko 3 kg.Najradije bih neki benzinac ugradio ili jaci glow ali finansije ogranicavaju ali ako nekad bude para za neki jaci glow stavicu mu ovako ja mislim da bi mogao da leti sa ovim elektromotorom sta misle drugi iskusniji modelari
Post by: bjanko on October 26, 2014, 10:02:28 AM
Nisam stavio link za motor ja sam ga vec porucio sta bude neka  bude http://www.hobbyking.com/hobbyking/store/__19831__NTM_Prop_Drive_Series_42_38_750kv_785w.html
Post by: magic on October 26, 2014, 10:07:35 AM
Ako si planirao da to bude na 4S sa 13x6,5 moci ce da prodje ali bice malo nategnuto jer je to granicna snaga za model pod uslovom da ne predje 3kg. Na 14x7 ce biti bolje ali je to vec malo nategnuto za motor narocito leti kada temp predje 25C.
Post by: bjanko on October 26, 2014, 10:13:23 AM
Da na 4 S bateriju sam planirao a odlucio sam i esc ja cu ovaj poruciti koliko sam citao po forumima nije los izgleda http://www.hobbyking.com/hobbyking/store/__2166__TURNIGY_Plush_60amp_Speed_Controller.html
Post by: bjanko on October 26, 2014, 10:15:14 AM
A koju elisu recimo 14x7 ili 8 da porucim ja bih drvenu nekako lepse izgleda pogotovo ovo je retro model
Post by: SABURO on October 26, 2014, 11:24:40 AM
Odlino izgleda. Ako ti treba neka fotka/info sa mog modela Storch-a u vezi npr vezivanja/fiksiranja krila i sl. samo pitaj.
Sto se glow verzije tice, 4T 100 - 150cc ce ti biti sasvim dovoljan motor. Trenutna tezina mog modela je oko 5kg +- 100g i trenutno na njemu je Saito 150. Na ovom snimku je motor Saito 120S.
Inace ovo je drugi let ako se ne varam, vec sam zaboravio.
http://youtu.be/CTTJL-9-SJg
Post by: bjanko on October 26, 2014, 12:11:55 PM
Da ovaj tvoj Storch je zaista vrhunski ima i zvuk gledao sam vise puta ovaj snimak a i lepo izgleda .Trenutno sam se odlucio za elektrovarijantu ali zelja mi je da mu ubacim glow 4 takta ali nisam trenutno finansijski u mogucnosti da finansiram.Ja sam se odlucio za zelenu boju sa jugoslovenskom semom iz 50 tih, on je bio u sastavu naseg vazduhoplovstva tih posleratnih godina
