Author Topic: Poklanjam plan za Cessnu 182 Skylane  (Read 308 times)
Offline SDmodelar
    • Moj KP
« on: October 09, 2024, 12:30:36 PM »
Zdravo,
Poklanjam originalni plan koji mi je stigao iz Amerike od firme Top Flight Models. Plan je na dva A0 papira i prilično je detaljan.
Evo i nekih karakteristika modela
The Classic Cessna 182 Looks You Want with Top Flite's Legendary Quality
in this 1/5 scale Cessna Skylane.
FEATURES: CAD engineered interlocking parts make building a breeze.
ABS strips for the control surfaces easily simulate the full-scale Cessna's corrugated Fowler flaps, ailerons, and elevator.
SPECIFICATIONS: Wingspan: 81"
Wing area: 906sq.in.
Length: 64.5"
Weight: 10-12lbs.
Wing loading: 23-28oz/sq.ft.
Throws: Hi Rate Low Rate CG: 4" aft of le @ root
Elev 1-1/16" each 3/4" each way Flaps: 1" Takeoff
Rud 1" each way 5/8" each way 2" Landing
Ail 5/8" each way 1/2" each way
REQUIRES: .61-.91 2-stroke or .91-1.20 4-stroke Engine
4-6 Channel Radio
5-7 servos (ailerons and flaps use two servos each)
5th and 6th channels for optional flaps and lights (see ACG for info)
4-plus Rolls of Covering
Zainteresovani neka se jave na PP
Nikola
Skype:  sdmodelari
