RC MODELI AVIONA - SUS => MOTORI GENERALNO => Topic started by: bjanko on December 10, 2021, 06:03:49 PM
Title: Pomoc u vezi Super Tigre G60 Blue Head
Post by: bjanko on December 10, 2021, 06:03:49 PM
Pozdrav, da li neko ima slucajno rezonantnu trubu za Super Tigre G60 Saturno Blue Head, na njemu je trenutno truba od Rossi 15 i ne odgovara ,a prikljucak na izduvnu granu pase samo mi ova truba treba ako ima neko neka mi se javi ili ako ima neko resenje kako da resim ovaj problem , (pijemo)
Title: Re: Pomoc u vezi Super Tigre G60 Blue Head
Post by: dejan_ts on December 10, 2021, 07:46:54 PM
A jel ima link ka tome sto ti treba
Post by: bjanko on December 10, 2021, 08:37:58 PM
Dejo ovaj deo to je od druhog motora od manjeg slabijeg Rossi 15 to je za motor 2 ili 3 ccm a ovaj moj motor je 10 kubika i treba mi za tu velicinu motora
Post by: dejan_ts on December 11, 2021, 12:55:47 AM
https://www.worthpoint.com/worthopedia/excellent-super-tigre-saturno-60-blue-1915126197
Ovde to tako izgleda po originalu kako ja vidim
Post by: dejan_ts on December 11, 2021, 12:57:36 AM
http://sceptreflight.com/Model%20Engine%20Tests/ST%20G60%20Blue%20Head%20RC.html
Post by: bjanko on December 11, 2021, 02:00:45 AM
https://images.app.goo.gl/oWnEkxpDk7GjvoVw6
Post by: bjanko on December 11, 2021, 02:06:23 AM
https://www.wangzze.xyz/products.aspx?cname=rc+airplane+tuned+pipe&cid=22
Post by: bjanko on December 11, 2021, 03:39:07 AM
https://youtu.be/HSd4ZfrW3Hw
Post by: bjanko on December 11, 2021, 03:39:53 AM
Kolika cev kao u Tomosa
Post by: bjanko on December 11, 2021, 08:29:45 AM
Ako ima neko viska znaci samo cev za dvotaktni avio motor od 10 kubika ,ovaj dodatak sto ode sa izduvne grane imam znaci samo cev , naravno ako ima viska za prodaju ili bi eventualno menjao za manju od Rossija 15 (pijemo)
Post by: doajen on December 19, 2021, 02:04:58 AM
Imam  ih nekoliko, uglavnom  specijalno gradjenih za taj motor od 10 ccm. Neke su standardne, neke za pogon visoko friziranih  motora za pogon takmicarskih motora NAVIGA camaca, sve su sa prigusivacima zvuka . Ja nisam u stanju da ti prosledim slike  na forumu (nemam pojma kako se to radi!)  Postoji mogucnost da sve obave to moji sinovi /ako ti  bar nisu u frci!) ali nisu tu, jedan je poslom negde u belom svetu, a drugi na specijalnoj obuci podvodnog snimanja i podvodnih radova na Santoriniju. .
Naravno za bilo koju kombinaciju veze morao bi da imam tvoju viber, adresu, stabilni telefon ,ime i adresu,
i ako mi se cini da smo mi vec obavljali neku trgovinu, ali sam ja sve te dostavnice negde zaturio, i tako ostao bez tvog imena ,adrese i telefona!
Cini Sveti Demencije svasta!!!
Moja adesa:
Vladan Sreckovic
Vulevar Arsenija Carnojevica 219 /sprat drugi, stan sest/
Novi Beograd
Telefoni: Stabilni /011/ 6124 194; Mobilni 064 90 99 110.  ( Mobilni koji ima Viber je 064 1196388)
Mozda si ti ovaj problem vec  resio, ma da (i iz licnog poznanstva sa  Tigrovcima" /bravo, poznajes pravi izraz/ ekspanzioni sud!!!/ proizvodili samo "trubu" za 15-ticu, /penjaci i brzinci!/ tvoj je nekompletan;original je imao jos jedan deo za podesavanje "stelovanje" motora, no to nema nikakve veze sa tvojim problemom. Srdacan pozdr
