RC MODELI AVIONA - ELEKTRO => SCALE MODELI => Topic started by: bjanko on June 15, 2017, 05:28:12 PM
Title: Utva 75 240 cm od penastih materijala
Post by: bjanko on June 15, 2017, 05:28:12 PM
(http://i.imgur.com/gy6ODBfs.jpg) (http://www.igreklik.com/slike/viewer.php?file=64469585043979973661.jpg&file_imgur=gy6ODBf.jpg)
(http://i.imgur.com/gcCRL1Hs.jpg) (http://www.igreklik.com/slike/viewer.php?file=01493201500302226987.jpg&file_imgur=gcCRL1H.jpg)
(http://i.imgur.com/TqvlK1gs.jpg) (http://www.igreklik.com/slike/viewer.php?file=39170742210281199929.jpg&file_imgur=TqvlK1g.jpg)
Title: Re: Utva 75 240 cm od penastih materijala
Post by: bjanko on June 15, 2017, 05:28:29 PM
(http://www.igreklik.com/slike/images/07530588116043495754_thumb.jpg) (http://www.igreklik.com/slike/viewer.php?file=07530588116043495754.jpg)
Post by: bjanko on June 15, 2017, 05:31:48 PM
(http://i.imgur.com/iZTTGJJs.jpg) (http://www.igreklik.com/slike/viewer.php?file=59727457447659864235.jpg&file_imgur=iZTTGJJ.jpg)
Ova je od balze ona je predvidjena za benzinca od 20 ccm ona je 270 cm raspon
Post by: bjanko on June 15, 2017, 05:32:30 PM
(http://i.imgur.com/U4sYiLWs.jpg) (http://www.igreklik.com/slike/viewer.php?file=41425695624606641354.jpg&file_imgur=U4sYiLW.jpg)
(http://i.imgur.com/uaz5vTEs.jpg) (http://www.igreklik.com/slike/viewer.php?file=35102378157786268828.jpg&file_imgur=uaz5vTE.jpg)
(http://i.imgur.com/TUPAau7s.jpg) (http://www.igreklik.com/slike/viewer.php?file=69693421112838791069.jpg&file_imgur=TUPAau7.jpg)
Post by: bjanko on June 15, 2017, 05:36:00 PM
(http://i.imgur.com/8QRzE8hs.jpg) (http://www.igreklik.com/slike/viewer.php?file=50866354190108600789.jpg&file_imgur=8QRzE8h.jpg)
(http://i.imgur.com/D7Ca1Qgs.jpg) (http://www.igreklik.com/slike/viewer.php?file=24797533534347722176.jpg&file_imgur=D7Ca1Qg.jpg)
(http://i.imgur.com/L693uYHs.jpg) (http://www.igreklik.com/slike/viewer.php?file=89085780500415252979.jpg&file_imgur=L693uYH.jpg)
Post by: bjanko on June 15, 2017, 05:41:05 PM
(http://i.imgur.com/YkfnQ6zs.jpg) (http://www.igreklik.com/slike/viewer.php?file=10201824232220192878.jpg&file_imgur=YkfnQ6z.jpg)
(http://i.imgur.com/SZcdLprs.jpg) (http://www.igreklik.com/slike/viewer.php?file=52123507212100216815.jpg&file_imgur=SZcdLpr.jpg)
(http://i.imgur.com/FzZudlas.jpg) (http://www.igreklik.com/slike/viewer.php?file=13259651719365411182.jpg&file_imgur=FzZudla.jpg)
Dobar materijal, ja dosta volim da radim sa drvetom ali ovaj materijal me bas odusevio ovo mi je prvi model koji pravim od ovog materijala.
Jeftin je i lagan a ima prilicnu cvrstocu i lepak za drvo dobro lepi sto me obradovalo.Koristio sam i balzu da ojacam malo konstrukciju, za sada sam prezadovoljan a videcemo ima tu dosta posla
Post by: bjanko on June 15, 2017, 05:43:06 PM
Vertikalac je radjen od 3 ploce a unutra je kostur od balze od letvica 6x6 da bi imao cvrstinu i da bih lepo ucvrstio sarke koje su ulepljene
Post by: bjanko on June 15, 2017, 05:45:44 PM
Cela ce biti oblepljena pak papirom i ofarbana belim lakom  :jaki:
Post by: bjanko on June 15, 2017, 05:46:29 PM
Toliko za sada treba jos rada a bice slika uskoro ...................................................... ()-() ()-()
Post by: pnedic on June 19, 2017, 09:48:49 AM
Nesto slike ne mogu da se uvecaju. Ili je to trenutno kod mene neki problem.
Nego koji je ovo materijal i gde si ga nabavio ? Da li su to one ploce za laminat (mada je on rebrasti) ?
Post by: bjanko on June 24, 2017, 09:43:00 PM
Zdravo Petre izvini sa malim zaksanjenjem odgovaram tek sad vidim tvoje pitanje  to je materijal koji ide ispod laminata i sa jednu stranu je rebrast a mogu ti recu da ima tu cini mi se i prednost ta rebra ako ti treba neka oblina lako se uvije po tim rebrima.Sa drugu stranu ima kao oznacene linije sto dosta olaksava ako ti treba da iseces nesto bez oznacavanja lenjirom pazi ja sam odusevljen materijalom  .Lepi se odlicno ja sam koristio neki holandski WOODFIX super tako pise na flasi lepi odlicno spoj je neverovatan.Imas u Uradi sam na Karaburmi tamo bas u onom delu gde stoji balza
Post by: bjanko on June 24, 2017, 09:43:53 PM
Ne znam zasto slike ne mogu da uvecam da se bolje vide
Post by: bjanko on June 24, 2017, 09:45:39 PM
(http://i66.tinypic.com/105zafd.jpg)
Post by: bjanko on June 24, 2017, 09:48:29 PM
(http://i66.tinypic.com/jpzmkl.jpg)
Post by: bjanko on June 25, 2017, 09:33:13 PM
Krila sam isekao vrucom zicom i bas su ogromna 41,5 cm je sirina krila bas deluju velika .Uradio sam ih iz 3 segmenta jer krila imaju lom malo veci.Sledi presvlacenjem pak papirom ali sam u nedoumici da li da stavljam elerone ili da idem bez njih Ovo svakako nije model za neke akrobacije to mi je otvoreno pitanje ako ima nekih predloga nije na odmet.
Prvi put sam sekao krilo sa vrucom zicom i bas sam zadovoljan uradjenim
(http://i64.tinypic.com/2s9zpmb.jpg)
(http://i67.tinypic.com/2ykb389.jpg)
Post by: sloba_b on June 26, 2017, 01:01:41 AM
Mozda je bolja ideja sa eleronima a bez rudera ako bi vec nesto eliminisao.
Post by: alzo on June 26, 2017, 11:48:20 AM
Ja bih ga uradio kako je Bog rekao, u fulu. Ipak je to veliki model, trebaće tu i peglanja na sletanju po vetru a i ovo je  niskokrilac. Ako se već ide na elerone šarke mogu da se reše vrlo lako.Ja sam na mestu gde treba da dođu šarke pre presvlačenja papirom zalepio traku tila , svile  ili tako  nekog materijala belim lepkom pa preko papir, i dobio šarku celom dužinom krila ili koliko već treba. Kad se krilo osuši samo se proseku eleroni i to savršeni a nema bojazni da dođe do cepanja papira.
Post by: bjanko on June 26, 2017, 05:29:56 PM
Hvala dugari reseno stavicu i elerone ()-() ()-() sto kaze Alzo kako Bog zapoveda slazem se pozz
Post by: bjanko on June 26, 2017, 11:18:26 PM
Krila sam danas stavio na vagu i imaju 580 grama a trup trenutno 270 grama i mislim da ce krila da budu malo preteska .Moracu da isecem rebra od deprona 6 mm ali mi je problem nisam video da li ima od 3 mm da oblozim krila da budu sto laksa.pokusacu da pronadjem depron od 3 m m .Cilj mi je sto laksi model sa trupom ide lepo jak je i lagan.Nastavak sledi (<--)
Post by: alzo on June 26, 2017, 11:45:22 PM
Depron od 3mm sam video u Sitologici pre desetak dana mislim da su table 100x70
Post by: bjanko on July 10, 2017, 05:32:07 PM
Probao sam papir za pakovanje posiljki ali nesto mi se nije bas svideo i prljav posao.Pokusao sam sa kineskom samolepljivom jeftinom folijom i meni ovo izgleda dobro  samo sto cu je prefarbati naravno pokretni deo u crveno a ovaj staticni u belo kao na pravoj.
Lepo se i smirgla ovaj materijal sve u svemu odlicno za sada
(http://i.imgur.com/7EGpCeYs.jpg) (http://www.igreklik.com/slike/viewer.php?file=47923311823105315596.jpg&file_imgur=7EGpCeY.jpg)
(http://i.imgur.com/5309wYis.jpg) (http://www.igreklik.com/slike/viewer.php?file=26422443345927925599.jpg&file_imgur=5309wYi.jpg)
Post by: bjanko on July 11, 2017, 05:27:04 PM
rep uradjen
(http://i.imgur.com/uFbeHNFs.jpg) (http://www.igreklik.com/slike/viewer.php?file=98914276658315681170.jpg&file_imgur=uFbeHNF.jpg)
Post by: bjanko on March 06, 2018, 04:53:55 AM
Idemo dalje malo po malo kad se nadje vremena.Veliki problem mi je sto ovaj penasti materijal nije gladak tako da cu morati da ga presmirglam pa cu najverovatnije da ga oblozim papirom pa onda spric git pa farba.Kompresor sam kupio pre mesec dana pa ce da ga isprobamo (work)
Post by: bjanko on August 16, 2018, 01:53:16 PM
Utva je dobila krilo ali pd balze
Post by: bjanko on August 16, 2018, 01:54:36 PM
 (yay)
Post by: bjanko on August 16, 2018, 01:57:23 PM
Odlucio sam ipak da je oblozim balzom ipak dobija sada na cvrstini i sve ide lakse i stajni trap a nije dobila na tezini mnogo.Nadam se da ce nekad da poleti ili ce je neko poleteti
Post by: drjack on August 16, 2018, 11:31:26 PM
Odlicna je samo napred , ima ko da je  poleti, dodji na 13 -icu kad je zavrsis. :)aplauz
Post by: bjanko on August 17, 2018, 08:17:22 AM
Super hvala puno dolece na 13 ticu kad se zavrsi pozdrav
